Old Feb 21, 2013, 03:50 AM
Devabird is offline
Find More Posts by Devabird
Natural flight
Devabird's Avatar
Joined Oct 2012
Balance
Originally Posted by Kazu-kaku View Post
Thank you. I will fly Butterfly20-3 in order to judge whether this method is effective.
Very good work indeed Kazuhiko, I am sure you will get good results.
I see that your battery is in the "tail", that's important for those who want to make ornithopters. On the one I am finishing I had to spend some time to find the good balance, and the best place for the battery was unexpectedly... almost under the tail !
According to my last experience, before trying the first flapping wing fly, it is important to send the ornithopter with fixed wings (without wind if possible), it should glide, at least a bit. If it falls directly, one has to rearrange the parts to change the gravity center, or watch the profile of the wings.
Devabird is offline Find More Posts by Devabird
Old Feb 21, 2013, 06:29 AM
Kazu-kaku is online now
Find More Posts by Kazu-kaku
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Thank you.
In the ornithopter that has not a tail, a center of gravity becomes considerably back.
Therefore, there is the case that a position of battery becomes in a tail.
Kazu-kaku is online now Find More Posts by Kazu-kaku
Old Feb 21, 2013, 10:04 AM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
Hi Devabird , A long time ago i want to ask you what kind is this nice bird on your avatar ? If you have larger picture or link please post it .
Thanks in advance!
Otto
About the tail role will write later now the time is limited
seagull10 is offline Find More Posts by seagull10
Old Feb 21, 2013, 11:00 AM
Devabird is offline
Natural flight
Devabird's Avatar
Joined Oct 2012
Thanks in advance!
Otto
Sorry, I can't find it anymore at the moment.
Old Feb 23, 2013, 05:54 PM
Joined May 2011
Old Feb 24, 2013, 05:47 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Puffin29iV with KJELL wiggle Drive: Flapping test
GosHawk29iV with KJELL wiggle Drive: Flapping test (2 min 29 sec)
This system is heavy (10g UP).
But the flapping is very smooth.
Old Feb 24, 2013, 09:05 PM
therealthing691 is offline
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
amazing work Doctor and functions very well regards Brian
therealthing691 is offline Find More Posts by therealthing691
Old Feb 24, 2013, 10:17 PM
Joined May 2011
Good choice and work Doctor, The weight can be optimized by designing (more slimmer)and CNC-ing instead of printing plastic parts.Also the width of mechanism seems can be reduced and weight of the transverse CF plates and steel axle will decrease. POM is maybe the best(for the purpose) material between plastics but 7075 aluminum will work better.
IMO at least on "Z" shaft it's good ball bearings to be used. The other two axes will work satisfactory on sliding bushings (the speed is low and the motion isn't fully rotational ) .Teflon is the plastic with the lowest coefficient of friction between commercially available plastics and it's used most frequently for manufacturing of bearing bushings.
Success
Old Feb 24, 2013, 10:18 PM
Slachemburg is offline
Find More Posts by Slachemburg
Indonesia, East Java, Malang
Joined Oct 2012
Excellent
Excellent Mr. Kakuta..
regards Slachem
Slachemburg is offline Find More Posts by Slachemburg
Old Feb 25, 2013, 01:11 AM
Velko Velkov is online now
Find More Posts by Velko Velkov
Velko Velkov's Avatar
Joined Sep 2007
I think this is not KJELL wiggle Drive.
Velko Velkov is online now Find More Posts by Velko Velkov
Old Feb 25, 2013, 01:19 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
KJELL made these parts of Wiggle drive with a 3D printer and sent it to me.
Old Feb 25, 2013, 01:48 AM
Joined Sep 2007
This is new KJELL wiggle Drive ?
What is the sense ? The wing movement is only flapping.
Old Feb 25, 2013, 02:12 AM
KJELL is offline
Find More Posts by KJELL
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Thanks Kazu.
The design of your first prototype looks good. After testing it, I am shore you can reduse the weight. What flapping frequesy are you using?
New Kjell Wiggle Drive0 (1 min 16 sec)
KJELL is offline Find More Posts by KJELL
Old Feb 25, 2013, 02:21 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Originally Posted by KJELL View Post
Thanks Kazu.
http://www.youtube.com/watch?v=36SUWofNHKA
I do not yet know flapping frequesy.
I will know it when wings are finished and I fly the ornithopter.
Old Feb 25, 2013, 02:40 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
The Wiggle Drive is made for fast flapping. Smaller wings can be used.
Discussion My stock DJI motors run pretty hot, here's a way to measure the temperature in flight jasper7821 Multirotor Electronics 5 Aug 02, 2012 03:05 PM
Discussion My son's fourteen minute flight! Thomas Cummings Thermal 11 Jun 27, 2012 06:59 PM
Sold Brand new flight tested ZII, 2 flights on it fly's great ROCKY2 FPV Equipment (FS/W) 11 Jun 05, 2012 12:08 PM
Discussion My first flight with my new F550/WKM, Aeroxcraft landing gear and Contour GPS camera jasper7821 Multirotor Talk 0 May 27, 2012 01:27 PM
