Old Oct 13, 2012, 11:56 AM
Bryan's Flyin is offline
Find More Posts by Bryan's Flyin
United States, MO
Joined Apr 2009
Originally Posted by Dialfonzo View Post
I am not sure if i should have a hole it the top plate and add a protect plate over or go for the same but under...
I would go under myself..
The distance between the two center plates is only 0.75" so.. a bit hard to fit any normal 70mm round board.
The thickness measurement on the quattro is 11.5 mm. I am using it on a Q450 frame and the Bumble Bee ST 550 between the plates to protect it.
Bryan's Flyin is offline Find More Posts by Bryan's Flyin
Old Oct 13, 2012, 04:58 PM
Dialfonzo is online now
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Here is my "Easy" fix...
I can't wait to have my ESC to know if they fit on that adaptor plate.. would be nice..
Looking where to put the NAZA things...
Dialfonzo is online now Find More Posts by Dialfonzo
Old Oct 14, 2012, 01:34 AM
MTHead4u is offline
Find More Posts by MTHead4u
Having fun again!!
MTHead4u's Avatar
United States, AZ, Queen Creek
Joined Aug 2012
Wow, fitting a Naza in there without the spacers will be perfect, They measure in at .73" I picked up another Naza/GPS yesterday for this, couldn't pass up the sweet deal.
Depending on shielding from the GroPro (still researching this) I was thinking GPS up front and FPV out the back. I haven't even thought about ESC's yet, was planning on just getting the 30A DJI ones for ease due to running the Naza. Wonder if they will stack on both sides of the Naza, at 1.0" wide they are to big to stand on their sides.
How much room is left on either side of the Naza before you run out of frame? Only need a total of 2.0" (1.0" per side) and they can be stacked together 2 per side. That could also make for some clean wiring if they were 180º of each other so the motor connections plugged right in coming out of the booms. Of course then I'd have to deal with power distro.
Definitely no hole in the top, it looks to good all sleek and clean to have anything protruding from the top. I'd take a lower plate though, with no extra holes in the frame. It would be a good place for a power distro board or the Quattro if the spacers were tall enough.
I can still work with what you have..lol
MTHead4u is offline Find More Posts by MTHead4u
Old Oct 14, 2012, 06:43 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Can you give me the square size they are..?
Old Oct 14, 2012, 11:36 AM
United States, MO
Joined Apr 2009
Old Oct 14, 2012, 01:14 PM
rmorhan is offline
Find More Posts by rmorhan
rmorhan's Avatar
wasaga beach ont canada
Joined Jan 2004
eric, nice install on the naza gear but you might want to move that vu so it can be seen in the air. on your dji spider conversion frame mines tucked right between one back arm & the plates facing the back of the quad. it.s real handy to be able tell what mode your in plus see the low voltage warnings in flight. i,d be interested to hear what gains you settle on as well....thanks..rob m
rmorhan is offline Find More Posts by rmorhan
Old Oct 14, 2012, 01:48 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes I was thinkingof it.
That will be my first dji ...
Old Oct 14, 2012, 03:10 PM
MTHead4u is offline
Having fun again!!
MTHead4u's Avatar
Joined Aug 2012
If you mean the DJI 30A ESC's, they are:
2.50" long
1.05" wide
.30" height/ thick
Wasn't sure who you were asking... lol
Old Oct 14, 2012, 11:30 PM
phover is offline
Find More Posts by phover
phover's Avatar
Canada, QC, Joliette
Joined Sep 2005
Super de belle job! Si tu as besoins de testeur, fais moi signe Quoique ça ne doit pas être les offres qui manquent
Cheers
Martin
phover is offline Find More Posts by phover
Old Oct 15, 2012, 05:51 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Cheers
Martin
Salut Martin,
Merci beaucoup, je l'aime moi aussi.
Je vais faire la modification pour mettre la plaque de GoPro (damper) sur le mien aussi.
Pour les tests, je peux pas me permettre d'en envoyé car ca me coute trop chers pour le moment...
J'ai deja envoyé un kit a Tahiti et j'attend qu'il arrive.
Tu fais quel genre de vol.. ?
Eric Nantel
info@dialfonzo-copter.com
Old Oct 15, 2012, 09:09 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Here is the 4in1 ESC i have myself
Old Oct 19, 2012, 01:15 PM
MTHead4u is offline
Having fun again!!
MTHead4u's Avatar
Joined Aug 2012
Now that will make for a very clean installation.
After seeing your boom blocks in red, I just had to order a set. It's always nice to have so many options.
Keep up the good work Eric!
Old Oct 19, 2012, 01:31 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
HaHa... Nice :-)
Old Oct 25, 2012, 10:52 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
I want this frame
tech69x is offline Find More Posts by tech69x
Old Oct 26, 2012, 03:40 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I receive my prop this week.
Some 11" Gemfan in Plastic and CF..
Those where buy from danphillips here on rcgroups.
His Website www.DiyQuadCopters.com
Discussion DiaLFonZo-Copter - DJI SpyderQuad Upgrade Dialfonzo Multirotor Talk 502 Aug 05, 2014 08:53 AM
New Product DiaLFonZo-Copter Boom Block Dialfonzo Multirotor Talk 88 Mar 21, 2014 05:34 AM
New Product DiaLFonZo-Copter - MicroTrinity Quad Dialfonzo Multirotor Talk 6 Jul 09, 2012 08:26 PM
Discussion FPV plate Soft mounted - Luis & DiaLFonZo-Copter Dialfonzo Multirotor Talk 5 Jan 05, 2012 12:04 PM
