Old Nov 15, 2001, 08:48 AM
Bleriot is offline
Find More Posts by Bleriot
Bleriot's Avatar
Joined May 2000
How dumb are you?
Hi All well this is how DUMB I am. All summer and early fallI have been carrying a 5.5mm wrench to remove GWS props when it occurs to me this week that the new prop can be used as a wrench to remove the broken prop and the broken one can be used to tighten the new one. DOH Best Regards
Bleriot is offline Find More Posts by Bleriot
Old Nov 15, 2001, 08:54 AM
1987tc is online now
Find More Posts by 1987tc
Come fly with us in Henryetta
United States, OK, Weleetka
Joined Dec 2000
Makes you go hhmmmm.......
Wonder if that was just a happy accident or if that was intended by GWS ? There pretty crafty.......
1987tc is online now Find More Posts by 1987tc
Old Nov 15, 2001, 08:57 AM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
Well, I don't need to carry that wrench anymore. I'd already read of using a broken prop as a wrench, but never put 2 and 2 together.
Thanks Bleriot.
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Nov 15, 2001, 09:47 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
You are not dumb at all. yet, your eyes are sharp and brian is too smart actually!
GWS design products very much different way. Glad to see your understand how GWS works hard.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Nov 15, 2001, 10:32 AM
mattk17 is offline
Find More Posts by mattk17
mattk17's Avatar
Dallas,TX
Joined Jul 2001
Take a broken prop and file down the prop to make it about 3" long. Then use sandpaper to take the sharp edge of the rest of the blade. Now you have a "free" wrench that will take up almost no room in your gear box. I say "free" because unfortunately I have a bunch of them since my GWS 9x7 props broke about every 5-10 flights. I finally got tired of replacing them and switched to the APC slowflyer series. I've logged about 40 flights on one prop with no breakage! I like the 9x6 but 8x6 or even 10x7 might also work.
mattk17 is offline Find More Posts by mattk17
Old Nov 15, 2001, 10:57 AM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Sounds more like genius to me. Thanks Bleriot. I never would have figured that out in a million years.
BC
Basketcase is offline Find More Posts by Basketcase
Old Nov 15, 2001, 11:34 AM
ErnieR is offline
Find More Posts by ErnieR
Haverhill, MA
Joined Jul 2000
dumb
I just use pliers.
ErnieR is offline Find More Posts by ErnieR
Old Nov 15, 2001, 12:01 PM
member73 is offline
Find More Posts by member73
member73's Avatar
Wakefield, MA
Joined Feb 2001
One word, one tool, leatherman.
But I really like the prop idea, why didn't I think that. We're dumb, not you Bleriot.
member73 is offline Find More Posts by member73
Old Nov 15, 2001, 12:53 PM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
I almost feel left out been flying slowflyers a year and not broke one prop yet. But only useing the 10-4.7 I guess they don't break as easy. But the wings that is something else
russ6421 is offline Find More Posts by russ6421
Old Nov 15, 2001, 02:40 PM
Vonbaron is offline
Find More Posts by Vonbaron
Plane hugging cat
Vonbaron's Avatar
Mackay Queensland Australia
Joined Sep 2001
If I did survive to 105.. Nope, wouldn't have guessed that one. I wonder how many other undiscovered tricks like that there are lurking in our flight box?
Vonbaron is offline Find More Posts by Vonbaron
Old Nov 15, 2001, 04:16 PM
fly4fun is offline
Find More Posts by fly4fun
Joined Jun 2001
I Never broken a GWS prop after flying 6 months with my Pico Stick FD. The key to this is FLARE, FLARE on landings. Keep your prop off the Ground.
fly4fun is offline Find More Posts by fly4fun
Reply With Quote  (Disabled)
Old Nov 15, 2001, 04:32 PM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
We wouldn't want anyone to feel left out.
All you have to do to break a prop is switch to the 9x7.
And then make a one-point landing, right on the nose. Sometimes these things happen because of ...aahh... would you believe, the wind or trees!
I know, I know, you'd have to be dumb to fly in wind or into trees.
BC
Old Nov 15, 2001, 05:36 PM
Wile E is offline
Find More Posts by Wile E
Wile E's Avatar
Ferndale, MI
Joined Feb 2000
How about flying between the trees, trying to catch it and hitting it with a house??
Wile E is offline Find More Posts by Wile E
Old Nov 15, 2001, 06:06 PM
KLH is offline
KLH
Find More Posts by KLH
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
Bleriot
I think we're the slow ones. I've got two broken 9x7 on the work bench. I'm in the process of adding a counter weight by the hub on one of them and making it a single blade prop kind of like the ones I used years ago on some CL planes. Probably not worth it on something that turns as slow these little motors, but it will be fun to try. The other one is going back in the field box and is now going to be called " prop wrench ".
Kern
KLH is offline Find More Posts by KLH
Old Nov 15, 2001, 06:13 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
GWS new prop EP9070 already modified the root stronger! may be arrivial USA ready?
But I have to start to worry about: Don't fly near the kids, pls.
My fingers and hands has a lot of propepplers cut records in the past 31 years since I strated fool arround with model engines. But no fingers cut away still 10!
However, still much lucky than other friend in Taiwan, lost a lot of his fingers cut by Ultralight Aircraft ( Rotex 503, 46HPs.)
I always have to remain you: SAFTY is important to keep RC modellings popular.
Just how green are you? dklassen Electric Plane Talk 55 Feb 18, 2004 09:27 PM
How high are you lauching??? AustinTatious Hand Launch 10 Nov 27, 2003 12:26 AM
A10 Finished! - Here's my Camo Job - How if/are you painting yours? mrebman Parkflyers 27 May 01, 2003 11:13 PM
How hard are you pushing your, RZ400, 350, 300, heli, 2500 motor? JFGrn Power Systems 15 May 01, 2003 04:42 PM
So. How Smart Are You? DaveSawers Life, The Universe, and Politics 30 May 17, 2002 06:58 AM
