Old Nov 15, 2001, 08:20 AM
xjohnx is offline
Find More Posts by xjohnx
Hastings, NE
Joined Oct 2000
Hobby Lobby Miss 2 Question
I just got a HL Miss 2. I am concerned with the elevator. It has a lot of up movement, but barely 3/8 inch of down movement. Appears that it was not fully deflected down while attaching it to the h-stab with the covering hinge. Is this normal for the Miss 2, or did I get a bad one.
Thanks.
xjohnx is offline Find More Posts by xjohnx
Old Nov 15, 2001, 08:51 AM
Tim Seidenstricker is offline
Find More Posts by Tim Seidenstricker
Boise, ID 83703
Joined May 2001
Miss 2
I have a Miss Moravia, but exactly the same plane except low wing instead of high. It sounds just a bit tight, but after some examination on mine I don't use more than 3/8" deflection for flying. It is a very responsive plane to just a little bit of control. You could cut it loose and use hinges or tape it, but I would sure try it as is first. The material you have attached is much stronger than tape will ever be.
Tim Seidenstricker is offline Find More Posts by Tim Seidenstricker
Old Nov 15, 2001, 05:42 PM
Wile E is offline
Find More Posts by Wile E
Wile E's Avatar
Ferndale, MI
Joined Feb 2000
Miss 2
Yours should fly fine. Just keep adequate UP travel to flare those landings.
Wile E is offline Find More Posts by Wile E
Old Nov 15, 2001, 06:10 PM
Bobski is offline
Find More Posts by Bobski
Merlin, Oregon 97532 USA
Joined May 2001
Miss 2
Hi All. Hey Wile E, what floats are you using on your Miss 2? I love float flying and that Miss 2 sure looks good up on floats. Thanks, Bob
Bobski is offline Find More Posts by Bobski
Old Nov 15, 2001, 10:34 PM
xjohnx is offline
Hastings, NE
Joined Oct 2000
Thanks for the replys. Guess as long as I don't get it tail heavy it will probably be ok. It may also loosen up with some use. I have plenty of up-elevator movement. It is just very tight on the down-elevator. Nice looking setup Wile E.
Old Nov 16, 2001, 05:48 PM
dano287 is offline
Find More Posts by dano287
Kirkland Wa. usa
Joined Jul 2001
elevator
Ive had two Miss2s and both were a little tight. The first one I cut apart and used tape..worked fine, but after flying it ..(and later smashing it to bits), I left the second Miss2 alone you dont need that much throw, its very sentitive.....
dano287 is offline Find More Posts by dano287
Old Nov 16, 2001, 09:40 PM
cruzomatic is offline
Find More Posts by cruzomatic
San Antonio, Texas USA
Joined Feb 2001
John, just sent you an email about the elevator throws on my miss2.
AC
cruzomatic is offline Find More Posts by cruzomatic
Old Nov 23, 2001, 02:02 AM
Marksl is offline
Find More Posts by Marksl
Tucson
Joined Nov 2001
Tim,
How do you like your Miss Moravia? I haven't built mine yet, wondered about needing to gear it.
Mark
Marksl is offline Find More Posts by Marksl
Wanted Hobby Lobby Miss 2 Wing BD Flyer Aircraft - Electric - Airplanes (FS/W) 7 Aug 08, 2007 05:44 PM
Wanted Hobby Lobby Miss 2 WING ONLY BD Flyer Aircraft - Electric - Airplanes (FS/W) 0 Jul 30, 2007 12:24 AM
Discussion Hobby Lobby Miss 2 advertisement efinkg Vendor Talk 5 Jun 05, 2007 12:16 AM
Hobby Lobby Miss 2 Pat Daily Parkflyers 20 May 05, 2002 03:10 PM
Hobby Lobby Lightweight Wheel Question janitor13 Parkflyers 9 Jan 21, 2002 01:12 PM
