Old Feb 13, 2013, 03:45 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
I guess it depends on how far you run your motor mounts on the arms. Honestly, that amount will make no difference in flight. I would say leave it and it should be just fine.
Qrome is offline Find More Posts by Qrome
Old Feb 13, 2013, 04:37 PM
romans1015 is offline
Find More Posts by romans1015
Winter Sucks!!
romans1015's Avatar
United States, WI, New Berlin
Joined Aug 2002
If you have an X configuration and the X has 90 degree angles,
then those two measurements should be the same.
On my IFrame: AB = 15 1/4" and AC = 14 1/2"
All I would have to do is push each motor mount in 3/8"
to square it all up.
romans1015 is offline Find More Posts by romans1015
Old Feb 13, 2013, 04:41 PM
Winter Sucks!!
romans1015's Avatar
Joined Aug 2002
I wonder if some of you guys could measure your quads and tell me if points
AB and AC on your quads are equal in length from center of motor to center of
motor???
Old Feb 13, 2013, 04:47 PM
Winter Sucks!!
romans1015's Avatar
Joined Aug 2002
Ok, I got my answer!
I guess it really doesn't matter.
As long as AD and BC are equal.
Old Feb 14, 2013, 10:34 PM
Winter Sucks!!
romans1015's Avatar
Joined Aug 2002
Well, here it is with the arms lengthened. Put carbon arms on there also instead
of the wooden ones. I like the carbon much better.....stiffer and straighter.
I also put different motors....went from the Suppo A2212-11 to the HT DT700's
to accommodate the larger 11x4.7 props.
I also bought preflashed ESC's.....highly recommend buying ESC's that come
already flashed if your not sure about how to do it.
Tried flashing the esc's on the first set up and motors ran twitchy
and the esc's were beebing all over the place..
I probably didn't do it right.
This runs very smooth
Now I just have to tune it all up
I'm running it with two 20-30c 1500 batteries using a 2-Pac HD dual battery
system shown here: http://www.rcdude.com/servlet/the-19...Battery/Detail
My only concern is that it weighs 3lbs and hovers at almost 3/4 throttle.
Any thoughts on that?
Randy
Old Feb 14, 2013, 10:50 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Randy
Randy, the setup looks good. I have never used those motors before, but I have seen them used. You really want it to hover at just under 1/2 throttle... about 40 - 50% -- this would give you best performance. When you have to hover at 75% throttle, there is very little room for correction when flying with any speed as you are already too close to the top end.
I am assuming you are running with 2 x 1500mAh 3S packs? So it is basically a 3000mAh system, right?
My xRotor IFrame Quad fully loaded (GoPro Hero2, full FPV gear, OSD, and a 2200mAh 3S pack) weighs 2lbs and 6oz -- Not even 2.5lbs. Why is yours so heave?
Old Feb 15, 2013, 12:12 AM
tonkajeep34 is offline
Find More Posts by tonkajeep34
NTX Helidillos
tonkajeep34's Avatar
USA, TX, McKinney
Joined Sep 2009
I love putting these things together... too bad my CA was all dried out or it'd be glued together. I'm planning on running the stock size as I really like the idea of a very compact fpv quad. Almost glad I ruined my 900mhz CL so I don't have to figure out where to put it.
tonkajeep34 is offline Find More Posts by tonkajeep34
Old Feb 15, 2013, 12:15 AM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Looking good -- I like it nice and compact as well. Fits nice in the car and easy to fly through trees and other small gaps. Nice little tight package.
Old Feb 15, 2013, 12:33 AM
Winter Sucks!!
romans1015's Avatar
Joined Aug 2002
Hmmm? I dont know why it's so heavy but it is really frustrating
Yes, it's basically a 3000mAh system.
I know the motors are 20g more a piece totaling 2.85oz.
3 more inches on each square tubing which would be like adding an extra
12" arm.
I spray painted the frame but that couldn't add any more weight than those
who clear coat theirs.
I dont get it David, I rebuilt this so I could lift more weight for FPV and I did
exactly the opposite....LOL
I should have just asked you exactly what yours was and built mine identical
If this one doesnt work out, I may just do that!
Would you have time to post a picture of yours?
Randy
Old Feb 15, 2013, 12:36 AM
Winter Sucks!!
romans1015's Avatar
Joined Aug 2002
HI Tonkajeep,
Any reason why you used wood for the motor arms and carbon for the frame arms?
Randy
Old Feb 15, 2013, 06:52 AM
NTX Helidillos
USA, TX, McKinney
Joined Sep 2009
Actually the frame arms are Gf with basswood inserts. And it was only due to the fact that I had a leftover piece from the last build that was almost the perfect size.
Old Feb 15, 2013, 04:30 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Randy
Randy, this one is mine. It is also the frame that is in the product page and videos.
Oh, I used clear coat on this one. I don't use colored props on this frame as I never fly it line of site. This is my dedicated FPV rig.
xRotor IFrame Quad Skimming Paradise (H-Quad) (3 min 56 sec)
Old Feb 15, 2013, 06:36 PM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
http://youtu.be/DCOiEiDczkc
that is some good looking props.
onefastxp is offline Find More Posts by onefastxp
Old Feb 23, 2013, 08:05 AM
NTX Helidillos
USA, TX, McKinney
Joined Sep 2009
Hey Qrome and others, how are y'all mounting your battery packs? I liked the paint stick method but just wondering how everyone else is doing it.
Also what's the best place to get those props?
Don't have Fpv gear on it but she flies and has GPS so I'm going to play with that a bit before moving the fpv gear over.
Old Feb 23, 2013, 10:28 AM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
I always just use Velcro between the battery and frame. Straps are optional.
Just place it the best you can to balance it for what ever gear you might have on it.
About the props -- they are really nice but they are $10 each. I took them off for now and are saving them for special occasions. I am actually really liking the stiff carbon filled Gemfan for FPV.
http://blueskyrc.com/index.php?main_...products_id=63
I should be getting more stock in the next week or two. The first batch sold quite fast.
New Product xRotor FPV Quad Frame Qrome Multirotor Talk 88 Aug 13, 2012 10:02 AM
Discussion Clear View wing loading Dave K Simulators 3 Jul 09, 2012 06:51 PM
Sold Clear View Flight Simulator $25.00 J.Avant Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 10:15 PM
Discussion 3rd Party Models in Clear View? Forrest Simulators 8 Mar 02, 2012 03:27 PM
