Old Jan 14, 2013, 02:50 AM
vlatko is offline
Find More Posts by vlatko
vlatko's Avatar
Croatia, Osijek-Baranja County, Osijek
Joined Feb 2006
It looks like the Bat has the best thrust of all of your birds doc. It seems like it needs less power than other birds to fly.
I'm amazed.
vlatko is offline Find More Posts by vlatko
Old Jan 14, 2013, 09:58 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
RC guys know that it's not easy job to design and scratchbuild a RC flying bat,not even mention the flapping one
well done! Sensei
best regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old Jan 14, 2013, 10:58 AM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
Doctor ,the idea to compare two almost identical fling machines face to face is very good IMO.
But to make the difference in performances more clear IMO you have to increase the angle of articulation of the articulated bat.Now the difference in flapping angles on both birds is negligibly small and respectively the performances are very close . Are there any stability issues that stopping you to increase the angles of articulation on the articulated bat?
Thanks for the videos and the technical data and appreciate flying and filming in such a complicated weather conditions.
seagull10 is offline Find More Posts by seagull10
Old Jan 14, 2013, 04:39 PM
Kazu-kaku is offline
Find More Posts by Kazu-kaku
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Thank you.
You noticed well.
Bat18-4 is different from Bat18-3 in the amplitude of flapping.
Ornithopter with Articulated wings can fly in stability.
However, it becomes difficult to turn to right or left.
Kazu-kaku is offline Find More Posts by Kazu-kaku
Old Jan 14, 2013, 06:08 PM
Iky_Alvin is offline
Find More Posts by Iky_Alvin
Joined Nov 2011
Thanks for the encouragement. I've attached a few better pictures and linked a couple of short videos of the flapping action. In the current state of build the ornithopter is quite delicate and wants to come apart when turning the gears by hand as I've not connected the drive shafts or hooks for the rubber. I've also not put the heatshrink on to retain the should hinge in the brass tubes. The video shows two slightly different phasing of gears. Interestingly and something I had not thought about - different directions of rotation give slightly different shape flaps. I think the first phasing is nicer to look at, but will do some experimentation when I have secured the gears and other joints. Thanks.
Orthithopter articulated wing_3.AVI (0 min 32 sec)
Orthithopter articulated wing_4.AVI (0 min 25 sec)
Iky_Alvin is offline Find More Posts by Iky_Alvin
Old Jan 14, 2013, 07:12 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
http://www.youtube.com/watch?v=HNP1uS7kG4w
http://www.youtube.com/watch?v=_Z7Sh-rgJQ0
This movement cannot make a strong thrust.
So that a strong thrust is made, when a wing is at the highest position a wing must becomes straight.
While a wing is swung down, a wing must be straight as much as possible.
When a wing go upward, it has to bend.
Can you set your system to move so?
Old Jan 14, 2013, 10:48 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
Originally Posted by Kazu-kaku View Post
A difference of two ornithopters is only Articulated wing and length, pinion Gear.
Bat 18-4 with articulated wings and swing legs: First Flight test
http://www.youtube.com/watch?v=ZlDp4jybr6U
Control system is modified swing steering system for membrane flapping wing by Takahasi. Maneuvering is not good yet.
width 101cm
length 38cm
weight97g
battery Lipo 2cell 240mAh 14g
Total flight weight111g
Receiver: OrangeRx R415 Spektrum DSM2 Compatible 4Ch Micro 2.4Ghz Receiver
Servo: DM 4.7g servo *2
Motor:Turnigy 1811 Brushless Indoor Motor 3800kv
Gear: "Main Gear 0.4M 66T*2& 3mm ballbearingSpur Gear (M0.4 x 58T), 64P8TPinionWire(4mm ball bearing),Pinion Gear M04 10T(64P 10T)"
ESC:H-KING 10A Fixed Wing Brushless Speed Controller
Battery:Lipo2cell180mAh G3
Control: 3CH (a motor, Rudder and Elevator servo)
Film of a wing:Orcon film
Bat 18-3 Swing legs: First Flight test
http://www.youtube.com/watch?v=2QiYb7hTLRY
Control system is modified swing steering system for membrane flapping wing by Takahasi. Maneuvering is good. It flies lightly.
width 101cm
length 33cm
weight87g
Total flight weight101g
Gear: "Main Gear 0.4M 66T*2& 3mm ballbearingSpur Gear (M0.4 x 58T), 64P8TPinionWire(4mm ball bearing),Pinion Gear M04 12T(64P 12T)"
I'll take one, please.... lol
Akura2 is offline Find More Posts by Akura2
Old Jan 14, 2013, 11:05 PM
Joined May 2011
Thank you.
