Old Sep 22, 2012, 04:16 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Build Log
1980 Outrigger with an Electric Outboard - Changed to Predator Outrigger w/outboard
I am going to start the outrigger build in the next post. First I want to thank anixs for the ESC. Change of plans, my girlfriends son said the boat that I was going to build for him and do a build log and use that ESC was "Dorky looking". So now we are going to buy him this boat and use that ESC in it. He likes this one a lot. It's from Hobby King.
Dave8888 is offline Find More Posts by Dave8888
Old Sep 22, 2012, 04:21 PM
Dave8888 is offline
Joined Nov 2011
Now for the outrigger build. I am going to build this boat for myself. I bought the plans on ebay. It's a 1980 design. I am going to change it from a nitro inboard to an electric outboard using the outboard in the 2nd picture, and make it like a smaller Spitfire Hydro from Prather see 3rd picture (except electric instead of nitro). Boat is giong to be 24" long. I will take photos as I build. For more on the outboard see this thread http://www.rcgroups.com/forums/showthread.php?t=1702142
Old Sep 22, 2012, 04:22 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
That really looks more like a mono than a rigger. Is it going to be running one of the outboard legs?
Edit Never mind, shoulda waited for the 2nd post
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Sep 22, 2012, 08:27 PM
Basstronics is offline
Find More Posts by Basstronics
United States, OH, Toledo
Joined Jun 2008
If you need some small struts for that little hull I got some kicking around that need a new home.
Also got a wire drive!
Basstronics is offline Find More Posts by Basstronics
Old Sep 24, 2012, 08:04 PM
Dave8888 is offline
Joined Nov 2011
Thanks Basstronics, I will keep that in mind. Made a full size paper mock-up of outrigger today. Plans are for a 26" in length outrigger. Mine is going to be 23 1/2". Plans have rear sponsons, but I don't think I am going to put those on. Also the sponson supports are 2 1/2" on the right side and 3" (in length) on the left on the plans. I am going to make them a little longer 3 1/2" and the same on both sides. The sponson supports for this outrigger are made of 1/4" plywood.
Old Sep 25, 2012, 06:49 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You're definitely going to want rear sponsons with an outboard on the back, you'll probably want to either extend or move them back so the trailing edge is closer to the prop.
wparsons is offline Find More Posts by wparsons
Old Sep 25, 2012, 09:35 AM
Dave8888 is offline
Joined Nov 2011
You mean like the Prather Spitfire? Why are rear sponsons so important if I use an outboard?
Old Sep 25, 2012, 09:50 AM
Chinewalker is offline
Find More Posts by Chinewalker
Chinewalker's Avatar
1000 Islands, NY
Joined Dec 2009
To keep the stern afloat...
Chinewalker is offline Find More Posts by Chinewalker
Old Sep 25, 2012, 12:18 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ Exactly, it'll be hard to get the same lift at the transom as you would get with an inboard motor if you run an outboard.
Old Sep 25, 2012, 03:52 PM
Dave8888 is offline
Joined Nov 2011
Thanks guys. You're right, ( I wasn't thinking) the prop has a lot more weight to lift with an outboard. I am going to put on the rear sponsons. This is exactly why I started this build log was to get advice as I go.
Old Sep 25, 2012, 04:25 PM
Dave8888 is offline
Joined Nov 2011
How far back should I extend the rear sponsons? If you look at the Prather Spitfire they extend out pretty far (first 3 pictures), but if you look at the JAE .21 outboard outrigger they don't extend out very much (4th picture).
Old Sep 25, 2012, 06:56 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
They can almost to inline/even with the prop; if you go any further you will starve the prop for undisturbed water in the turns.
Kcal is offline Find More Posts by Kcal
Old Sep 28, 2012, 06:19 PM
Dave8888 is offline
Joined Nov 2011
If I make them almost even with prop, like the boat in the first picture, they will be put on like the second picture (back of boat is white with red background). There's not enough sponson glued to back of boat is there? I want to use these rear sponsons (on the plans) because I have the templates already.
Old Sep 28, 2012, 07:26 PM
Kcal is offline
Joined Jul 2008
Maybe add a gusset if your worried about them braking off, or move them up a little?
Old Sep 28, 2012, 07:33 PM
Dave8888 is offline
Joined Nov 2011
I was thinking of moving them up a little. What is a gusset?
Discussion help with electric outboards traxxas13 Racing Boats - Electric 4 Aug 01, 2012 01:38 AM
Alert Prather Fast Cat Hull for an outboard 3.5cc(.21cid) hobbyclub Racing Boats - Internal Combustion 1 Jul 15, 2012 10:38 PM
Discussion electric boat to compete with .21 nitro outboard KAW_Concours Racing Boats - Electric 14 Mar 31, 2012 07:13 AM
Wanted Looking for an electric outboard motor HyperHelis Boats (FS/W) 10 May 13, 2010 11:58 PM
Where Can I Find An Electric Outboard Motor Cover!!! telecom tech Racing Boats - Electric 1 Sep 24, 2004 03:49 AM
