Old Nov 09, 2012, 11:06 AM
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
Trevorh, check out a common height adjustable ironing board for a field bench. Works well for this old coot....
art (72, 5 way bypass, both hips replaced, RA, etc.)
lindart is offline Find More Posts by lindart
Old Nov 11, 2012, 03:32 PM
DUNDAS CANADA
Joined Feb 2006
Trevorh.
In my model, the batteries are sitting between F3 and F4 but I have room to move them further forward between F2 and F3. Adding 1” to 2” to the nose should not effect the flight characteristics.
LADDIE is offline Find More Posts by LADDIE
Old Nov 11, 2012, 03:58 PM
Steve Merrill's Avatar
USA, IL, St Charles
Joined Nov 2002
Always wanted to build this plane.
Steve Merrill is offline Find More Posts by Steve Merrill
Old Nov 12, 2012, 03:05 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Art: I have seen people using ironing boards at the field - I agree they do work well with a model stand on top. However they are a bit narrow for putting Shock Flyer models on at indoor meets. My half pasting table worked out okay so I'll stick with that for now. I just hope I manage to find the other half when I next come to do some paperhanging!
Laddie, thanks for that. Does your hatch extend back to F4 or did you stop it at F3 to avoid weakening the fuselage structure?
Steve, Well, what's stopping you
Trevorh is offline Find More Posts by Trevorh
Old Nov 12, 2012, 04:56 AM
DUNDAS CANADA
Joined Feb 2006
There is no hatch on my model. I have to remove the wing to change the battery which is no problem with one bolt holding the wing.
Old Nov 12, 2012, 10:06 AM
USA, IL, St Charles
Joined Nov 2002
Too many other projects in the que right now
But my 2 cents, from what I have read so far, Change the location of the aileron servos. You are asking for trouble with your set up, plus putting weight out there may make this plane unstable.
Now I will shut up and go back to watching
Old Nov 21, 2012, 06:00 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
The formers are now glued in. The dry fit felt reasonably secure so I just removed the formers one at a time and glued them back in place. As usual, in spite of eyeing it all up several times, re-examinination the morning after showed a few little misalignments.
I'll try to sort out the wing fixing next - I find this easier to do before the top of the fuselage is sheeted in so you can see how it's all fitting together.
Old Nov 21, 2012, 07:38 AM
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
beautiful work as always Trevor!
Getting interesting now.
Nick
nickchud is offline Find More Posts by nickchud
Old Nov 21, 2012, 08:47 AM
USA, IL, St Charles
Joined Nov 2002
Very nice! I can see how it gets confusing building this, is the wing upside down in the first picture? Yes, I believe it is...
Old Nov 21, 2012, 09:18 AM
nickchud's Avatar
Market Harborough
Joined Apr 2006
Upside down and back to front!
Old Nov 21, 2012, 09:22 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Spoken like a true canard aficionado!
Old Nov 21, 2012, 10:28 AM
nickchud's Avatar
Market Harborough
Joined Apr 2006
That reminds me, do you know why this plane was called an Ascender?
Old Nov 21, 2012, 11:24 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Would I be right in thinking that the explanation works better in US English than in British English?
Old Nov 21, 2012, 01:52 PM
nickchud's Avatar
Market Harborough
Joined Apr 2006
You guessed it!
I might have to build one of those... I can feel it coming on.
Build Log Maxford Spad 70 inch electric build log jasonak Electric Warbirds 1 Aug 03, 2012 10:28 PM
Discussion electric Design Build and Fly competition dards Electric Plane Talk 0 Jun 14, 2012 09:27 PM
