Old Jan 03, 2013, 09:14 PM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Originally Posted by grnd0 View Post
Where is a good source for the Graupners ?
These are the two places I buy mine...
getfpv.com
gothelirc.com
TaSaJaRa is offline Find More Posts by TaSaJaRa
Old Jan 04, 2013, 09:00 AM
grnd0 is offline
Find More Posts by grnd0
Palm Bay, FL
Joined Nov 2005
Thanks guys for the info. I'm running the 8X4.5 colored
props now with the 1200kv motors on the Spider.
What size Graupner would be best to use for FPV
flying? I'm only using a 2200mah 3 cell right now
which gives me 7min of flight time.
grnd0 is offline Find More Posts by grnd0
Old Jan 04, 2013, 10:26 AM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
if you're running 8" SF props you could most likely use the 9" graupners. If your worried about pulling too much amps, go with the 8". But the graupners seem to pull less amps.
I forgot to mention espirit sells graupner E props too.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Jan 04, 2013, 02:59 PM
jmdlcar is offline
Find More Posts by jmdlcar
USA, OH, Marysville
Joined May 2010
xRotor IFrame Quad (H-Quad)
Here is a list I made up with parts do I need anything else.
xRotor IFrame Quad (H-Quad) $39.99
http://blueskyrc.com/index.php?main_...products_id=59
OrangeRx T-SIX 2.4GHz DSM2 6CH Programmable Transmitter w/10 Model Memory (Mode 2) $64.99
http://www.hobbyking.com/hobbyking/s...y_Mode_2_.html
OrangeRx R610 Spektrum DSM2 6Ch 2.4Ghz Receiver (w/ Sat Port) $5.89
http://www.hobbyking.com/hobbyking/s...Sat_Port_.html
Hobbyking KK2.0 Multi-rotor LCD Flight Control Board $29.99
http://www.hobbyking.com/hobbyking/s...rol_Board.html
Turnigy 2200mAh 3S 30C Lipo Pack $13.79
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
HW 25A Electronic Speed Controller for Brushless Motors $11.99 ea 4 needed
http://blueskyrc.com/index.php?main_...products_id=39
Suppo A2212-11 - 1200kv Outrunner Motor $16.50 ea 4 needed
http://blueskyrc.com/index.php?main_...products_id=38
Black Gemfan 5030 2-Blade (Quad Pack) $6.50 ea 2 sets
http://blueskyrc.com/index.php?main_...products_id=49
Multi Rotor Landing Skids (450 size) $6.99
http://blueskyrc.com/index.php?main_...products_id=19
I know some parts are not the best but I'm on a fix income.
Jack
jmdlcar is offline Find More Posts by jmdlcar
Old Jan 04, 2013, 03:05 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Jack, you will want to get the arms booms. These are the ones I like to use:
https://www.magnumwood.com/cart/Prod...?ProductId=942
Bass works just fine.
Also, you may want to get some 2x8mm screws for securing arms and motors.
Also, you want 8045 props with those motors... not 5030.
http://blueskyrc.com/index.php?main_...products_id=24
One last thing, I would recommend the 500 size landing skids -- though the 450 would work as well. The 500 size just look awesome on the IFrame.
Qrome is offline Find More Posts by Qrome
Old Jan 04, 2013, 03:46 PM
Vito is offline
Find More Posts by Vito
USA, PA, New Hope
Joined Nov 2001
At the risk of sounding negative, you might want spare props. I went through a few when I was getting started and I just lost one today when an adapter flew off. No damage but the prop is somewhere in a messy garage. Might not ever find it. A few spares will avoid waiting for an order.
Vito
Vito is offline Find More Posts by Vito
Old Jan 04, 2013, 07:37 PM
jmdlcar is offline
USA, OH, Marysville
Joined May 2010
How much are the arm booms? I can't find 500 size landing skids? What type of glue should I use?
Jack
Old Jan 04, 2013, 08:01 PM
Vito is offline
USA, PA, New Hope
Joined Nov 2001
Jack,
I can chime in on the glue because I learned something on my frame. I think I used regular carpenter's wood glue initially which worked okay. After a few rough landings, I repaired the frame with CA and I glued with the arms in place. It was a major pain when I needed to replace an arm because they were glued seeped into the inside the frame sockets. A lot of chisel work with a 10 mm chisel to get back in business. I always separate the arms from the frame when gluing to prevent this problem.
I bought my landing skids on Ebay. Real cheap but a bit of a wait.
VGito
Old Jan 04, 2013, 11:46 PM
jmdlcar is offline
USA, OH, Marysville
Joined May 2010
Quadcopter
Hi,
I know this is off topic for this. I have never try to fly any type of RC so before I try to build one should I try this first?
http://www.banggood.com/Wholesale-Ne...f-p-49730.html
Then if I can fly this Quadcopter or learn how to fly it then build one?
Jack
Old Jan 05, 2013, 07:35 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Even before you get a real model you should get a RC simulator and try it a bit.
It will help you to assimilate how controls react and how it feels to control a RC model.
Even one as simple and free as FMS will do the job.
The second advice would be the have someone that knows RC to help you but that is not always possible.
IceWind is online now Find More Posts by IceWind
Old Jan 05, 2013, 09:58 AM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
I second this 100% -- find some one local to you and go out with them. Most RC people are super nice guys (some gals).
Old Jan 07, 2013, 11:05 AM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Jack
I bought these Landing Skids on eBay, USA seller
Trex 500 Landing Gear / Skids - Neon Orange 1 Pair $4.99 with Free Shipping
But had to buy the Skid pipes seperate Heli Direct
I just wanted the orange...
You can also buy the Hole kit local in the US
Like Heli Direct
As far as glue goes I use thin CA on the main frame and motor mounts.
Never any glue on are near the booms. If the booms don't fit snug use small amounts of tape until they fit snug. Then use servo type screws to hold then in place.
Booms... I went to Lowes and got hard wood. You can check for warps before you buy, just look down the stick like you would a gun sight.. Always buy a few extra you just may break a few.
Old Jan 07, 2013, 03:49 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Looking Real Good... The IFrame is my favorite quad, and the Spider next...
Originally Posted by fireslayer26 View Post
Started my build. Now just need to decide on a flight controller and motors.
Old Jan 11, 2013, 10:07 PM
Scotth72 is offline
Find More Posts by Scotth72
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
Here's a new vid. Back to MultiWii. 9x4.7 carbon mix Gemfans. Still have a bit of roll shimmy, I will need to come down a bit more on roll P.
Bell Rock 1 13 13 (6 min 51 sec)
Scotth72 is offline Find More Posts by Scotth72
Old Jan 11, 2013, 10:35 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Very nice video... I wouldn't know how to act without any trees to dodge.. LOL
Boy I am jealous, we have not seen the sun in a week and a half... it has rained off and on all week..
Funny thing is the only flying I have done was in the kitchen today.. I bought one of the Flip MultiWii boards. So far it is doing good, would love to try it outside..
New Product xRotor FPV Quad Frame Qrome Multirotor Talk 88 Aug 13, 2012 09:02 AM
Discussion Clear View wing loading Dave K Simulators 3 Jul 09, 2012 05:51 PM
Sold Clear View Flight Simulator $25.00 J.Avant Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 09:15 PM
Discussion 3rd Party Models in Clear View? Forrest Simulators 8 Mar 02, 2012 02:27 PM
