Old Sep 22, 2012, 05:34 PM
Raydee is offline
Find More Posts by Raydee
RC Addict
Raydee's Avatar
United States, NY, Niagara Falls
Joined Jun 2002
Going to try Set RPM on my Trex 700 again
I didn't have much luck getting it to work good before but I am going to give it another try. Is this setup still the preferred setup for the Trex 700 using the newest 4.02 firmware?
http://www.castlecreations.com/suppo...0mx-530kv.html
Raydee is offline Find More Posts by Raydee
Old Sep 22, 2012, 06:16 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I am not speaking for CC but I think that they now recommend a PWM of 12 and High start power.
Governor gain seams to vary from motor to motor so you may want to tune it a little after you get flying. Some are able to run a little higher gain than 12.
I have found that V4.01 and V4.02 governors are definitely better than the older versions.
RC Man is offline Find More Posts by RC Man
Old Sep 22, 2012, 06:32 PM
Raydee is offline
RC Addict
Raydee's Avatar
Joined Jun 2002
Ok what should I change the start power to? I think I left it low last time I tried 4.01 and that may have been the cause of some of the issues I had.
Old Sep 23, 2012, 04:22 AM
John235 is offline
Find More Posts by John235
John235's Avatar
Sydney, Australia
Joined Mar 2006
I've always had good results with Set RPM mode on micro size helis since the feature was introduced in 2009. I'm running V3.28 now and it as good as ever. Since I crashed the heli with an old version of governor software (about V1.3 or something) I don't want to try beta release firmware anymore.
In the interests of stability and safety I think its important not to go too aggressive on the gain setting. Lower gain is safer. Better to be safe than sorry with a 700 size heli.
John235 is offline Find More Posts by John235
Old Sep 23, 2012, 05:17 AM
RC Man is offline
United States
Joined Feb 2001
Start Power controls the motor power used during the first couple of seconds to get the blades turning. Set it at 100 and forget it for most helicopters. If it if trying to turn the helicopter around at first then decrease 10 at a time until smooth.
Old Sep 25, 2012, 05:51 AM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
I would Leave the start power at default and adjust up if it is needed. My 700 is default on start power...
If the 700 is stock use 12 kHz PWM and Normal timing.
Clintstone is offline Find More Posts by Clintstone
Old Sep 25, 2012, 06:23 AM
Raydee is offline
RC Addict
Raydee's Avatar
Joined Jun 2002
Ok I will give that a try.
Old Oct 05, 2012, 03:58 PM
Bernie Wolfard is offline
Find More Posts by Bernie Wolfard
Castle's Chaos Corner
Bernie Wolfard's Avatar
Olathe, KS (next to the Castle)
Joined Jun 2001
Increasing start power usually make a good start up bad. This is not a setting you want to change from its default unless you have a good reason to do so, usually related to a motor so bad it won't start anyway else.
Bernie
Bernie Wolfard is offline Find More Posts by Bernie Wolfard
Old Oct 06, 2012, 02:14 PM
Raydee is offline
RC Addict
Raydee's Avatar
Joined Jun 2002
Ok I put the start power back to default and will hopefully get to try out the GOV mode tomorrow or Monday.
Old Oct 09, 2012, 07:42 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
I would start the GOV gain around 12....
Old Oct 09, 2012, 11:55 AM
Raydee is offline
RC Addict
Raydee's Avatar
Joined Jun 2002
Yep I have the GOV gain set to 12 to start. I will post a log after I fly it today after work.
Old Oct 09, 2012, 05:38 PM
Raydee is offline
RC Addict
Raydee's Avatar
Joined Jun 2002
Ok I took the heli out today after work. It looks like 2200rpm is a bit to high so I will knock it down to 2050 and see how it does. I think the gain is to low, I dont know if it is a good way to tell but when I switched at the end of the flight from 2200rpm to 1950 to land the RPM dipped way down and had to come back up to 1950.
Old Oct 10, 2012, 09:23 AM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Your head rpm is too high.
Look at the PowerOutput parameter. It is near 100% at the start of the flight, and is at 100% after 100s until you switch back to the lower rpm.
That means you are flying at near 100% throttle for the entire flight.
What did the Parameter window say when you chose that set rpm? If it didn't complain big time, then I think you don't have the pole count, gearing, or Kv input correctly into the Castle Link software.
added. Looking at your current parameters, and I see it is in the 30-40A range during most of the flight, only occasionally peaking into 80A range.
I'd say your gearing (or Kv) is a bit on the low side.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Oct 10, 2012, 12:13 PM
Raydee is offline
RC Addict
Raydee's Avatar
Joined Jun 2002
Alan I am using the standard Trex 700e motor and gearing. Like I said in the post above I know i need to lower the RPM for the gov to work properly. When I put 2200rpm into the program it did warn me but I wanted to try it anyway and make sure.
Do you think when switching to 1950 and having the head speed drop way off before it picks back up is a indicator that the gain is to low?
Old Oct 10, 2012, 04:30 PM
Chicago 'burbs
Joined May 2006
I'm not an expert on the drop-off issue---I just tend to fly at one headspeed for the entire flight, including takeoff and landing.
I have heard of other's problems with the drop-off. I am not positive what exactly causes it, except that when you flip to a lower rpm, the rotor rpm can tend to decouple from the motor rpm--due to the one-way bearing. So the ESC sees that the motor load drops dramatically and lowers the current way down in an attempt to keep the new low motor rpm--with the motor seeing almost no load. At some point the main rotor slows down enough to have the oneway engage, but now the motor current is really low, so the governor has a long way to go to get it up to sustain the head rpm.
Not sure if that is a real explanation of the problem or not. Sounds good to me !
I am not sure if goosing up the gain will help this or not, and whether the higher gain may cause other problems.
But like I said, it is easy enough to land at any headspeed, as long as you can lower the pitch appropriately. So I don't experience the problem in the way I fly.
Discussion Going from an 11t to 12t on my trex 550e v2 hidaven Electric Heli Talk 1 Sep 03, 2012 07:45 PM
Help! Here we go again--What set of programs for CNC? Mel Duval CAD/CAM 10 May 29, 2012 08:26 AM
Sold ALIGN TREX 700 Metal Tail Pitch Assembly / / Metal Tail Rotor Control Arm Set helifreak592 Aircraft - Electric - Helis (FS/W) 0 Apr 05, 2012 06:36 AM
