United Kingdom, England, Bristol
Joined Aug 2011
3D Trainer - Parkmaster 3D, Acromaster, RC Factory Yak, HK Yak EPP 3D, OR?????
I want to get into the wonderful world of 3D acrobatics, however I need a suitable airframe that I can practice on and withstand the bumps, scrapes and smashes from the inevitable accidents. I'd also like the airframe to be capable of being converted to do pattern acrobatics, so I can improve that too if I find 3D isn't for me.
What I've whittled it down to is:
The Parkmaster is my top choice so far. Very expensive, but I've always found Multiplex stuff to be excellent quality and always fly well. The RC Factory Yak looks good, and is popular down our field, but requires a fair bit of assembly and its motor mount seems to be a big weakness. Unless it flies really well, I can't be bothered with the HK Yak as it'd take 2-3 weeks to get here. What would be the best to go for to learn on? Something else that would be recommend (and that I can easily get here in the UK)? Thanks! Cheers, Si. |
Joined Aug 2011
Forgot to add, I've also seen the Telink Yak. I know nothing about it, but seen a couple of reviews on here that say its a superb flier?
These lumps of cut foam seem all very expensive for what you get! I assume you get what you pay for with these? I.e. Spending more will get you a much better aircraft as the cost is from developing through a lot of R&D. Cheers, Si. |
Joined Aug 2011
Thanks for the response, its really quite helpful. The Multiplex is by far the most expensive, and probably not the best to bash and break a couple of times.
Just looking at the Crack Yak (I assume RC Factory make it for Twisted Hobbies and thus the same?), and noticed its quite cheap (compared to the others) - but also smaller. So possibly looking at the Crack Yak, the Flash or the RS352. I'm guessing the Flash and RS352 would be better fliers in wind and easier to learn on, etc due to them being bigger? However the Crack Yak is almost 60% cheaper than the RS352 and half the price of the Multiplex. So for the same price as I was spending, I could effectively get 2 airframes. Finally I've also seen the 800mm Sbach 342 on offer for ~$60 - which is tempting, especially if it flies well. So is it better to go for a bigger airframe? Or is a smaller just as good and it copes just as well (in wind, etc), but has less mass in an accident (thus less damage)? I really don't want to get the HK Yak, as even though I'm a HK addict, I can't be bothered to wait for it to get to me when I can get the others next day. Also after postage, the HK Yak from Hong Kong is the same price as what I can get the Crack Yak in the UK. I guess the Crack Yak > HK Yak? Too many choices (and not enough knowledge)! I really only want to buy one aircraft that will be the best out of the big selection, rather than buying and going through several before finding out there is one better than I've just got. Cheers, Si. |
I agree the power combo is fine, there isn't any need for precise servos as the whole plane flexes a bit, high quality precise servos would be a complete waste of money.
It doesn't have proper airfoils, its a profile foamy. It is not good at all for precision aerobatics but you said you wanted to learn 3D. For 3D it's a good trainer, i.e. it will help train your thumbs and brain for 3D. It does not however transfer to larger heavier airframes. Larger airframes need more speed and momentum to fly, the Crack Yak is a totally slow floater, which is why you an learn, it slows everything down for you. |
| Thread Tools | |
| Discussion HK Yak 55 3D/EPP plane FPV | hazchem88 | Video Piloting (FPV/RPV) | 9 | Jul 23, 2012 03:27 PM |
| Question multiplex parkmaster 3D or acromaster? | AnbuPunk | 3D Foamies | 7 | Aug 04, 2011 09:42 PM |
| Discussion Parkmaster 3D Or Flash EPP? | Hansm | 3D Foamies | 19 | Feb 01, 2010 08:18 AM |
| Discussion Flash EPP or Parkmaster 3d? | Hansm | 3D Flying | 0 | Jan 25, 2010 12:53 PM |
| Discussion Parkmaster or Rc-Factory Yak? | somt1033 | 3D Foamies | 9 | Sep 12, 2009 04:20 PM |
