Old Sep 23, 2012, 12:17 AM
astr0b0y is offline
Find More Posts by astr0b0y
Australia, VIC, Melbourne
Joined Sep 2011
Termination voltage seems too high
I noticed with my PL8 that the termination voltage at the end of a LiPo charge is always 0.006-0.007v higher that requested. For normal pre-sets this means ~4.207 per cell. I normally charge to 4.18v and with this set in the PL8 that means each cell finishes at 4.187v.
Is this expected behaviour?
astr0b0y is offline Find More Posts by astr0b0y
Old Sep 23, 2012, 12:24 AM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
Yes, this is normal behavior because the cell voltage always settles shortly after the charge is complete. It does not harm the cells in any way. However, if it bothers you, you can always set the end charge voltage to whatever value you want using the Charge Control Software. You will find this parameter on the Charge tab for every preset. Parameter name is "Charge Voltage". After you change it, remember to click the Update button.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Sep 23, 2012, 12:26 AM
astr0b0y is offline
Joined Sep 2011
Thanks Tim. Great product by the way, I often feel like discharging batteries just so I can use my PL8!
Discussion High Kv and Low Voltage or Low Kv and High Voltage PatrickRC Power Systems 47 Jul 22, 2014 09:29 PM
Discussion Flight pack voltage too high for DS821s and TM1000 ? netdudeuk Radios 6 Mar 21, 2012 08:43 PM
Too high of voltage? ElvisLivesOn77 Radios 2 Jul 06, 2004 01:53 PM
If 3s voltage is too high? ICRSHLTS Batteries and Chargers 7 Oct 17, 2003 05:49 PM
10/12/20/24 cell High Voltage Panasonic 3000s and loose cells too! Jason M Aircraft - Electric - Airplanes (FS/W) 17 Sep 16, 2003 09:33 PM