You noticed well.
Doctor, thanks for the answer but I mean increasing of the articulation angle not of the flapping angle .Exactly like in the next your video:
http://www.youtube.com/watch?feature...=bIjRr1fstdo#!
Old Jan 15, 2013, 12:09 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
As you say, Bat18-4 has a little articulation angle .
I will increase the articulation angle of Bat18-4.
Old Jan 15, 2013, 05:27 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
New setting.
Old Jan 15, 2013, 04:33 PM
Joined May 2011
[QUO
Success on the next test .
Old Jan 15, 2013, 05:55 PM
Joined May 2011
[QUOTE=Iky_Alvin;23815425]Thanks for the encouragement. I've attached a few better pictures and linked a couple of short videos of the flapping action. In the current state of build the ornithopter is quite delicate and wants to come apart when turning the gears by hand as I've not connected the drive shafts or hooks for the rubber. I've also not put the heatshrink on to retain the should hinge in the brass tubes. The video shows two slightly different phasing of gears. Interestingly and something I had not thought about - different directions of rotation give slightly different shape flaps. I think the first phasing is nicer to look at, but will do some experimentation when I have secured the gears and other joints. Thanks.
You are right, on the first video the motion is better, so it's going to be the right direction of gears rotation
Unfortunately as the Doctor mentioned this motion isn't good enough and I think that your phasing(timing)isn't perfect. Try to make it 90 degree as for beginning and post a result here please
Also I think that is time for you to open your own thread or use Kinkade's one "Wings articulation research thread" somewhere on pages 6,7 or 8 shame for us
Old Jan 16, 2013, 04:49 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Seagull 24iV-4 with Articulated wings Test Flight 2 and Test Gliding 2
SeaGull 24iV-4 with Articulated wings: Test Flight 2 and Test Gliding 2 (7 min 34 sec)
Test Flight 2 and Test Gliding 2 on Snow ground.
I remade wings to articulated wings.
I reduced a dihedral angle.
I enlarged the tail assembly for improvement of flight control.
This system is the same as a system of Goshawk25iV.
Flapping motion is Good.
A thrust is enough and lift is good.
Old Jan 16, 2013, 05:07 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Bat18-3 flies lightly
The flight of Bat18-4 is powerful.
Bat 18-4 with articulated wings and swing legs: Second Flight test
Bat 18-4 with articulated wings and swing legs: Second Flight test (3 min 23 sec)
Maneuvering was improved.
I made the amplitude of flapping of wing tip large.
Powerful flight.
I mount with the body for exercises.
Bat 18-3 Swing legs: Second Flight test
Bat 18-3 Swing legs: Second Flight test on Snow ground (4 min 38 sec)
It flies lightly.
Old Jan 16, 2013, 09:42 AM
Taiwan
Joined Aug 2011
The bats were doing great jobs,totally awesome
thanks for sharing
best regards
Sam
Discussion My stock DJI motors run pretty hot, here's a way to measure the temperature in flight jasper7821 Multirotor Electronics 5 Aug 02, 2012 03:05 PM
Discussion My son's fourteen minute flight! Thomas Cummings Thermal 11 Jun 27, 2012 06:59 PM
Sold Brand new flight tested ZII, 2 flights on it fly's great ROCKY2 FPV Equipment (FS/W) 11 Jun 05, 2012 12:08 PM
Discussion My first flight with my new F550/WKM, Aeroxcraft landing gear and Contour GPS camera jasper7821 Multirotor Talk 0 May 27, 2012 01:27 PM
