Old Sep 25, 2012, 02:49 AM
prondel is online now
Find More Posts by prondel
prondel's Avatar
France
Joined Aug 2003
I second Mike on his experience with MKS and S-BEC. I have unregulated Life in my Needle 100, use 6 MKS servos with 6 S-BEC, and I'm very statisfied with them.
I like the idea to have a protection per servo that can save other servos, so the plane, in case of any problem on one servos.
Pierre
prondel is online now Find More Posts by prondel
Old Sep 25, 2012, 02:52 AM
kdt is offline
kdt
Find More Posts by kdt
kdt
kdt's Avatar
Joined Feb 2007
maybe the same as the old model JR
Originally Posted by satinet View Post
I hope the new jr graupner hv servo is good. To be honest the graupner ds3288 had absolutely terrible centering.
I think the graupner ds 3288 is the Euro name for the JR ds388 we had here in North America. The first production model in North America had an issue with centering but it improved with later issues. It seemed worse with the regular voltage model. They were noisy as well.
It would be interesting to know if the new JR Graupner will be the same as the new JR we have ? The new ones are designated 181/189 in Japan. Maybe also in Oz?
kdt is offline Find More Posts by kdt
Old Sep 25, 2012, 03:03 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
I heard they had improved, but I bought some a while after the first lot, which I got when they first came out, and they were just as bad.
Yes they are very noisy as well. Otherwise it was/is a good servo with lots of power and speed and tough gears. The centring/accuracy was just amazingly bad.
satinet is offline Find More Posts by satinet
Old Sep 25, 2012, 03:04 AM
kdt is offline
kdt
kdt
kdt's Avatar
Joined Feb 2007
Lost model to bad servo lead
My last trip to the slope I lost my Pike Giant with to a bad wire harness that shorted and drained my battery. would the S-BEC help with this kind of problem?
I have just purchased the new Spektrum DX18 transmitter that has a module for relaying battery and signal information back to the radio. These functions can be put on an alarm with tone and vibrate in the TX. Nice feature but it is hard to shoehorn another module into an F3F/F3B model.
Pierre
Old Sep 25, 2012, 03:12 AM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
Originally Posted by Tuomo View Post
I am definately not interrested in Hitec as long they have tested by the F3J/B community for one season. ...Or make it two seasons... But I am very interrested in sensible hig voltage 2x Life setup - that is future!
what we need is a willing volunteer!
Old Sep 25, 2012, 04:16 AM
kdt is offline
kdt
kdt
kdt's Avatar
Joined Feb 2007
I think you will like the new ones. When the weather is cold it might take 30 seconds for the servos to warm up before the trims are perfect. I noticed this once when the servos were very cold. No issues with centering any more.
Old Sep 26, 2012, 05:08 AM
Ja9 is offline
Ja9
Find More Posts by Ja9
Ja9
Norway, Rogaland, Tjelta
Joined Dec 2004
Just placed an order for new servos.
Went with JR DS 390HV for fuse and JR DS398HV for wing.
I am also waiting for a new fuselage for my Freestyler, so I will install the servos
afte the F3F season ends.
Ja9 is offline Find More Posts by Ja9
Old Sep 26, 2012, 05:20 AM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
Cool. Two things:
1) I would be interested to hear your thoughts on the servos. Especially if they cured the centring issues
2) Where did you buy the servos in europe?
Tom
Old Sep 26, 2012, 03:18 PM
kdt is offline
kdt
kdt
kdt's Avatar
Joined Feb 2007
JR RDS and conventional servo frames source?
Waiting for the JR RDS servo frames and splines to do the DS 390/398 install in my new Fosa. Can anyone tell me who supplies the ones Jiri is including with his models?
Anyone suggest the best frames with bearing output shafts for JR servos in a conventional install? I have a Needle FDS in the works. Hope there is enough room in the servo bay to fit the larger bearing frame?
Old Sep 26, 2012, 03:29 PM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
The ones that smart model sells are nice.
http://www.smartmodel.com.hk/product...sub_cat_id=297
Old Sep 26, 2012, 04:00 PM
kdt is offline
kdt
kdt
kdt's Avatar
Joined Feb 2007
Nice stuff!
No picture or dimensions of the JR frames at their website. Do you think these will fit in the Needle FDS servo bay? Thuro says he thinks the bearing frames are not needed but the DS best speed for this model is approaching 300mph
Old Sep 26, 2012, 04:06 PM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
Keith,
Here is another option if space is an issue:
http://www.sloperacer.co.uk/_content...earingkits.asp
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Sep 26, 2012, 04:26 PM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
I'm not sure. On the one for the s3150 the screw heads are higher than the servo. Ok near the horn but a problem near the trailing edge.
However the mounting lugs in the jr servos are below the top of the servo case though, IIRC. The 3150 doesn't have wing mounting lugs of course.
I would guess it would be okay then, but you could ask.
The slope racer kit is a bearing and works well.
Old Sep 27, 2012, 05:38 AM
Harri Pihl is online now
Find More Posts by Harri Pihl
Suomi, Lšnsi-Suomi, Uurainen
Joined Jan 2004
Well, so far the Turnigy A55Hs have worked very well for me and now Bluebird has a HV version:
http://www.blue-bird-model.com/en/hi.../bms-a56v.html
Harri Pihl is online now Find More Posts by Harri Pihl
Old Sep 27, 2012, 07:57 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
I have to confess I've had good experiences in general with servos made by both of those makes...
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Sold FS3 RDS Disser+PLANE QUIVER 68"er PRICE DROP Terminator Aircraft - Sailplanes (FS/W) 5 Aug 28, 2012 09:15 PM
For Sale FS3 - RDS - Orange/Blue - $2600 RTF Brand New jgs99v Aircraft - Sailplanes (FS/W) 12 Jun 29, 2012 12:04 AM
Wanted FS3 Incidences Pins mrfski Aircraft - Sailplanes (FS/W) 6 Aug 05, 2011 11:06 AM
New Product JR HighVoltage servos Happy|Harry Electric Heli Talk 6 Oct 28, 2008 12:16 AM
Discussion www.highvoltage-rc.com - WARNING!!!! CHEATERS!!! RickHustle Vendor Talk 3 Jun 09, 2008 03:07 PM
