GosHawk 26iV 2mm EPP wing: Good Flight &Good Gliding
GosHawk 26iV 2mmEPP wing Light Ornithopter With New GLDAB for Gliding. Test Flight3. I added 0.8mm Carbon rod on wings for to increase thrust. Good flight and Good Gliding. Width 94cm Length 44cm Weight 69g Total 79g (160mA 2cell Lipo) Receiver: OrangeRx R415 Spektrum DSM2 Compatible 4Ch Micro 2.4Ghz Receiver Servo: HK-5320 Ultra-Micro Digital Servo 1.7g*2 Motor:C05XL Micro Brushless outrunner 10800kv ESC: Cosmotec 7A 4.4g Max Power CT-7A V2.2 Gear:Main Gear:GWS Spur Gear IPS A 82TM0.3, Second Gear DIDEL M0.3 Outer 60T Inner12T SPurGear G260 (inner 12Tgear was exhaged by GWS 12T M0.3 copper pinion gear) ,Third Gear: DIDEL Outer48T Inner12T M0.3SpurGear G348, M0.3 9T PinionGear Battery:Lipo2cell130mAh G3, 2cell160mAh G3,2cell180mAh G3 Wing: 2mm EPP Control: 3CH (a motor, inverted Vtail: 2 servo) Gliding system:New GLDAB It follows TB30--- http://trhk.exblog.jp/i16/ |
FalcoHobby 22iV Acrobatic Flight: Looping
Good acrobatic flight. I added 1mm Carbon rod on wings for to increase thrust. Then, Loop is OK. |
GosHawk 25iV with Articulation wing : First test Flight
Flight is OK. Thrust is OK. I learned this system from KJELL and FUSHIMIbird. Thank you KJELL. |
GosHawk 26iV Orcon film wing Light Ornithopter
With New GLDAB for Gliding. Good Flight and Gliding.
GosHawk25iV with articulated wing
So that the 0.8mm piano wire which I use in order to bend wings sags, I tied 1.4mm carbon rod beside piano wire. By this sagging down of piano wire disappeared. The wings came to turn well and thrusts increased. A side to the body of this wings has Airfoil. Width 94cm Length 49cm Weight 128g battery Lipo 2cell 240mAh17g Total flight weight 145g Receiver: Castle Creations Berg Microstamp 4L 4Ch Micro Rx FM cryistal: Castle Creations Micro Crystal Berg (72MHz) Servo: Vtail: elevator & rudder (DM 4.7g servo *2) Motor: Turnigy 1811 Brushless Indoor Motor 3800kv ESC: H-KING 10A Fixed Wing BrushlessESC Gear: Main gear: 66TM0.4 Acetal GWS EPS D (Stainless shaft3mm, 3mm ball bearing), First gear: 56TM0.4 GWS EPS 2 (=GWS IPS-42), 64P8TPinionWire(with 4mm ball bearing), Pinion Gear M04 10T(=64P 10T) Battery: Lipo 2cell 240mAh G3 Film of a wing Orcon filmAN36 Control: 3CH (a motor, inverted Vtail: 2 servo) Gliding system New GLDAB |
| Thread Tools | |
| Discussion My stock DJI motors run pretty hot, here's a way to measure the temperature in flight | jasper7821 | Multirotor Electronics | 5 | Aug 02, 2012 03:05 PM |
| Discussion My son's fourteen minute flight! | Thomas Cummings | Thermal | 11 | Jun 27, 2012 06:59 PM |
| Sold Brand new flight tested ZII, 2 flights on it fly's great | ROCKY2 | FPV/RPV - Equipment and Vehicles (FS/W) | 11 | Jun 05, 2012 12:08 PM |
| Discussion My first flight with my new F550/WKM, Aeroxcraft landing gear and Contour GPS camera | jasper7821 | Multirotor Talk | 0 | May 27, 2012 01:27 PM |
