Old Sep 24, 2012, 09:40 PM
caall99 is offline
Find More Posts by caall99
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
Blade 400 Flybarless conversion
I would like to convert a hand me down Blade 400 3D into a flybarless heli, in preparation for my FPV endeavors. I plan to use a MultiWii controller with accelerometers for auto level flight. Will a Trex450 Flybarless head fit and work on the blade 400? Here is a link to one i am thinking of using (i apologize if ebay links are not allowed)
http://www.ebay.com/itm/Hot-Sale-CNC...item3f19466fd6
caall99 is offline Find More Posts by caall99
Old Sep 24, 2012, 09:49 PM
caall99 is offline
Joined Jun 2011
or this... http://www.hobbyking.com/hobbyking/s...450_HK450.html
but then would i still need to get a TREX 450 swash plate? are blade 400s intended to have part interchangeability with TREX 450s?
Old Sep 25, 2012, 03:55 AM
MinfangDuan is offline
Find More Posts by MinfangDuan
Fly Hard, Land Soft
Australia, VIC, Melbourne
Joined Jun 2012
blade and align are totaly different companies and blade deos not copy people so I dont think the parts are interchangeable and i also dont think the multiwii board can handle CCPM mixing which is required for the blade 400. the blade 450 flybarless conversion kit might fit on you 400 but I'm not 100% sure.
MinfangDuan is offline Find More Posts by MinfangDuan
Old Sep 25, 2012, 06:31 AM
caall99 is offline
Joined Jun 2011
any cheap control boards like kk 2.0 that CAN handle CCPM?
Is shaft diameter the only thing that matters when replacing the head and swash on the blade 400? I can't find much info on someone having done this yet.
Old Sep 25, 2012, 08:50 AM
Fly Hard, Land Soft
Joined Jun 2012
just get a vbar it will make life alot easyer and getting a align trex 450 will make it cheaper aswell. align may be expensive to buy compared to blade but the repairs are half the price.
Old Sep 25, 2012, 08:58 AM
caall99 is offline
Joined Jun 2011
i am not interested in spending a lot of money on this project. i plan to leverage DIY even if it makes my life more difficult. i want auto level capability, and a flybarless head on a blade 400. what are my options?
Old Sep 25, 2012, 05:23 PM
Elios000 is offline
Find More Posts by Elios000
United States, MO, Springfield
Joined Jul 2010
SK720 or MSH Brain will do that for you if you HAVE to have auto level
really if you want to do FPV a quadrotor is the way to go
the align head should work as long as the main shaft is the right size
Elios000 is offline Find More Posts by Elios000
Old Sep 25, 2012, 09:05 PM
Fly Hard, Land Soft
Joined Jun 2012
What about a 3GX with a APS then you can have return to home and GPS position hold.
Old Oct 28, 2012, 07:19 AM
pommesschranke is offline
Find More Posts by pommesschranke
pommesschranke's Avatar
Slowenien, Krško
Joined Sep 2011
I use the $30 flybarless unit from CopterX on 2 of my helis - no problems so far.
pommesschranke is offline Find More Posts by pommesschranke
Old Oct 28, 2012, 10:57 AM
mdugas is offline
Find More Posts by mdugas
Joined Aug 2003
hi,helifreak should have how to make the stock head fbl ,as an option ,as well as other conversions
mdugas is offline Find More Posts by mdugas
Old Nov 10, 2012, 01:45 AM
italiano687 is offline
Find More Posts by italiano687
Joined Dec 2009
Yes the align FBL head will work. The swash plate won't because of the anti rotation bracket style. You have to cut about 2 mm off the top of the main shaft to get the correct pitch settings,
italiano687 is offline Find More Posts by italiano687
Sold Cox Tailwind 40 convered to EP with Floats $400 LPU be69ar Aircraft - Electric - Airplanes (FS/W) 0 May 04, 2012 11:01 AM
For Sale Flybarless Blade 400 Hs65's, DS520 Etc. Bonestockz06 Aircraft - Electric - Helis (FS/W) 0 Nov 25, 2011 03:27 PM
Question what size motor to convers speed 400 e-plane to glo Thermalin Fuel Plane Talk 4 Aug 01, 2007 11:53 AM
Blade convering question cat5 Micro Helis 9 Oct 21, 2005 11:52 AM
