Old Sep 26, 2012, 08:48 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Originally Posted by TaSaJaRa View Post
Well I am waiting on my 500 size landing gear to come in.
I need to have it mounted before I lay out my wiring and battery placement.
Hope to have it in by Friday...
How are you going to mount it since you extended the arms a little?
Qrome is offline Find More Posts by Qrome
Old Sep 26, 2012, 10:59 PM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Guess I will figure that out when they get here.
May do as I did before and not use the pipes.
Like I did on this spider quad.
TaSaJaRa is offline Find More Posts by TaSaJaRa
Old Sep 28, 2012, 06:27 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Got my Landing gear
My landing gear came in today.... Got them mounted, now I can start laying out my wiring.... want be long now to get this thing in the air.
Old Sep 28, 2012, 06:41 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Hey those LG fit perfect even with the longer fuse sticks. Looking really good. You going clear coat on the frame?
Old Sep 28, 2012, 07:24 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
I did use clear coat I just used satin so it's not that shiny
Old Sep 28, 2012, 08:53 PM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
When you get finish with it you can give to me. Lol.
onefastxp is offline Find More Posts by onefastxp
Old Sep 28, 2012, 08:55 PM
Joined Mar 2008
I love them motors.very smooth running.
Old Sep 29, 2012, 09:52 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Battery mount done
Time to make a battery mount. I will be flying this quad a few different ways.
So I decided to make a long battery mounting area so I cam move the battery around a bit.
This will let me balance depending on the equipment I am using at the time.
I use a paint stick, free wood is good..
Old Sep 29, 2012, 10:03 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Time to mount the motors and esc's
I am using T-Motors 1100kv, along with flashed esc's.
I cut the heat shrink away from the esc where the heat sink is to let it cool better.
Old Sep 29, 2012, 10:10 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Mounting my MultiWii control board
Now the all my motors are soldered up and spinning the right direction.
Time to mount my MultiWii board. I may have to use 8x4.5 props until my 9x5 Graupners come in.
Old Sep 30, 2012, 12:13 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Got it ready for FPV....
Well got all my equipment mounted.... It is ready to go, but the weather is not good.
Light rain, 100% chance...
Anyway here is my video lay out, I added a 300mw 1.3 gHz TX with a Skew Planar Wheel Antenna, 3s 370mAh for my power
and a cable from ReadyMadeRC to go to the GoPro..
Another thing I added was a lost plane finder, pretty cheap but well worth it if you go down in tall brush.
It is hooked into a spare ch. on my RX as slave to the Ailerons. If the beeper don't see any stick movement for 1 min it will start beeping.
It has helped me find my other quad 2 different times when I lost RX signal and a prop broke.
The final weight is 2lbs 9.5 oz or 1179 grams RTF.
Old Sep 30, 2012, 01:40 PM
Scotth72 is offline
Find More Posts by Scotth72
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
Very nice. I see you are giving CP antennas a try. Let us know how they work out.
Scotth72 is offline Find More Posts by Scotth72
Old Sep 30, 2012, 03:58 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Thanks Scott,
Will do on the antennas, I have used them on a 5.8gHz system. And it was like night and day difference over the stock antennas. I was losing my signal and get snow from time to time. Once I swapped it almost never dropped signal and very little snow if any at all.
I had a diversity sys. and used one on one RX and a Helical on the other RX.
This will be a new video sys for me. I swapped to 1.3gHz. I was losing signal behind small trees on the 5.8 gHz. So hopefully this will do much better. Also I can use a smaller video TX and get better range than the 5.8gHz.
Old Sep 30, 2012, 04:55 PM
Scotth72 is offline
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
What radio control frequency are you using? I have read that 1.3 ghz vtx can interfere with 2.4 radio frequencies. That is why I am still using 5.8. That, and I like the tiny antennas.....
Old Sep 30, 2012, 08:16 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
I am using 2.4gHz, but the 1.3 shouldn't bother it at all. NOTE: It will cut your range way down if you use 1.3gHz video with 2.4gHz radio, didn't want to miss lead anyone.
This is listed on the ReadyMadeRC site about the1.3GHz 300mW Transmitter I have.
"Great quality video and no interference from 2.4GHz transmitters, wifi, or cellular!
Typically better performance than 500mW 900MHz transmitters (because of lack of interference). Offers similar range to 2.4GHz 1000mW transmitters"
Plus ReadyMadeRC has a new custom RX's and TX's that have a new Frequency for legal use in the US. Now includes the original 1280MHz, along with the new 1258MHz frequency!
From most of what I have read the 1.3 is a good all around Freq. I have seen ppl fly over 2.6 miles out on a 200mW 1.3gHz.
So I thought I would give it a try. My Futaba want go over a mile. But I have a older Futaba 9c I would like to drop a Dragon Link into.
When it quits Raining I will try it out and see how it does.
This is what my Ground station looks like. I still have got to figure out a way to mount my helical antenna.
Last edited by TaSaJaRa; Jan 03, 2013 at 10:16 PM. Reason: 2.4gHz radio don't work well with 1.3gHz video Tx
New Product xRotor FPV Quad Frame Qrome Multirotor Talk 88 Aug 13, 2012 09:02 AM
Discussion Clear View wing loading Dave K Simulators 3 Jul 09, 2012 05:51 PM
Sold Clear View Flight Simulator $25.00 J.Avant Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 09:15 PM
Discussion 3rd Party Models in Clear View? Forrest Simulators 8 Mar 02, 2012 02:27 PM
