This thread is privately moderated by polyfractal, who may elect to delete unwanted replies.
Old Sep 23, 2012, 09:37 AM
polyfractal is offline
Find More Posts by polyfractal
polyfractal's Avatar
United States, SC, Charleston
Joined Jun 2012
RC Newbie with a Sky Surfer
The day has finally arrived: my Sky Surfer has shown up in the mail. I've been reading and dreaming about RC planes for months now. I finally pulled the trigger and purchased my gear...but it was on backorder.
Fast-forward a month and everything finally ships. I felt like a kid on Christmas, unwrapping all the gear. I also ordered a bunch of FPV gear, but it isn't allowed near my plane until I can fly it successfully.
My kitw as an RTF Sky Surfer. While technically ready to fly, I wanted to add some of the modifications that are often suggested. So, two modifications to get things started:
  • Hooks for rubber-bands on the wings
  • DuBro control horn replacements
Rubber band mod went smoothly. Hooks were attached with CA super glue and feels rock solid.
DuBro control horn replacement...not so smooth. I removed the old horns and glued the new ones into place. Then I read the directions and realized that these DuBro horns have little plastic plates that go on the opposite side of the wing, held together with pins.
Whoops. I frantically pushed the pins through and screwed them in. Luckily, I glued everything with Gorilla Glue so it was still curing. Unfortunately, the horns are now bolted and glued. If I ever have to take them off, it is going to be hell.
The second problem relates to the pin that holds the control rod/wire for the rudder and elevator. Apparently the holes in the DuBro horns are smaller than the stock horns, so the pin does not rotate freely (or at all). I don't have a drill so I couldn't drill the hole out. Twenty minutes of trying to enlarge the hole with a variety of tools (screwdriver, sandpaper, knife) was largely unsuccessful.
I opted to just bend the control wire, similar to the ailerons. Not a great solution and I'll probably have to fix them later.
polyfractal is offline Find More Posts by polyfractal
Site Sponsor
Old Sep 23, 2012, 09:59 AM
Barney Boy is offline
Find More Posts by Barney Boy
into the wild blue yonder
Barney Boy's Avatar
United States, OR, Dundee
Joined Dec 2010
Welcome to the RC world, looks like you got a nice starter plane. When you first fly her take it up high enough, so you have time to recover from any mishaps on the sticks. Don't try any stupid stuff at first, just get to know your plane, fly it in a nice oval and try to keep it leval. After that you can do some loops and rolls.good luck I hope you have succes.
Shawn Barney
Evergreen Aero Modelers
McMinville Aircraft Modelers
Barney Boy is offline Find More Posts by Barney Boy
Old Sep 23, 2012, 03:49 PM
Joined Jun 2012
Shawn Barney
Thanks! Unfortunately, I took it out yesterday before posting this blog and managed to smash it up pretty good. Luckily the damage was repairable with some glue and tape.
Just took it out flying again and kept your advice in mind...much better! The extra height really helped give time to recover from mistakes. I apparently have a lot of tuning to do, the plane kept trying to bank to the right. I managed to compensate a bit by trimming the ailerons waaaay to one side, but clearly something is not setup correctly on the plane.
Flying is completely awesome, I'm hooked. Nerve wracking for sure, but really fun!
Site Sponsor
Discussion Sky Surfer plane help with ESC I think videorov Electric Plane Talk 2 Jul 07, 2012 12:13 PM
Build Log Sky surfer, newbie FPV build Redmist FPV Talk 19 Sep 04, 2011 03:41 PM
Question "Sky Surfer" RC Model Paraplane Shandolyn Parkflyers 13 Apr 17, 2006 11:29 AM
new Wal-Mart RC plane - sky (not air) surfer... tnkenyon Parkflyers 85 Jan 15, 2004 01:14 PM
