Old Sep 23, 2012, 06:14 PM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, CA, Anaheim
Joined Aug 2005
Coroplast F-22
Here is a thread to discuss the coroplast F-22. As far as I know, I'm the first to build this out of coroplast. (Corrugated Plastic, or plastic cardboard). I wish I could say I thought of the original design. But I only made it better for combat. The overall design is the same, but there are some fundamental differences
The original foam design is supposed to be made out of Depron. It is much lighter, use as a smaller power system, and flies and looks great. It requires carbon fiber reinforcement. It is a great design, but I'm too lazy and cheap to build that type of plane for combat.
The coroplast design is a very simple build. It is heavier than the foam design, uses a bigger power system, and requires little or no reinforcement. It is a perfect alternative to wings for combat. The best part for me is it's very inexpensive.
Feel free to add your $.02, photos, thoughts, ideas, and comments.
edit:
Okay, it looks like I need to do a little updating and clarification. Up to about post #105, the F-22's were made from a solid orange coroplast. It was a bit heavier, and not as rigid as the newest ones. In reading the thread, it appears most of the issues were related to the orange ones.
After about post 105ish, I re-tooled the plane and started using some better coroplast. The result is a little bit smaller (than the orange ones) F-22, and more rigid. Ive spent several hours getting the currnt model where it is now.
Keep in mind, this is not your traditional rc plane. It is a beast, and will not be bothered as much if something isnt exact. It will fly great in about all circumstances, but it is still not for beginners. I need to dig through and post some pictures of the trashed planes that I have repaired and still flown without any problems.
denial15 is offline Find More Posts by denial15
Old Sep 23, 2012, 06:34 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Hi Dan
I did a short article over on the Flitetest forum for the the coroplast F-22.
I'd like to reference this thread in the article.
http://flitetest.com/articles/F22_Co...ld_Ninja_Style
The plane in the picture is setup with:
fc2812 motor (hobbyking)
7x6 apc style prop (hobbyking)
25-30 esc (hobbyking)
1300mah 3s battery (hobbyking)
power hd 1711mg servos (valuehobby)
Orange 6ch receiver (hobbyking)
.055 control wire and two Dubro EZ connectors (LHS)
And here is the pic of my latest one (post sWARm version) very little departure from the original. I did add the two coro pieces on top to try to keep the rods from flexing and my motor mount is made from a paint stick from Home Depot.
jetpackninja is offline Find More Posts by jetpackninja
Old Sep 23, 2012, 06:45 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
The Home Depot paint stick motor mount is another excellent idea. Especially along the theme of inexpensive.
Old Sep 23, 2012, 06:50 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Just read your article. Very nice summary. Feel free to link this thread to it so they can get applicable information.
Old Sep 23, 2012, 06:53 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
We need to get some good videos of these things in flight. I'm pretty limited to my cell phone
Old Sep 23, 2012, 07:49 PM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
We should talk Dan into making more types.. Maybe a MIG, F15....
ttabbal is offline Find More Posts by ttabbal
Old Sep 23, 2012, 08:09 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Funny you should mention that. I saw a Mig thread not too long ago. That thought did cross mind today.
Old Sep 23, 2012, 08:20 PM
ttabbal is offline
ttabbal's Avatar
Joined Jan 2012
I think it would be fun to have a few different types flying around at the same time. Maybe even in combat. Make them out of campaign signs next time...
Old Sep 23, 2012, 08:50 PM
czechyour6 is offline
Find More Posts by czechyour6
überprüfen Sie Ihre sechs
czechyour6's Avatar
Central Utah
Joined Feb 2005
Guess ill have to get mine going, got HS65MGs, just need red motor and possibly esc? I may try to use carbon fiber rods on servos
czechyour6 is offline Find More Posts by czechyour6
Old Sep 23, 2012, 08:54 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
CF rods should work if you can afford that kind of stuff. I have a 25 amp esc I'll trade you for a 5S charger if you want.
Old Sep 23, 2012, 09:21 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
czeckyour6- What kind of flying do you intend to do? If you are going to do your best Dan impersonation and fly it in combat I wouldn't go with the carbon fiber rods. If you are just going to fly it around and use it kinda like a trainer, I'm sure the carbon fiber control rods will do a great job of eliminating flex.
By the same token the HS65MG is a great servo but very expensive. if you are building a basher take a look at these:
http://www.valuehobby.com/radio-syst...hd-1711mg.html
I use these in my larger combat planes and for the F22. I use them as a drop in replacement for the HS82MG, every bit as good but a LOT cheaper.
Old Sep 23, 2012, 10:19 PM
czechyour6's Avatar
Central Utah
Joined Feb 2005
ive already got a few hs65s and saw earlier photo where it looked like metal rods got bent when they took a hit, prob wont do serious combat with it but who knows maybe ill wrap everything in kevlar fibers
Old Sep 24, 2012, 05:49 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Keeping with the theme of inexpensive:
Dan have you tried using marker flag wire?
Old Sep 24, 2012, 06:05 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
I haven't, but I know someone did. And they seemed to work acceptably well. This will fly with floppy wires, but it will fly a lot better with solid control rods much better. I was flying around on Saturday with really floppy wires.
Old Sep 25, 2012, 08:25 AM
Plane Insane RC is offline
Find More Posts by Plane Insane RC
BUZZ KILL
Plane Insane RC's Avatar
Utah
Joined Aug 2010
Any advice for the first toss? I have mine built and ready to go. I’m wondering about reflex and junk like that. Do I need any? Anything else that will help with the first flights?
I went super cheap with plastic gear servos from PlaneInsaneRC (shameless plug) and the 2812 Proportion kit which includes the 2812 motor, prop, esc, bullet connectors and prop adapter.
For push rods, you can always use bike wheel spokes. Find a junker on KSL for a couple bucks and your set.
Ryan
Plane Insane RC is offline Find More Posts by Plane Insane RC
Sold TX LPU: Twin 55mm F-14, Hopped-Up F-22 w/ alloy fan Roswalt Aircraft - Electric - Jets (FS/W) 7 Sep 19, 2012 05:09 PM
Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. FoamJunkE Aircraft - Electric - Jets (FS/W) 3 May 09, 2012 12:00 PM
Sold F-22 and F-20 Give away Prices (AZ) toxic-trip Aircraft - Electric - Jets (FS/W) 11 Apr 03, 2012 05:09 AM
Sold F-20 and F-22 toxic-trip Aircraft - Electric - Jets (FS/W) 4 Mar 06, 2012 11:10 AM
Discussion F-22 coroplast plan wanted frankyfly SPAD - Simple Plastic Airplane Designs 11 Oct 18, 2007 01:09 PM
