Old Dec 13, 2012, 11:11 AM
glenbees is offline
Find More Posts by glenbees
Leeds/Bradford Leeds, Great Britain (UK)
Joined Jun 2003
Great explantion regarding building your own Quad. Was going to buy RTF but slowly changing my mind after watching your vids. As a complete noob to Quads i understood your build but could you explain please when you mention PI gain and these reccomended numbers you give, what does this mean regarding setting up your quad before your first flight . what exactly does gain mean.
glenbees is offline Find More Posts by glenbees
Old Dec 13, 2012, 05:18 PM
ox5 is offline
ox5
Find More Posts by ox5
ox5
United States, NC, Candler
Joined Sep 2012
Hi all..just wondering if anyone can tell me how to turn on auto level. No switch will turn it on. Tx is Spektrum DX6i. Do I need to assign this chanel to a switch? What am I missing here?
ox5 is offline Find More Posts by ox5
Old Dec 13, 2012, 06:05 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Ox5,
Are you using the kk2 board?
If so then you need to, first, configure your Tx to bind a switch to channel 5/aux1. This is often used for the landing gear, so you might find documentation on that.
Secondly you need to make sure that you have a jumper/servo cable from channel 5/aux 1 on the Rx to the fifth channel on the kk2.
You then need to modify the setting for self-level in mode or misc settings to aux, the other option is stick.
brontide is offline Find More Posts by brontide
Old Dec 13, 2012, 08:41 PM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
Originally Posted by templton89 View Post
...most likely a SF prop, ...........and these are designed to create more drag and reduce rpm, .........
Completely incorrect.
wannabe is offline Find More Posts by wannabe
Old Dec 14, 2012, 09:20 AM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
You can also activate self level with the sticks. Throttle down and to the left, elevator down and to the right.
Tom
carr52 is offline Find More Posts by carr52
Old Dec 14, 2012, 09:29 AM
templton89 is offline
Find More Posts by templton89
templton89's Avatar
United States, NY, Kings County
Joined Nov 2011
care to shed some light then?
because that's what I've gathered from reading forums and my own tests. 8x4DD gws props feel way different compared to 8x4SF
templton89 is offline Find More Posts by templton89
Old Dec 16, 2012, 11:12 AM
ox5 is offline
ox5
ox5
Joined Sep 2012
Carr52 Hey thanks guy. The stick method worked. Thanks Brontide also.Yes I'm using the KK2 and have the wiring as you outlined.
Old Dec 16, 2012, 04:40 PM
mebillica is offline
Find More Posts by mebillica
mebillica's Avatar
Joined May 2012
ok, I am a newbie and have a question. What is "self level"?
mebillica is offline Find More Posts by mebillica
Old Dec 16, 2012, 09:32 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Self level is the helicopter wanting to level itself when you release the controlls. Works sometimes and not so well other times. I like it because it seems to make the helicopter easier to handle more stable. But I'm a low and slow type.
Tom
Old Dec 17, 2012, 11:12 AM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
You said "these are designed to create more drag and reduce rpm". This is just plain silly. So called Slow Fly (SF) props are thinner and create far less drag than standard props which makes SF props far more efficient.
SF props were initially developed to do exactly the opposite of what you said. They are intended for early electric power systems that were not as powerful and had less vibration than glow engines. Therefore SF props could have smaller and lighter hubs because the potential for them to fly apart was far less in an electric motor plane. Lighter weight, less mass, more efficient.
Look at these three prop performance charts.
10x7SF for low power electric motors
10x7E for high power electric motors
10x7 standard for glow engines
Old Dec 17, 2012, 09:22 PM
mebillica's Avatar
Joined May 2012
Tom
Sounds like something I need to do, how do I do it?
Old Dec 18, 2012, 02:23 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
I use a jumper wire on the 5th channel of my Rx to the 5th channel on the KK2. I activate the self level using the gear switch on my DX6i. Or you can activate by using the sticks on the TX. Throttle full down and to the left and elevator full back and to the right. It will show self level on the LCD screen. Set your choice of stick method or switch on the KK2 menu.
Tom
Old Dec 18, 2012, 03:13 PM
mebillica's Avatar
Joined May 2012
Tom
I have the HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA). It is very similar to all the kk boards, but I don't have the LCD screen. Anyone know how to do this on my board? I cant find a manual for it.
Old Dec 18, 2012, 03:18 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Click this link and click on the "files" tab. There you can find the docs:
http://www.hobbyking.com/hobbyking/s...ga328_PA_.html
mystman is offline Find More Posts by mystman
Old Dec 18, 2012, 03:59 PM
mebillica's Avatar
Joined May 2012
Thanks, I looked there and it wasn't there. Apparently because I bought it from the USA store. The file is only under the "International Store" files tab.
Build Log Beginner plane both easy to build and easy to fly (with plans and videos) ffranck Foamies (Scratchbuilt) 42 Feb 06, 2016 02:32 AM
Poll Douglas Skyraider Video Tutorial for a "drawing and tutorial disk" Harpye Foamies (Scratchbuilt) 52 Sep 05, 2012 12:13 PM
Mini-HowTo MyRcMart's X450Q Quad Build Tutorial (Using KK Board) bobepine Multirotor Talk 2 Jul 27, 2012 10:01 AM
Discussion First quad build, Oppinions/Suggestions appreciated. (now with video) Brainanator Multirotor Talk 4 Jul 09, 2012 02:10 PM
Mini-HowTo POSTING VIDEO: A Beginner's Guide to Building an FPV Quadcopter Lucidity47 Multirotor Talk 0 May 19, 2012 10:24 AM
