Old Jan 26, 2013, 09:12 PM
jusjak is offline
Find More Posts by jusjak
Serbia, Central Serbia, Belgrade
Joined Mar 2011
Hi guys,
I have Turnigy 1811, kv1500 motor laying around. Do you think it is OK for Kestrel or other ornithopter, if I use one stage reduction of 13.25, which makes maximum of around 14 flaps/sec (no load)? Is there particular reason to go with such high Kv and 2 stage reduction? Vibration, maybe. No experience, this is going to be my first ornithopter. Thanks.
jusjak is offline Find More Posts by jusjak
Old Jan 26, 2013, 09:33 PM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
Originally Posted by Kazu-kaku View Post
SlowHawk2 with Articulated wings Turn system
http://www.youtube.com/watch?v=1hEv6wFSEDo
A conclusion:
Unfortunately, by this system, it is difficult to change direction.
Ornithopter can not turn.
Kakuta-Sensei:
my humble observation & suggestion
this Articulated wings may glide well in the air with current CG,
but extra thrust gained from the Articulated wings changed the CG of the orni when flying.
move forward the CG to cope with thrust line may help to control the direction of the bird
I maybe wrong.....pls kindly try
best regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old Jan 26, 2013, 11:27 PM
therealthing691 is offline
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
One more time thank you for everything you do and you are the fastest model builder experimenter I have seen ever . well said Otto AKA seagull
Doctor kazu is a very amazing and generous person in my opinion and one very enthusiastic experimenter and marvelous ornithopter builder regards Brian
therealthing691 is offline Find More Posts by therealthing691
Old Jan 27, 2013, 07:39 AM
Kazu-kaku is online now
Find More Posts by Kazu-kaku
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Bat 18-3 and Bat 18-4
Bat 18-3 Swing legs: Flight on snow in wind 4-5 meter /second
Bat 18-3 Swing legs: Flight on snow (2 min 19 sec)
Bat 18-4 with articulated wings and swing legs: Flight on snow in wind 4-5 meter /second
Bat 18-4 with articulated wings and swing legs: Flight on snow (1 min 52 sec)
Kazu-kaku is online now Find More Posts by Kazu-kaku
Old Jan 27, 2013, 07:40 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Dsungarypterus 5-8 with Articulated Wings: Very Good Flight on Snow
Dsungarypterus 5-8 with Articulated Wings: Very Good Flight on Snow in wind 4-5 meter /second.
Dsungarypterus 5-8 with Articulated Wings: Very Good Flight on Snow (3 min 49 sec)
Old Jan 27, 2013, 07:42 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Seagull 24iV-4 with Articulated wings: Flight on Snow in wind 6-7 Meter / second.
Seagull 24iV-4 with Articulated wings: Flight on Snow (2 min 6 sec)
Old Jan 27, 2013, 07:43 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
SlowHawk2 with Articulated wings Turn system test 2 Roll axis
SlowHawk2 with Articulated wings Turn system test 2 Roll axis (3 min 2 sec)
A conclusion: By this system, it may be able to be roll.
Ornithopter may turn by Cahnge of Roll axis and Elevater.
The turning is possible by Sean's tail.
Old Jan 27, 2013, 09:59 AM
Taiwan
Joined Aug 2011
Enjoyed the vids,well done
thanks for sharing
best regards
Sam
Old Jan 27, 2013, 01:30 PM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Yes. Very educational *
G-LO is offline Find More Posts by G-LO
Old Jan 27, 2013, 04:02 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Thank you.
Old Jan 27, 2013, 04:05 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Originally Posted by samwei1950 View Post
Kakuta-Sensei:
best regards
Sam
Articulated wings moves CG in the front.
Old Jan 27, 2013, 04:07 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Originally Posted by jusjak View Post
Hi guys,
Please Try it.
Old Jan 27, 2013, 04:11 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Originally Posted by seagull10 View Post
Hi Doctor,
First thanks for the experiment ,the video and all the efforts!
I have watched the video few times and there is my thoughts:
1. I think that it is evident there is not slight but pretty strong tendency of turning right by some reasons which will analyze later.
2. There is almost no difference with the plate fixed in the center and fixed to the right .
3.When the plate is fixed to the left the system ornithopter - test stand behave strange .First start to turn left and after all the system achieve a good amplitude of shaking, it change the direction of turning to the right again? The last one I think is evident as well.
I think that there is some mechanical reason for such a system's behavior related to the system's shaking and mechanical instability. From what I see on the video only fastening clamp is evidently offset to the left . Probably it act like pendulum and precession force push the test stand to the right .Bigger amplitude on left wing is also possible in result of the shaking and twisting of the stand beam on which the clamp and the ornitopter are fastened.
Probably there are additionally stand leveling issues as well.
So IMO the experiment isn't absolutely pure and it's early to conclude that this new system isn't work.
Mr. Velkov opinion make sense as well and probably in the air without test stand influence the ornithopter will behave different .
I will suggest one more time the same experiment with the clamp mounted backwards.
Also if you still want to experiment it(I don't want to press you in any way) , make this ornithopter to fly first by the articulation system only and after that try this new turning system . This way you will be sure that the ornithopter generate symmetric thrust forces before starting experimenting with the new turning system.
I will really have to fly.
Old Jan 27, 2013, 05:09 PM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
Thanks for the efforts Doctor .
Actually the proper way of turning include roll to the inside of the turn curve so I think the system has to work .Also I am sure there will be asymmetry tn the differential thrust when the articulation angles aren't eqall
Is the right turn of the orni on the video(when it fly) was initiated from you or it turns from it self .or maybe better question is :is it able to fly straight without need of permanent control of the direction?
seagull10 is offline Find More Posts by seagull10
Old Jan 27, 2013, 10:27 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
SH2 flew straight without doing big maneuvering.
Because it seems to have fly out from a park, I controlled it to the right.
However, it was not able to turn enough and fell.
Discussion My stock DJI motors run pretty hot, here's a way to measure the temperature in flight jasper7821 Multirotor Electronics 5 Aug 02, 2012 03:05 PM
Discussion My son's fourteen minute flight! Thomas Cummings Thermal 11 Jun 27, 2012 06:59 PM
Sold Brand new flight tested ZII, 2 flights on it fly's great ROCKY2 FPV Equipment (FS/W) 11 Jun 05, 2012 12:08 PM
Discussion My first flight with my new F550/WKM, Aeroxcraft landing gear and Contour GPS camera jasper7821 Multirotor Talk 0 May 27, 2012 01:27 PM
