Old Oct 24, 2012, 08:38 PM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Most stock ESCs require programming to set things like battery type, low voltage cutoff, brake on or off and a number of other parameters. This is usually done either by a programming card, or with the Tx by using the stick positions and listening to assorted beep patterns (very cumbersome). In addition, all ESCs need to have the throttle endpoints calibrated, and this is done with the Tx.
Flashing an ESC is done with a small programming device and a computer. The aim is to replace the stock firmware, which is not optimized for use with multirotors, with custom firmware that is, usually SimonK. The end result is that the multirotor with flashed ESCs flies better and is more stable and responsive to stick commands.
With flashed ESCs, you no longer need to worry about programming the ESC, but you still need to calibrate the throttle.
Here's a long thread about flashing ESCs if you want to know about it in depth:
http://www.rcgroups.com/forums/showthread.php?t=1513678
Flashing a flight control board is basically the same idea- to replace stock firmware with updated or improved firmware, and it uses the same basic tools. Here's a thread on that that talks about how it's done for KK boards. The process is similar for other types of boards:
http://www.rcgroups.com/forums/showthread.php?t=1458663
It's not really necessary to flash the FC or ESCs, but it does improve the flying experience, and many people do it as a matter of course. Not all ESCs can be flashed, and some ESCs even have the parameters locked in, and cannot be programmed.
Rick
2400RDR is online now Find More Posts by 2400RDR
Old Oct 24, 2012, 09:47 PM
ox5 is offline
ox5
Find More Posts by ox5
ox5
United States, NC, Candler
Joined Sep 2012
Is there a list anywhere of suitable escs for multirotors? I just ordered the Hobbywing Fun Fly 30A and was feeling pretty smug but now I'm worried again.Waiting on shipments from China is nerve wracking. Having a problem getting the payment through for the KK2.0. Troubles already! Hope everyone else's quads are going well. Hey Chris, What are the single connectors you were using on the Rx? Are these called gold single pin connectors?
ox5 is offline Find More Posts by ox5
Old Oct 25, 2012, 04:28 AM
Joined Feb 2009
Here's the best database. Be sure to scroll in the database itself. You don't see all of it if you just scroll the page:
http://wiki.openpilot.org/display/Doc/RapidESC+Database
The ESCs with Atmega chips and pads in a row are the easiest to flash. The Silab chips are a lot more trouble, but it can be done.
Also, RCTimer is selling a line of preflashed ESCs that are pretty good. Right now though, the HK F-series is the favorite of flashers (F-20, F-30) Here's some preflashed F-30s for sale in the RCG classified. Only coming from Florida; you could get these pretty damn quick:
http://www.rcgroups.com/forums/showthread.php?t=1757562
Old Oct 26, 2012, 09:03 AM
natelarson57 is offline
Find More Posts by natelarson57
Joined Oct 2012
bobepine, Im looking at building a quad thats pretty much the same size that you should in the. Is there any way I can get a complete list of the components you used? Also I think you replied to someone about which motor you used and it linked to a kv1800 motor, didnt you use kv2600? And the suggested prop sais 6 or 7in based on the battery. I think you said you used an 8in prop. What effect does that have compared to 6 or 7, more thrust? Any risks using that size blade? Thanks for all the help, and I really like that quad you built! I hoping to build a copy of it(not using a custom frame though). thanks!
natelarson57 is offline Find More Posts by natelarson57
Old Oct 26, 2012, 09:10 AM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
Preflashed ESC's now thats what I'm talking about. Thats the kind of stuff guys like me need. Believe it or not there are people like me that when it comes to computer stuff I'd be better warming a pop tart on it than programming something. I'm a plug and play hobby guy. Thank you RCTimer.
Tom
carr52 is offline Find More Posts by carr52
Old Oct 26, 2012, 02:02 PM
ox5 is offline
ox5
ox5
Joined Sep 2012
hi natelarson57. If you look closely there are 2 quads in the video. The Armattan 362 uses the 1800kv motors linked to. The last with the bigger motors is a larger frame size. Sorry I cant answer your other questions.
Old Oct 31, 2012, 01:15 PM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Originally Posted by bobepine View Post
Here are the PI settings I recommend as a staring point for frames ranging from 250mm to 600mm. I believe these are better than the stock settings that come pre-programmed in the KK2 board:
Pitch and Roll:
-45
-100
-30
20
Yaw:
-80
-20
-70
-10
Are those values meant to be negative??
AcroFPV is online now Find More Posts by AcroFPV
Old Oct 31, 2012, 05:00 PM
templton89 is offline
Find More Posts by templton89
templton89's Avatar
United States, NY, Kings County
Joined Nov 2011
No but thats how they appear in kk2.0 , with a dash
templton89 is offline Find More Posts by templton89
Old Oct 31, 2012, 05:04 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
The dash appears if you change the value from positive to negative. By default all the PI settings are positive settings. There are no dashes.
Old Nov 01, 2012, 06:02 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Got this in an email. Looks like it comes already setup and you only need to plug in the motors ESC's and Rx.
Tom
http://www.valuehobby.com/multi-roto...rol-board.html
Old Nov 02, 2012, 02:29 AM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
Tom
Do some research on the KK board and especially "lazy motor 4" issues. It sounds one heck-a-lot easier than it is.
There are several threads on the KK board and they folks there are pretty good about helping -- but sometimes tempers flare when things don't work as they should.
scott page is offline Find More Posts by scott page
Old Nov 02, 2012, 07:00 AM
Joined Feb 2009
Tom
None of these boards are truly plug and play. After you get your components installed and connected, at the very least you'll have to calibrate your ESCs, and check the directions on the gyros. It's not unusual to need to reverse the yaw gyro.
That being said, this type of board is much easier to set up than the ones that connect to a computer interface.
Old Nov 02, 2012, 09:03 AM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Will do. I ordered two of the KK2 boards. I figured they would be easier for me to use. By me I mean non computer type. Just not any good with the darn things.
Tom
Old Nov 03, 2012, 11:00 AM
geedee is offline
Find More Posts by geedee
Chester, UK
Joined May 2010
Help please
Started to build a quad a year or so back but did not persue further.
I have 4 x Emax CF2822 motors .plus a frame (450) called a black something or other bought from Europe
I have the original board (unused from HK) but intend to replace this with the latest LCD KK2.
Could someone kindly tell me what ESCs I need (preferably from HK)
to complete the project.
I would like to use a camera other than a keychain.
Many thanks
geedee is offline Find More Posts by geedee
Old Nov 03, 2012, 02:24 PM
bobepine is offline
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Guys, I've been so busy I haven't even had time to read this thread and answer any questions addressed to me. Very sorry. I'll do my best to catch up on reading and replying this week.
Best,
Chris
bobepine is offline Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Build Log Beginner plane both easy to build and easy to fly (with plans and videos) ffranck Foamies (Scratchbuilt) 42 Feb 06, 2016 02:32 AM
Poll Douglas Skyraider Video Tutorial for a "drawing and tutorial disk" Harpye Foamies (Scratchbuilt) 52 Sep 05, 2012 12:13 PM
Mini-HowTo MyRcMart's X450Q Quad Build Tutorial (Using KK Board) bobepine Multirotor Talk 2 Jul 27, 2012 10:01 AM
Discussion First quad build, Oppinions/Suggestions appreciated. (now with video) Brainanator Multirotor Talk 4 Jul 09, 2012 02:10 PM
Mini-HowTo POSTING VIDEO: A Beginner's Guide to Building an FPV Quadcopter Lucidity47 Multirotor Talk 0 May 19, 2012 10:24 AM
