Old Jan 17, 2013, 04:45 AM
therealthing691 is offline
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
Originally Posted by seagull10 View Post
Thanks Doctor,
Now there is noticeable difference and I hope the active articulated bat will show its superiority
over the non articulated one. Also I hope, it to be enough stable and controllable .
On the pictures is shown the progress of the articulation angles and IMO the GosHawk 25iV still to be the champion in that field and your best (and closer to the Nature) flying bird and my favorite one
Success on the next test .
i agree totally i love the flying style of this bird regards Brian
therealthing691 is offline Find More Posts by therealthing691
Old Jan 17, 2013, 04:51 AM
australia
Joined Apr 2007
18-4 looks great and flies well also that snow looks so nice nice and cool is 40c here and is only expected to go down to 30c over night regards Brian
Old Jan 19, 2013, 11:21 PM
Kazu-kaku is online now
Find More Posts by Kazu-kaku
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
GosHawk 26iV with Articulated 2mmEPP wings
GosHawk 26iV with Articulated 2mmEPP wings: First Flight test (3 min 33 sec)
With New GLDAB for Gliding.
First Flight Test. Good slow flight and low falpping rate.
Width 94cm Length 44cm Weight 76g (160mA 2cell Lipo)
Receiver: OrangeRx R415 Spektrum DSM2 Compatible 4Ch Micro 2.4Ghz Receiver
Servo: HK-5320 Ultra-Micro Digital Servo 1.7g*2
Motor:C05XL Micro Brushless outrunner 10800kv
ESC: Cosmotec 7A 4.4g Max Power CT-7A V2.2
Gear: Main Gear: GWS Spur Gear IPS A 82TM0.3, Second Gear DIDEL M0.3 Outer 60T Inner12T SPurGear G260(inner 12Tgear was exhaged by GWS 12T M0.3 copper pinion gear) ,Third Gear: DIDEL Outer48T Inner12T M0.3SpurGear G348, M0.3 9T PinionGear
Battery:Lipo2cell160mAh G3
Wing: 2mm EPP
Control: 3CH (a motor, inverted Vtail: 2 servo)
Gliding system:New GLDAB
It follows TB30--- http://trhk.exblog.jp/i16/
Kazu-kaku is online now Find More Posts by Kazu-kaku
Old Jan 19, 2013, 11:55 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Bat 18-3 Swing legs: Third Flight test with Body and Red eye
Bat 18-3 Swing legs: Third Flight test with Body and Red eye (5 min 21 sec)
I mount with the body and LED Eyes.
This ornithopter is made for the metal band which is active in Europe.
Old Jan 20, 2013, 01:48 AM
australia
Joined Apr 2007
http://www.youtube.com/watch?v=P6P67-sml7A
cool that looks great
Old Jan 20, 2013, 02:05 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Seagull 24iV-4 with Articulated wings: Test Flight and Gliding 3 on Snow ground
Seagull 24iV-4 with Articulated wings: Test Flight and Gliding 3 on Snow ground (5 min 51 sec)
Good Flight.
Old Jan 20, 2013, 03:16 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Dsungarypterus 5-8 with Articulated Wings: Test Flight of Articulated Wings
Dsungarypterus 5-8 with Articulated Wings: Test Flight of Articulated Wings (3 min 0 sec)
Old Jan 20, 2013, 03:21 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
GosHawk25iV with articulated wing. Good Flight and Gliding and Roll.
GosHawk25iV with articulated wing : Good flight Roll (3 min 5 sec)
Old Jan 20, 2013, 04:53 AM
australia
Joined Apr 2007
a fleet of articulated birds excellent. I think you might have inspired me to try build a articulated wing for my large span bird if you dont mind me using your design Doctor Kazu best regards Brian
Old Jan 20, 2013, 05:14 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Perhaps this Articulated Wing system is effective in all ornithopters.
It can be made with simple work.
There is one uneasy point.
At the tail assembly of an ornithopter of Sean, an ornithopter may not do a turn, because going straight becomes strong by this system.
Old Jan 20, 2013, 06:06 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
Very much enjoyed your articulated flapping wing vids
thanks for sharing
best regads
Sam
samwei1950 is offline Find More Posts by samwei1950
Old Jan 20, 2013, 06:38 AM
australia
Joined Apr 2007
ok thankyou Doctor Kazu i will keep that in mind will have to replan my tail similiar to yours.
I still have some carbon sheet just have to put some thought into design my be later in the year thankyou and regards Brian
Old Jan 20, 2013, 08:55 PM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
I am sure Doctor because this system is very simple , very effective and produces very natural wings' movements, it will be widely reproduced in the future.
The turning problem can be overcome in many different ways but I think that the most effective way is by manipulating the outer parts of the articulated wings.
Here is a proposition for one possible solution to the turning problem:
As you can see on the picture everything is the same as in the original
system, the only difference is that the piano wires are attached to the movable (left/right regarding the ornithopter's frame) supporting plate.
The plate is controlled by separate servo which doesn't need to be very strong because the forces applied to the supporting plate in result of the wing's movements actually cancel each other . Moving the plate left or right will create slight differential imbalance in the angles of articulation on both wings, which have to initiate turn . I think that this will work either flapping or gliding, The points named "A" and "B" on the sketch are the pins on which supporting plate slide left or right . The pins are mounted firmly to the frame of the ornithopter and they pass thru the supporting plate oval holes .
seagull10 is offline Find More Posts by seagull10
Old Jan 20, 2013, 10:31 PM
australia
Joined Apr 2007
Hi Otto,
like the idea is very similiar to the trailing edge propotional steering i thought of trying in the past but this is by off setting the articulation great idea i think.
As it only takes minimal difference to make a orni turn a great idea i think
Otto regards Brian
Old Jan 21, 2013, 04:17 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
This is a good idea. I may make it and test it.
Discussion My stock DJI motors run pretty hot, here's a way to measure the temperature in flight jasper7821 Multirotor Electronics 5 Aug 02, 2012 04:05 PM
Discussion My son's fourteen minute flight! Thomas Cummings Thermal 11 Jun 27, 2012 07:59 PM
Sold Brand new flight tested ZII, 2 flights on it fly's great ROCKY2 FPV Equipment (FS/W) 11 Jun 05, 2012 01:08 PM
Discussion My first flight with my new F550/WKM, Aeroxcraft landing gear and Contour GPS camera jasper7821 Multirotor Talk 0 May 27, 2012 02:27 PM
