Old Jan 27, 2013, 06:01 PM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
Originally Posted by ilektron View Post
Reminds me of this thing.
Wow! I am so not worthy.....
wannabe is offline Find More Posts by wannabe
Old Jan 28, 2013, 05:24 AM
Pkitup is offline
Find More Posts by Pkitup
United States, NY, New York
Joined Jan 2013
I guess I'm going to have to keep playing with my pi settings after seeing that lego bike video . My rcexplorer style tri with kk2 fc is all over the place if the wind blows a tiny bit. I'll be running the numbers in the hundreds today just to see what happens .
Pkitup is offline Find More Posts by Pkitup
Old Jan 28, 2013, 04:13 PM
pbosche is offline
Find More Posts by pbosche
United States, CO, Colorado Springs
Joined Jan 2013
Input/advice on my first/new build!
So I've just dropped a bit of dough on a bunch of parts for a new beauty.
I'm hoping some of you here can take a look at it and give me some input. It's all ordered so if anything is "wrong" I'll most likely have to get diffent parts but more than your thoughts on these parts I'm hoping you can let me know what pieces I haven't ordered that I will need to complete the build.
I know I'll need a soldering iron and heat shrink. Can I use a mini torch light for the HS instead of dropping money on a heat gun?
HUNTER VTAIL 400 BUILD
VTAIL 400mm from Dialfonzo w/protection cover
http://www.myrcbuild.com/DiaLFonZo--...SON-_p_87.html
http://www.myrcbuild.com/DiaLFonZo--...-TOP_p_85.html
FC
http://witespyquad.gostorego.com/fli...ontroller.html
Motors
http://www.rctimer.com/index.php?gOo...4&productname=
ESC
http://www.rctimer.com/index.php?gOo...9&productname=
Props x8
http://www.rctimer.com/index.php?gOo...6&productname=
Batteries/Charger
http://www.hobbyking.com/hobbyking/s...dProduct=11915
http://www.hobbyking.com/hobbyking/s...idProduct=6478
RX/TX
http://www.goodluckbuy.com/wfly-wft0...l-device-.html
Thanks in advance. I'd hate to have almost everything I need only to find out I'm missing a little something and then have to wait possibly 30 days for another order. Wires, screws, bolts, mounting board/plate..who knows?! I'm hoping you with experience do and can help me be prepared!
Thanks!
-Paul
pbosche is offline Find More Posts by pbosche
Old Jan 28, 2013, 09:57 PM
Mark_K is offline
Find More Posts by Mark_K
Joined Jan 2007
I just swipe it over a stove burner a few times. A bic lighter/match also works in a pinch.
Mark_K is offline Find More Posts by Mark_K
Old Jan 28, 2013, 10:31 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
I did that for awhile. I think you can get a functional heat gun from Harbor Freight for $15 or something. When you have the budget, you can get a lot of use out it for a number of things.
ilektron is offline Find More Posts by ilektron
Old Jan 29, 2013, 09:24 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Most of us are not, that guy seems to come out with something unique and/or technically difficult every week.
brontide is offline Find More Posts by brontide
Old Feb 01, 2013, 01:35 PM
Byrdman is offline
Find More Posts by Byrdman
Winter Haven FL
Byrdman's Avatar
Joined Dec 2003
Great tutorial. Helped me put together a list for my first Quad.
http://www.rcgroups.com/forums/showthread.php?t=1822290
Thanks!!
Byrdman is offline Find More Posts by Byrdman
Old Feb 02, 2013, 03:58 PM
DavidGib is offline
Find More Posts by DavidGib
Joined Feb 2013
600 mm quad project
Hi Chris
Can I firstly congratulate you on a brilliant set of tutorials; I have learnt a lot, Thank you.
The last time I brought anything to do with RC I was using glow engines and every thing was controlled by servos as such you can see I have a lot of catching you to do. After seeing a quad flying nearby I was hooked.
I am wanting to build an x quad with a motor to motor measurement of 600mm and enough lift to eventually in the future, lift two cameras, one for FPV, the other for HD photography/video and all the gps and sensors etc.
I do have a couple of questions if you or anybody could help answer I would be grateful.
For my first FCB I have purchased the KK2.2 board and already have a Futaba T6EXAP Tx and Rx.
Can I power the Rx as you do in the video or do I have to change this to a different one, if I do need to change it can you recommend one?
The other relates to the motors and props, I have looked on the Net and now I am totally confused where to start trying to work out what to get, if you have any suggestions I would be grateful, the ECS’s and battery I think I can work out.
Thanks David
DavidGib is offline Find More Posts by DavidGib
Old Feb 03, 2013, 01:01 PM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Hi David,
You should be able to power your TX off the KK2. As for props, with a 600mm quad, I'm not sure. I mostly work with smaller quads. I'd say you'll be looking at about 12 inch props.
