Old Sep 30, 2012, 08:50 PM
Scotth72 is offline
Find More Posts by Scotth72
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
Nice and tidy. Diversity and all. I just use one little Rx on the back of my goggle strap with the antenna sticking up above my head. I will keep your set up in mind if I ever feel the need for more range. Currently, however, its my FrSky that starts beeping at me before I lose video. I checked on a map, I got about 2500 feet away before that happened. I do think I might have put a rock (ground) in between my aircraft and myself at some point.
Thanks for the pictures.
Scotth72 is offline Find More Posts by Scotth72
Old Sep 30, 2012, 10:18 PM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Thanks... the other thing that helps you on your range you don't have big trees where you fly just big rocks LOL
TaSaJaRa is offline Find More Posts by TaSaJaRa
Old Oct 01, 2012, 09:00 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
First Flights
I had a break in the rain so I ran out and did the first flight in the back yard.
Also placed my GoPro on the quad to see how smooth the video would be.
I will have to say I like this quad a lot. Flight got cut short a few times by stepping in an ant bed LOL. Thought they were all gone had to land a second time ...
Guess I missed a few.
Here are a few short flights put in one video.
Maybe you can get an idea on how well it flys. I may need to do some fine tunning
being that I just used stock settings on my MultiWii.
I hope to get a little FPV in soon... Should be fun.
Anyway enough of the chatter... On with the video...
xRotor IFrame Clear View FPV (5 min 46 sec)
Old Oct 01, 2012, 09:28 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Nice job, you had to dodge the cop on the road -- and the ant hill. Nice flying into the carport too. I have some FPV footage I am building up, but nothing too exciting yet. I will share it soon. I will try and get some more in at my local park tomorrow.
Qrome is offline Find More Posts by Qrome
Old Oct 01, 2012, 09:39 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Thanks.... I really want to try out my new FPV gear... But weather still sucks.
I think this is one of my smoothest flying quads I have built yet.
And I am using GemFan props too. Can't wait to try the 9x5 Graupners when they come in.
Thanks for making such a good quad frame, it went together pretty easy. Also the open area in the middle of the frame makes running wires very easy.
Old Oct 03, 2012, 09:46 PM
dnewcomer is offline
Find More Posts by dnewcomer
Joined Mar 2012
what were your dimensions of your sticks for the arms? the body?
thanks
dnewcomer is offline Find More Posts by dnewcomer
Old Oct 03, 2012, 10:40 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
I will be using 9x5 props when they come in, so I made my motor arms 14", this will keep the props from spinning over the main body of the quad.
The main arms are 11" just to keep a good distance between motors. If you were using 8x4.5 or 8x5 you could use 10" for the
main frames and 12" on the motor booms.
Old Oct 04, 2012, 12:24 AM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
thanks
Mine are 12 inches for the front and back. 10inches in the frame. That gives you 12 inches square.
Old Oct 06, 2012, 05:26 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
I been collecting video flights for the past couple of weeks. About 11 flights and 4 different locations went into this video.
xRotor IFrame Clear View FPV (H-Quad) (5 min 8 sec)
Old Oct 07, 2012, 12:38 AM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Fpv crash
Nice flying there...
I had a few flights today... But my first FPV flight with the new quad ended in a crash....
It was flying great..... even thought we had some 15 mph wind gust.
I was flying at a local field, having a good time until, the sorry Nano Tech decided to die 3 + min into my flight. Most of the time I get 6 min + with my spider quad so I thought nothing about 3 min and it shutting down.
As you can see on the video all was fine until the low voltage buzzer went off and my quad went down. I throttled up , but it was falling like a rock.
It took a while to find it. But the lost plane buzzer made it much easier. We drove close to where we thought it went down. And just started listening for the buzzer. We hear it... Saw it across a creek in a tree. Had to drive my truck through the creek to get to it. My good friend climbed the tree to get it for me. Had to use a long stick to get it down.
Boy was I lucky, the only thing I had to fix was a bent landing tube and 2 props that cracked. The frame is rock solid, no damage at all. I flew the quad 2 more times after the crash.
NO MORE NANO TECH's for ME.... That is the second time I had one go bad. And the bad thing is I only have 30 cycles on the battery.
Anyway here is the video of the flight and crash. Along with the tree rescue.... LOL
xRotor IFrame FPV Crash (5 min 21 sec)
Old Oct 07, 2012, 09:49 AM
macinr is offline
Find More Posts by macinr
macinr's Avatar
USA, CA, Santa Barbara
Joined Feb 2003
Pretty funny seeing it be rescued with the FPV footage...
Where did you source your arms from?
macinr is offline Find More Posts by macinr
Old Oct 07, 2012, 10:19 AM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
I went to Lowes, that way I could hand pick the wood and get only the straightest sticks.
Old Oct 07, 2012, 10:21 AM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
This is where I get my wood for the arm:
https://www.magnumwood.com/cart/Prod...?ProductId=942
The link is also found on the xRotor IFrame product page. The wood is super high quality and they ship fast.
I ordered both Bass and Poplar -- every one of them was straight and smooth.
Old Oct 08, 2012, 11:06 AM
macinr is offline
macinr's Avatar
Joined Feb 2003
Thanks... ordered the Poplar (supposed to be harder).
Old Oct 11, 2012, 09:31 PM
Scotth72 is offline
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
Anyone using a GoPro HD2, a new firmware is out. Ups the bitrate to 35Mbps, and adds more frame rates to 1080p. The difference is substantial.
Here is a sample. Sorry about the jello, the 1080 setting is not forgiving in the wind.
GoPro Pro Tune aerial shot.mp4 (0 min 57 sec)
New Product xRotor FPV Quad Frame Qrome Multirotor Talk 88 Aug 13, 2012 09:02 AM
Discussion Clear View wing loading Dave K Simulators 3 Jul 09, 2012 05:51 PM
Sold Clear View Flight Simulator $25.00 J.Avant Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 09:15 PM
Discussion 3rd Party Models in Clear View? Forrest Simulators 8 Mar 02, 2012 02:27 PM
