Old Feb 05, 2013, 10:19 PM
mejmea is offline
Find More Posts by mejmea
Always trying to learn
mejmea's Avatar
United States, IL, Batavia
Joined Feb 2011
Originally Posted by D.R.BOWERS View Post
Some 1SQ flying in my side yard.
Nice! I wish we had that weather here too....
mejmea is offline Find More Posts by mejmea
Old Feb 06, 2013, 10:26 AM
D.R.BOWERS is offline
Find More Posts by D.R.BOWERS
D.R.B.
D.R.BOWERS's Avatar
EAST TN.
Joined Oct 2007
I have been flying outside on good weather days and inside on the bad days. I have been wanting to get into quadcopters for some time now and thought I would give it a try. I really like flying the 1SQ with my DX7. As fun goes, it is giving my fixed wing planes a run for the money.
D.R.BOWERS is offline Find More Posts by D.R.BOWERS
Old Feb 06, 2013, 10:36 AM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
I absolutely agree - the 1SQ is a blast. I have both helis and planes and I think that the stick skills complement each other and the 1SQ can be flown almost anywhere/anytime so you can keep your fingers in practice. Additionally, the light weight of a smaller model like the 1SQ keeps it from being damaged as easily so you can try things that you might afraid to try with something larger and more expensive!
Old Feb 07, 2013, 07:17 PM
D.R.B.
D.R.BOWERS's Avatar
EAST TN.
Joined Oct 2007
O.K. I have been flying my 1SQ and loving it and since this is my first quadcopter I was wondering if there is anyone on this thread that has flown a Blade mqx that could compare flying characteristics of the two.
Thanks.
Dale
Old Feb 08, 2013, 01:07 AM
bmilla39 is offline
Find More Posts by bmilla39
Air Bender
bmilla39's Avatar
Joined Jan 2013
Thanks.
Dale
I have both and fly them pretty much daily. I enjoy both but I feel the 1sq is quicker in forward flight, turns better, and is less affected by wind.
bmilla39 is offline Find More Posts by bmilla39
Old Feb 08, 2013, 07:17 AM
muck76 is offline
Find More Posts by muck76
muck76's Avatar
Joined Mar 2006
i'm suppose to go fly tomorrow with a group in a gym... thinking about picking up the AL for my DX7. Wish my wires came in for my Armattan
muck76 is offline Find More Posts by muck76
Old Feb 08, 2013, 03:56 PM
superfets is offline
Find More Posts by superfets
Can you flip that over for me?
Canada, SK, Saskatoon
Joined Jan 2013
Thanks.
Dale
I have both. And there the same. I fly the 1SQ inside the the MQX outside. (For now, have an Armattan on the way ) The tricky part is setting them up to behave the same in your TX if using your own. But both use a 3 axis gyro system. Also have the QR1 and it flys different.
Cheers
Stef
P.S. Too bad you can't show off the Armattan in the gym. I'd be bribing my LHS to help me out.
P.S.S. My friend put his 1SQ arms and motors on his MQX for fun. It's got alot of jam. lol
superfets is offline Find More Posts by superfets
Old Feb 08, 2013, 04:08 PM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
Thanks.
Dale
Cheers
Stef
@!Dale
I also have both. I have not flown the mQX as much simply because of weather (I've done more indoor flying in my house where the 1SQ is simply a better "fit"). When I have flown the mQX in conditions that are not too windy it probably feels slightly more stable than the 1SQ simply due to it's larger size/mass. By the same token, however, it is also therefore not quite as nimble. With sudden moves (like a flip for example) or if the wind is gusty I have occasionally had the mQX develop kind of a shudder, presumably as the gyros try to keep things under control. It's not a big deal but it can be a little unsettling. The 1SQ handles wind pretty well because it's so small there isn't much surface area for the wind to catch, but it also has less brute power than the mQX imo. I have flown the 1SQ in 10-15 mph (est.) gusty winds and while it was fun. I'm not sure if I'd do that with the mQX or not. The mQX does care my keychain camera with ease which can be fun.
@Stef
I'd be curious to know how you have tweaked your settings between the two. Different DR/Expo? Different throttle curves? I haven't done enough playing around yet to get to that point so any information you could share would be appreciated!
Old Feb 08, 2013, 04:27 PM
slawsonb is offline
Find More Posts by slawsonb
Bruce
Palmdale, CA
Joined Sep 2005
I just got the 1SQ and the anylink module for my Futaba 9C radio. The problem is I can't get it to bind. I turn on the radio with the throttle at minimum. Plug in the 1SQ and hold the bind button for 5 seconds. The LED next to the bind button continues to blink rapidly and moving the Tx controls does nothing.