Sorry if my answer isn't very helpful, but my experience qith quads this size is limited.
Best,
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Feb 05, 2013, 11:03 AM
Fun Spunge is offline
Find More Posts by Fun Spunge
Joined Aug 2011
Loss of power after 30 secs then motors 1 and 3 stop
Hi guys, Firstly, thanks for such a great thread; I've read it (and others) for ages looking for a solution.
I'm using 4x HK Blue 30A ESC's with HK 2728 Brushless Outrunner Motors at 1000kv with 8x4.5 props and KK2 v1.2 FW
I've set it up as instructed (and spent the afternoon in hospital with 2 badly cut fingers because I didn't take the props off when advised to do so when calibrating the ESC's via the KK2 so be warned)!
I have tried to calibrate the 4 ESC's on the KK2 but it didn't go as stated so I did them individually with the TX and receiver. There must be an easier way to programme these ESC's! It is all so complex using the beeps and pips on the TX!
My quad powers up and starts to lift of (drifting quite badly) but then suddenly loses power and motors 1 and 3 stop altogether. There is a noticable "glitch" on the throttle stick about the mid point too. Can anyone throw any light on this annoying issue please?
Fun Spunge is offline Find More Posts by Fun Spunge
Old Feb 05, 2013, 11:35 AM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I just use my soldering iron. Its hot and right there ready to use. I hold it close to the shrink tube and TA DA!! Done
carr52 is offline Find More Posts by carr52
Old Mar 09, 2013, 05:35 PM
tsilis is offline
Find More Posts by tsilis
Joined Mar 2013
Greta tutorial it helped me a lot to build my first quad but i have a problem. Every time i try to take off my quad it always leans to the left side and it looks like it will flip
if i raise my throttle. I have done everything said on the videos my sensors and receiver test seems is ok although i had hard time to trim the values down to 0. I have calibrated the escs many times, balanced my props, my motors spin as they should on a "x" quad (m1 cw, m2 ccw, m3 cw, m4 ccw) still no luck so far. I have also calibrated on a level surface. My setup consists of 4 1200kv motors, kk2 board(1.5 firmware), HK 30 A esc(not flashed), turnigy 9x transmitter and receiver. Any suggestions?
tsilis is offline Find More Posts by tsilis
Old Mar 09, 2013, 11:15 PM
bobepine's Avatar
Joined Jun 2011
Are you talking about radio trims? Why do you say you had a hard time reducing trims?
Chris
Site Sponsor
Old Mar 10, 2013, 04:59 AM
tsilis is offline
Joined Mar 2013
Yes I am talking about radio trims. It was hard because I used the subtrim menu first but still couldn't zero aileron I had to use the trim menu as well. Something else that i just noticed to the receiver test is when i get my throttle almost half way up i get this values
which they seem wrong to me at least for the aileron. And this is what it looks like with no input at all from the transmitter
Any help is much appreciated. Thanks
Old Mar 10, 2013, 06:44 AM
bobepine's Avatar
Joined Jun 2011
Sorry, but I don't quite understand. This is what you wrote: " ... i had hard time to trim the values down to 0."
How can this be hard to do? Simply set the trims to 0%.
I recommend setting flight trims and subtrims to 0%. Then calibrate the sticks on your radio. Then make sure all your channels are in the right direction. I believe you need to reverse ailerons and elevator using a DX7. Then unplug everything. Power up the quad and calibrate the ACC/sensors. Then bind your radio to the quad and see what happens.
I have a DX7 I just recently bought and for some reason, a quad will want to go left and forward without trims. Then if I install a devo receiver and use my walkera transmitter, I do not need trims at all. I calibrated the sticks on the DX7 and did everything mentioned above to no avail. Need to use trims to make it fly. It's weird and I don't like it.
I do not use subtrims. I use flight trims to the left and back a bit and then it flies fine. Not sure why. It's almost as if the DX7 has something skewed with stick calibration.
Best,
Chris
Site Sponsor
Build Log Beginner plane both easy to build and easy to fly (with plans and videos) ffranck Foamies (Scratchbuilt) 42 Feb 06, 2016 02:32 AM
Poll Douglas Skyraider Video Tutorial for a "drawing and tutorial disk" Harpye Foamies (Scratchbuilt) 52 Sep 05, 2012 12:13 PM
Mini-HowTo MyRcMart's X450Q Quad Build Tutorial (Using KK Board) bobepine Multirotor Talk 2 Jul 27, 2012 10:01 AM
Discussion First quad build, Oppinions/Suggestions appreciated. (now with video) Brainanator Multirotor Talk 4 Jul 09, 2012 02:10 PM
Mini-HowTo POSTING VIDEO: A Beginner's Guide to Building an FPV Quadcopter Lucidity47 Multirotor Talk 0 May 19, 2012 10:24 AM
