Old Sep 23, 2012, 03:41 AM
Lpbug is offline
Find More Posts by Lpbug
United States, CA, Santa Monica
Joined Jul 2011
Piano wire vs Piano MUSIC wire- difference?
Piano wire
vs
Piano MUSIC wire
Any input? Also, where can I get a spool of 1mm pushrod type piano wire?
Lpbug is offline Find More Posts by Lpbug
Old Sep 23, 2012, 06:08 AM
Thechittyfather is offline
Find More Posts by Thechittyfather
Damn this gets addictive.
Thechittyfather's Avatar
United Kingdom
Joined Oct 2011
Same stuff, different sales pitch I think.
Most of the online rc stores over here in the Uk sell piano wire. Although I notice that the available sizes didn't include 1.0mm (just 0.9 and 1.2).
I tend to use 0.7 and for longer rods I jam a bit either end of a 2mm CF tube with some epoxy. 1mm sounds quite heavy. Is it to do with the hole size on your horns?
Thechittyfather is offline Find More Posts by Thechittyfather
Old Sep 23, 2012, 02:35 PM
Lpbug is offline
Joined Jul 2011
nope, trying to build a vibration isolation system with the wires- I might end up going with the 1.2mm
Old Sep 23, 2012, 02:44 PM
United Kingdom
Joined Oct 2011
Sounds interesting. I'm not saying there isn't 1mm out there but it doesn't show up on the sites I use. You might try music wholesales.
Old Sep 23, 2012, 03:05 PM
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Music wire is sometimes called piano wire, the wire for the Dulcimer they are selling isn't what is traditionally called music wire, although some might define it as such. "Music wire" as traditionally used by the hobby industry is tempered spring steel.
The wire they are selling for the Dulcimer is more like guitar string. You can buy similar wire as that at your local hardware store for about $3-4, at least that's what I paid for it at Ace Hardware about a month ago! Don't use the hardware store wire in your Dulcimer though!
This (ACE Hardware) is nicer plated wire than regular baling wire which isn't plated.
Wingman26 is offline Find More Posts by Wingman26
Old Sep 23, 2012, 05:27 PM
southside is offline
Find More Posts by southside
I fly bipes
southside's Avatar
United States, OK, Elgin
Joined Dec 2011
matress wire
I get wire out of old inner spring mattresses...it looks to be about .6 to.7 mm. a bit more flexible that tempered wire but still stiff. it is used in the mattresses to tie the wire frame and the springs in place.
southside is offline Find More Posts by southside
Old Sep 23, 2012, 08:58 PM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
Music wire for pushrods
I've recently purchased 0.039 inch music wire, equivalent to 1mm, for pushrods at a local hobby shop. It comes in 36 inch straight lengths from K&S Precision Metals in Chicago, Illinois. Stock number is # 497. It is hard enough to stay straight. I wouldn't buy anything on a coil for pushrods, unless the coil was quite large in diameter, maybe 20 inches at least. I have no experience with pianos or hammer dulcimers.
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Sep 23, 2012, 09:12 PM
Lpbug is offline
Joined Jul 2011
Hmm... I don't need it to be exactly straight since I'll be rolling it into semi circles anyway as I'm using them for vibration isolation- so is the Dulcimer good enough for this purpose?
Weight of music/piano wire FredN The Builders Workshop 7 Nov 02, 2014 09:02 PM
Discussion Different kinds of music wire bergfalke4 The Builders Workshop 2 Jun 16, 2007 05:15 PM
Piano wire/Music wire torsion data? vintage1 The Builders Workshop 11 Sep 27, 2005 02:42 PM
Music/piano wire - 48 inch Salmon-Run The Builders Workshop 4 Jul 09, 2005 10:33 AM
Piano Wire / Music Wire Navy Diver Parkflyers 6 Sep 22, 2001 06:51 AM