Any ideas?
slawsonb is offline Find More Posts by slawsonb
Old Feb 08, 2013, 04:36 PM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
Any ideas?
See post 1170 on page 72 for some information about what I've observe/done to get a bind. A couple people (myself included) have noticed some oddness about binding if the screws holding the main board to the frame are tightened unevenly so that the board it twisted also. Do you have the RTF Tx and, if so, can you bind to it successfully?
Old Feb 08, 2013, 04:59 PM
pa4ul is offline
Find More Posts by pa4ul
Joined Mar 2011
man i love flying this bird! Plus it can handle quiet a bit of wind! The other day i was flying it in 25mph winds and it was able to stay afloat!
pa4ul is offline Find More Posts by pa4ul
Old Feb 08, 2013, 05:23 PM
Joined Jan 2013
Originally Posted by mejmea View Post
@Stef
I'm using a DX8, and have 3 f-modes set up for DR/Expo on each. Mild, Wild and INSANE. There both set up differently. And I'm continuously messing with them. It's been a trial and error process. But here's where i'm at.
MQX - Travel set to max on all flight modes, 150% on my radio, D/R - F1@35, F2@66, F3@125. Expo at 20 on all three. and Gyro inhibited.
1SQ - Travel set to max on all flight modes, 150% on my radio, D/R-EXPO F1 @ 80/35, F2 @65/30, F3 @ 100/70. Gyro - F1 @ 25, F2 @ 45, F3 @ 70.
Not sure if that helps, but that's where I'm at and will be changing it again i'm sure.
Cheers
Stef
Old Feb 08, 2013, 05:28 PM
slawsonb is offline
Bruce
Palmdale, CA
Joined Sep 2005
Thanks for the info. Did you mean post 1070? I tried that procedure a couple dozen times and one of those times the motors started pulsing. Full power for a couple seconds. Off for a couple seconds. Over and over. Probably got it in some weird mode.
I did try loosening the screws to see it that helped. No luck.
I don't have the RTF Tx.
Bruce
Old Feb 08, 2013, 07:35 PM
Zellot is offline
Find More Posts by Zellot
Joined Dec 2012
Bruce
I'm using an RTF with a JR XP652 Tx and Anylink
What I've noticed is that if you wait for anything longer than about 1-2 seconds before pressing the bind button on the 1SQ board AFTER plugging in the battery you will not get it to bind.
This is what I've been doing since figuring that out and have been able to bounce back and forth between stock Tx and Anylink without issue EVERY TIME
1. Turn on your Tx with Anylink (Make sure throttle stick is at 0)
2, Have the 1SQ with battery connector barely seated so that it can be plugged in one handed.
3. Other hand with finger hovering over the Bind button BUT NOT pressing it
4. Plug in the battery
5. AS SOON as the lights on the board come on PRESS AND HOLD the bind button for at least 3 seconds and you should get a bind.
It seems that if the board makes it to Gyro init then the BIND function will not work..
It's kind of like trying to get into the BIOS on a PC by getting that F10, F2 or DEL in at the right moment when it boots.
Hope this helps..
Good luck
Zellot is offline Find More Posts by Zellot
Old Feb 08, 2013, 07:46 PM
D.R.B.
D.R.BOWERS's Avatar
EAST TN.
Joined Oct 2007
Thanks to all for the info. I am loving my 1SQ but was thinking that the bigger geared blades would give it more torque and make it able to carry a fpv camera. I did not think that it would be as maneuverable as the 1SQ. I was just wondering if it would be worth buying the MQX.
Thanks.
Dale
For Sale Heli-Max 480 4300kV High Perf Brushless Heli Motor boots.isa Aircraft - Electric - Helis (FS/W) 0 Jul 22, 2012 10:02 PM
Discussion New Release Heli-Max Novus FP 200 Heli Gym Flight wnppmy Beginner Training Area (Heli-Electric) 20 May 30, 2012 07:40 PM
Sold Heli-Max Blade Balancer/COG $12 SOLD themadhatter196 Aircraft - Electric - Helis (FS/W) 0 Feb 28, 2012 08:23 PM
Sold Heli-Max Novus CP Clavin01 Aircraft - Electric - Helis (FS/W) 6 Feb 24, 2012 03:55 PM
Sold 4 Heli-Max Helis (2) Heli-Max Novus Huey 1-D Coax & (2) Helix-Max Novus FP 125 Sea Planes Aircraft - Electric - Helis (FS/W) 3 Oct 17, 2011 06:01 PM
