Old Sep 25, 2012, 03:24 PM
Trevorh is online now
Find More Posts by Trevorh
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
I like that idea! Particularly as I have both 0.4 and 0.8mm ply in stock
Trevorh is online now Find More Posts by Trevorh
Old Sep 25, 2012, 04:02 PM
LADDIE is offline
Find More Posts by LADDIE
DUNDAS CANADA
Joined Feb 2006
There is no difference in the dimensions between original glow version of Aquabird and the electric version. Both versions had all balsa fuselage and the foam wing. All flying weight of my electric model is 6Lbs-10oz.
I am little bit in dark as far as the construction of the balsa wing published in the RCMW. I haven seen the plans so it is little bit hard to advice.
LADDIE is offline Find More Posts by LADDIE
Old Sep 25, 2012, 04:27 PM
pentaxman is offline
Find More Posts by pentaxman
pentaxman's Avatar
Braintree, Essex, UK
I thought that might appeal to the engineer in you
pentaxman is offline Find More Posts by pentaxman
Old Sep 26, 2012, 10:15 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
My immediate reaction when seeing the plan for the wing was that it had been drawn specifically to show a built-up option, but probably nobody had ever built it. Funnily enough, I'm quite reassured to hear that you had nothing to do with it - I'm no longer worried that I will be turning my back on years of design experience by going my own way!
By way of illustration, here are a couple of photos of the central wing joint. To me it looks like somebody has just drawn in two dihedral braces, then put a note on to say fill the gaps with scrap. Not really what I would call a design.
Old Sep 26, 2012, 10:25 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Having cut out five rib pairs (20 rib halves), I felt the need for a break and also wanted to check that my rib/spar concept would actually go together.
When I offered up the first rib half, it looked alarmingly skinny. However, the ribs are pretty closely spaced so, once the rear sub spar is in place supporting the aft portions of the ribs, I think it will be strong enough.
Whichever way you come at this wing though, it seems that every joint and notch has to be cut at an angle so it's not something to be rushed.
Old Sep 26, 2012, 04:16 PM
LADDIE is offline
DUNDAS CANADA
Joined Feb 2006
Looking at the drawing, solution shown for joining two halves will work just fine. Probably, you can omit D2 plywood brace and the balsa fill in the back. On top of that, when both halves of the wing are joined, between ribs R3, cover top and bottom of the sheeting with the fibreglass.
Old Sep 28, 2012, 11:17 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Thanks Laddie, the option of glassing the central joint is a good one to bear in mind as I contemplate the options.
Meanwhile, the first week's work is summarised by one photo. Next step will be a dry assembly to see if everything lines up and to sort out the rear spar detail.
Old Sep 28, 2012, 02:29 PM
Sopwith Mike is online now
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
Hmmm...I wonder if there is a laser-cut set?
Sopwith Mike is online now Find More Posts by Sopwith Mike
Old Sep 28, 2012, 03:35 PM
eye4wings is offline
Find More Posts by eye4wings
...design-build-fly-publish...
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Well Mike, I know Traplet's intention is to offer laser cut sets for all the plans they offer eventually, but it seems to be quite a long way off fulfillment just now!
I suspect that since even those that are on CAD haven't been set up yet, paper drawn plan types are just a dream.
eye4wings is offline Find More Posts by eye4wings
Old Sep 29, 2012, 12:36 PM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Whilst cutting ribs is certainly not my favourite part of the build process, this set wasn't particularly onerous, certainly compared to something like the Rapide. As a matter of interest, how do laser cut sets cope with the sweep in the spars etc., which mean that all of the rib and spar notches have to be cut at an angle? Presumably the notches would have to be cut on the narrow side, leaving the user to file an angle onto the edges?
Anyway, I have re-arranged my kit of parts into a more three dimensional layout. Next step is to sort out the rear subspars, decide on the aileron servo mountings etc. Then I think it's decision time on that central joint before the glueing starts.
Old Sep 29, 2012, 02:03 PM
pentaxman's Avatar
Looking good so far.
What gives with the back to front pegs on the outer ribs?
Old Sep 29, 2012, 02:31 PM
Joined Aug 2004
I remember seeing that tip in one of the magazines, ages ago. It gives you better grip, with less chance of damaging the balsa.
Is there a prize?
Old Sep 29, 2012, 10:56 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
cool looking plane.
rcrich is offline Find More Posts by rcrich
Old Sep 30, 2012, 02:43 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
I hit on the idea of reversing the pegs years ago (did you steal it for the magazine, Mike?!). The tapered end makes them much more versatile but, as you see, I do keep some in the original configuration as well.
(Translation note for transatlantic readers:- Peg = Clothes Peg = Clothes Pin.)
Old Oct 03, 2012, 11:03 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Once more, with glue!
After sorting out a likely servo mounting arrangement whilst the glue was drying on my laminated spar joiner, it was time to start glueing some bits together at last.
Because I can't fit the R2 ribs until the dihedral brace is glued in place, I've had to leave the spar caps off for the moment. I'm now trying to get as much done as possible to the two panels before joining them together, after which I fear things are going to get rather unwieldy.
Build Log Maxford Spad 70 inch electric build log jasonak Electric Warbirds 3 Nov 18, 2013 08:21 PM
Discussion electric Design Build and Fly competition dards Electric Plane Talk 0 Jun 14, 2012 09:27 PM
