Old Sep 22, 2012, 07:48 AM
Bart10 is offline
Find More Posts by Bart10
Bart10's Avatar
Poland, Podkarpackie, Mielec
Joined Apr 2010
Help!
Problem with potentiometer
Hello everybody!
Yesterday, I flew my model and I had a strange problem with XM-2812-33 RTR. When I connected battery to RX, I heard -5-6-5- tone and after that a lot of short, fast beeps. After about 15 sec. the beeps stopped and I heard -5-6-5- tone again. It was the first flight in low temperature (about 15 Celsius degree or less). But today I discovered that ESC have the the same behaviour when throttle stick isn't at the bottom. But when I had this strange situation I probably didn't touch the stick. When is the problem and what I should do? I use Optic 6 with the Spectra 2.4 module.
Bart10 is offline Find More Posts by Bart10
Old Sep 22, 2012, 03:52 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Bart10 View Post
Hello everybody!
1. Check your ESC instructions, as that may well be a warning that the ESC detects reverse polarity.
(Most likely Power pack, but a forgotten adjustment to Tx & throttle setting changed.)
2a. Check Tx batteries are now of good quality and fully charged:
2b. Remove ESC and plug a servo into that channel to verify all is well or that there is in fact a
problem with Tx.
(If BEC was being used then you will also need a 4 cell battery pack with new or fully charged batteries to test)
99% of problems relate to ESC/BEC:
Electronic Speed Control - Why BEC and LVC cause most EP RX problems
if a servo operates well with fully charged Tx & Rx batteries and a servo, try another ESC and power pack.
3. If a problem with Tx is verified, then as per previous advises, contact your local distributor
for your nearest service centre.
Hitec Warranty & Service - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time. Reach us at 858.748.8440 or
service@hitecrcd.com any time you have a question"
If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Sep 23, 2012, 12:45 AM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
1) It couldn't be a reverse polarity because the problem resolved itself after ~15 sec.
2) I use Ni-Mh battery pack and it was 9,4v on the screen. The module didn't have any "lags" so I think that batteries could't be a problem. I never have had any problems with this potentiometer- before and after this strange situation.
What do You think about it? What are symphtoms of break potentiometer? Maybe I had to move a stick but I forgot about it?
Old Sep 23, 2012, 03:06 AM
A.T. is offline
Joined Aug 2002
Problem with battery connection, wiring or ESC, if it were a Tx problem, problem would have remained.
Alan T.
Old Oct 03, 2012, 12:21 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Today, I had the same problem. I didn't wait but I tightened the throttle stick with full force. Beeps were resolved. This is strange bevaviour of my stick:
Optic- throttle (0 min 12 sec)
It has been from I have bought this TX. When I have set a throttle range in ESC (some time ago), I have been tightened this stick with full force, too. But when I always turn on ESC this stick is on second "teeth". I had this problem before first flight (before second everything was OK) and it was quite cold outdoor. Is this normal? Is my potentiometer broken?
Wanted Dx6i B5K potentiometer or DX6i for parts pavcon Aircraft - General - Radio Equipment (FS/W) 9 Jul 09, 2012 05:46 PM
Discussion How can I modify a brushless esc to be controlled with a potentiometer? Steve Klyce Power Systems 5 Apr 15, 2008 06:19 PM
Astro 110D with bad potentiometer JoeR Power Systems 18 May 29, 2002 03:49 PM
