United States, NY, Albany
Joined Sep 2012
Joined Sep 2012
Probably, yes, but ecalc would indicate you are more in the range of 77% of throttle with 11" props and would have a 6 minute flight time. Going with a 200g GoPro drops that to 58% throttle and a 10 minute max flight time. DT700 prop efficiency testing thread. You will see a big difference between 50% max lift and lift at 50% throttle. http://www.rcgroups.com/forums/showthread.php?t=1594904 |
I did go bigger on the ESC's ( New 20a turnigy multistar ). 11 inch props. I also factored in 50 grams for the props and excess wieght in my calculations. The frame i'm going to use is 195 grams. I'm also going to direct connect all the wires verses using a heavier board ( Solder ). So I think i'm going to be pretty close to that weight depending how the frame goes together. Its not going to hurt to try a dummy load and see if it works. I have a go pro and 3 cameras. Only the rebel has the lower weight and excellent quality. If not this becomes my learning quad and we build a bigger one. Thanks for the help guys. Appreciated!!!! Blue Skies Nightstone Edit * I just looked at that efficiency thread. A 12 inch prop would give me 1728 grams of thrust at 50% throttle. The esc's I have can handle the amperage. So it all comes down to how light the build comes out. |
United States, NC, Candler
Joined Sep 2012
First of all this is a great thread. I've done weeks of reasearch on rc groups on quads and this is the thread that made it all make sense. Thank you sir! Now some questions? I want to build a quad almost identical to yours but am unsure of the motors you used. The rest is perfectly clear. Well clearer than the sound track on the first video anyway. Also. How much lifting capability does your quad have. I at least want to lift a small keychain camera. Any suggestions. Thanks Roger
Joined Jun 2011
The motors I used for that build are these ones: http://www.myrcmart.com/rcx-a282212-...ts-p-3994.html That quad has roughly 2640 grams of thrust. The whole thing weighs about 500 grams. Yeah, you can probably lift a dozen keychain cameras with that. ![]() Have fun building! Best, Chris |
Just been watching the videos again. Just wanted to say thank you again for making them. I had bought an Aerosky H100 and the board keeps going wonky so I've ordered the KK2 from HK. I plan to use the H100 as a learning tool. So right now I'm just flying a little Syma X1 around with a key chain cam on it while I wait for the new board. Thanks again all. Now back to the videos.
Tom |
The videos are very thorough and complete. I don't think I'll have a problem as long as I stick to the videos but if I do I'll just go back and watch again. I'm gonna try and plug the H100's board into the PC and see what happens. Got nothing to lose. Thanks again.
Tom Update: Plugged the board into the PC but nothing happened. Oh well, the KK2 will be here in a couple of weeks then I believe I'll have better results. |
Canada, ON, Merrickville-Wolford
Joined Jun 2012
What props do you use? What thickness of lexan are you using for the plates? What's the aluminum boom sizes? Oh, and recommended battery? Many thanks in advance. cheers, Andrew |
Hey Chris!
The Armattan 356 is awesome!!!! I'm already doing flips and rolls. This thing is a Porsche compared to my other quads and it's really strong too. I flipped it into the ground pretty hard and the only damage was a broken screw (plastic) that holds the leg on. I'm very impressed with this thing. I'm ready to try building one for myself. Thanks again, Jim |
United States, WA, Spokane
Joined Oct 2012
One question I have relates to is meant by "programming escs?"
How is it done, and for what reason? I've read that ESCs don't need to be programmed for multi rotors in some places, and in others it should be done. Some programming I've read deals with brakings, others deal with low or medium start up power, but I can't find a "why and how" for this. How, and why, and in terms that a rookie can understand. Thanks for any help. |
Thats a good question. Also I'd like to know what is meant by flashing the esc's or the board. As for the esc all I've ever done is put the throttle in the full up position the first time I ever use the thing. The paper that came with the esc said this is to set the end points for the throttle. I have no idea. It said do it so I did.
Tom |
| Thread Tools | |
| Poll Douglas Skyraider Video Tutorial for a "drawing and tutorial disk" | Harpye | Foamies (Scratchbuilt) | 52 | Sep 05, 2012 12:13 PM |
| Mini-HowTo MyRcMart's X450Q Quad Build Tutorial (Using KK Board) | bobepine | Multirotor Talk | 2 | Jul 27, 2012 10:01 AM |
| Discussion First quad build, Oppinions/Suggestions appreciated. (now with video) | Brainanator | Multirotor Talk | 4 | Jul 09, 2012 02:10 PM |
| Mini-HowTo POSTING VIDEO: A Beginner's Guide to Building an FPV Quadcopter | Lucidity47 | Multirotor Talk | 0 | May 19, 2012 10:24 AM |
| Build Log Beginner plane both easy to build and easy to fly (with plans and videos) | ffranck | Foamies (Scratchbuilt) | 20 | Mar 15, 2011 04:46 PM |
