Old Oct 21, 2012, 09:23 PM
denial15 is online now
Find More Posts by denial15
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
That is awesome. I want to see that one fly. Keep us posted on how it does.
denial15 is online now Find More Posts by denial15
Old Oct 21, 2012, 10:30 PM
czechyour6 is offline
Find More Posts by czechyour6
überprüfen Sie Ihre sechs
czechyour6's Avatar
Central Utah
Joined Feb 2005
have we fired up mini me yet? way cool
czechyour6 is offline Find More Posts by czechyour6
Old Oct 22, 2012, 06:45 AM
jjisme is offline
Find More Posts by jjisme
jjisme's Avatar
Joined Sep 2012
Pix are after the maiden flight test, you can see the kinks on the nose..... It flew a gentle glide to the ground about 15 times just couldn't get it to climb out of ground effect. It acts just like when Dan helped me get the big F22 flying at swarm we had a 8x4 prop and it just wouldn't get going, Dan put a 8x6 on it and presto... Off it went. the mini me has a 6x4 and is acting the same way it basically glides but won't fly??? Parts were scammed from an old CX2 (mini servos, 7.4v 800ma battery & motor) Had an old speed control & mixer from the Zagi & an orange RX . I'll pick up a prop and try it again . Stay Tuned
jjisme is offline Find More Posts by jjisme
Old Oct 22, 2012, 07:01 AM
jjisme is offline
jjisme's Avatar
Joined Sep 2012
I'll get with you later this week on our radio deal, may need your expertise on the next Mini Me flight test.... It's pretty crash proof so far though (Good thing for this yank ahhh???
Old Oct 22, 2012, 10:00 AM
swede
denial15's Avatar
Joined Aug 2005
Try taking one of the 7x6 props and trimming it down about 1/2 inch on each blade.
Old Oct 24, 2012, 02:16 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
F22Fun.MP4 (4 min 51 sec)
jetpackninja is offline Find More Posts by jetpackninja
Old Oct 28, 2012, 05:45 PM
ttabbal is online now
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
Alright... I'm over thinking cg.
About 1 inch ahead of the front of the servos? I've got everything but the battery installed, and experimenting with the battery shows I can get cg there. Just checking before I set it up.
Nice full throws on the radio, elevons flap nice and smooth. Hopefully I'll get this one flying nice like the first few flights of the last one.
ttabbal is online now Find More Posts by ttabbal
Old Oct 28, 2012, 08:24 PM
swede
denial15's Avatar
Joined Aug 2005
I measured the CG on mine about 8 and a half to 9 inches back for the leading edge of the main wing near the fuse.
Old Oct 28, 2012, 08:31 PM
ttabbal's Avatar
Joined Jan 2012
Thanks! I'll aim for that as well then. Just wanted to make sure I get the obvious stuff right.
Old Oct 29, 2012, 11:21 AM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
BTW- Kevin (Lee's) Brother flew his around for a couple of minutes with a slightly bigger motor.
(2826 1900KV)
That thing was flying great, 'til it got taken out by a reaper...
Old Nov 01, 2012, 02:09 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Dan-
What servos are you using on your F22
I find it odd that some folks are having so much trouble getting the F22 to fly well.
I'm wondering if the MG90 servos may not have enough torque for this application and the large throws that it needs...
I'm using PowerHD 1171 servos.
They look to be a direct copy of the HS82MG servos that were originally recommended for the Assassin.
I use them as a drop in replacement for the 82MG.
http://www.valuehobby.com/radio-syst...hd-1711mg.html
Great servo and the cost is much easier to swallow than the HiTec units
Old Nov 01, 2012, 03:39 PM
swede
denial15's Avatar
Joined Aug 2005
The first one I made had HS55 knock off servos. They don't need a lot. I've flown it with the mg90's. I think they are my favorite for this plane. I sold that one RTF to someone. He's still flying it.
The one I have now has MG?? I can't remember exactly.
My guess why some are having problems is the throws aren't high enough. I built one with longer control horns and not as much throw. It flew lousy. I drilled holes closer to the wing and increased the amount of throw and it was a totally different plane.
The proper amount of throw for this looks unnatural. I keep mine at 100% travel. I think the natural tendency is to want to tone them down. Not a good idea.
Old Nov 01, 2012, 04:05 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Yeah- I actually turn the throw up to 125% in the radio settings.
If they fly fine with the blue 9 gram generic servos then the MG90S should work fine...
Just thinkin out loud...
Old Nov 01, 2012, 04:09 PM
swede
denial15's Avatar
Joined Aug 2005
I need to meet up with Ryan and take a look at his. I know he was having problems. It's going to be something simple, and probably obvious to those of us that have flown this.
Old Nov 01, 2012, 04:25 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Yeah- Tell him to take the GoPro off of the nose
Sold TX LPU: Twin 55mm F-14, Hopped-Up F-22 w/ alloy fan Roswalt Aircraft - Electric - Jets (FS/W) 7 Sep 19, 2012 05:09 PM
Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. FoamJunkE Aircraft - Electric - Jets (FS/W) 3 May 09, 2012 12:00 PM
Sold F-22 and F-20 Give away Prices (AZ) toxic-trip Aircraft - Electric - Jets (FS/W) 11 Apr 03, 2012 05:09 AM
Sold F-20 and F-22 toxic-trip Aircraft - Electric - Jets (FS/W) 4 Mar 06, 2012 11:10 AM
Discussion F-22 coroplast plan wanted frankyfly SPAD - Simple Plastic Airplane Designs 11 Oct 18, 2007 01:09 PM
