Old Sep 22, 2012, 05:07 AM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
N-TECH JETS "BAE HAWK" 11 modifications
Always on the look out for some good value EDF jet, recently found out about this new BAE HAWK just a perfect adition to my fleet. I was more then pleased with the performance of 70mm and two 90mm foamies I have been flying over the years so 127mm EDF version is a great new contender. This ARF kit is specially designed to take 127mm RAMTEC, either '91 IC DF or E-power. Optional comes set of very robust metal trial link landing gear I ordered with the kit. After thorough check of all parts I have decided to do some modifications to this kit finding some areas totally inadequate for model of this size and all up weight. Bellow is the list of my main mods, Joe.
jofro is offline Find More Posts by jofro
Old Sep 22, 2012, 05:18 AM
jofro is offline
Joined Jan 2010
180x205cm (72x80") overall size, 127mm Ramtec/650kv/180aESC/12S power system. 12kg AUW inc.3kg in 12S/8000/40c/5cell 3300NMHi. J.
Old Sep 23, 2012, 01:45 AM
jofro is offline
Joined Jan 2010
This model came with no parts list or instr. manual, pretty strait forward build but I'm still puzzled what are these two parts, any idea, could it be some sort of Rudd. sub/stab? Joe.
Old Sep 23, 2012, 07:03 AM
tinker27 is offline
Find More Posts by tinker27
tinker27's Avatar
United Kingdom, England, Boston
Joined May 2011
Very nice how much kit jofro ? thanks Neil
tinker27 is offline Find More Posts by tinker27
Old Sep 23, 2012, 04:11 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the real hawks have some fins in the back ...but maybe they were supose to put mono coat over them nice mod ...keep us posted
AIR SALLY is offline Find More Posts by AIR SALLY
Old Sep 23, 2012, 05:46 PM
jofro is offline
Joined Jan 2010
Hi Neil, great value at 685 for kit if this size, I believe there is distr. in US, J.
Thanks Rodger, left of the pic are the bottom fuse subwings like on "Falcons" which I won't attach, grounding them off on every take off and landing and still might fit small supplied fins to the wings, Regards J.
Old Apr 27, 2013, 06:57 PM
jofro is offline
Joined Jan 2010
After my horrifying experience on Fri. flying my "Hawk" possibly due to dropped voltage in few cells I decided to mod my wing tips to improve the breed. J.
Old Apr 27, 2013, 07:13 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
That's.... a unique approach to solve an inherent tendency.
Without knowing exactly what spooked you, I can assume you got "bit" by a tip-stall scenario with your Hawk? I ask because there's more effective ways to help overcome that without even changing the tip shape... unless that piece is already glued on.
AceMigKiller is offline Find More Posts by AceMigKiller
Old Apr 28, 2013, 12:28 AM
jefffassbinder is offline
Find More Posts by jefffassbinder
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Tip Stall
Crow, it's what I use on my Hawk. Works great! Again without modification. But you May be looking for more lift. The N tech is pretty big, especially the fuse.
jefffassbinder is offline Find More Posts by jefffassbinder
Old Apr 28, 2013, 02:23 AM
Joined Jul 2004
Or some simple reflex. Both work awesome!
But I do like using crow on short field approaches.
Old Apr 28, 2013, 04:09 AM
jofro is offline
Joined Jan 2010
After static test today using the same batteries I got only 5.5kg but 7.8 with other pack I used in F9. Some serious drop in voltage due to few sussy cells in two packs out of 4 didn't help. Mate, I did a good kilometer radius circuit to bring it down in one piece! Any 12+kg EDF jet will have a tendency of t/stall at only some 60% of normal power after rotation, J.
Old Apr 28, 2013, 04:29 AM
jofro is offline
Joined Jan 2010
Guys, I can assure you there's nothing to beat my good old trick to make overweight EDFs fly better. It looks better and flies superiour with simple mod like this. 80 inch span now. Forget about crowing and reflex, get it inverted and and you know what I mean, J.
Old Apr 28, 2013, 01:18 PM
Joined Jul 2004
Don't get me wrong, not knocking on your ability or ingenuity... I'm all for creative solutions.
I was just curious on the Hawk, an airframe that many of us are pretty well versed in, what your approach was with your wingtip mod.
Glad you got it back down in one piece after that power problem on takeoff!
Old Apr 28, 2013, 06:46 PM
jofro is offline
Joined Jan 2010
Hi mate, if you check out the wing size of any "Reaction" or Boomerang" series jets you get the idea why they are so popular, J.
Old Apr 28, 2013, 06:57 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Where are the wing fences????
Jo if you slow a swept wing down too much you will end up with the flow separating and running down the leading edge, the air picks up speed as it runs down the LE and no longer flows over the wing providing lift. Having the wingtips behind the CoG exacerbates things and induces a very nasty fast stall.
Rather than adding ugly wingtips to what is a beautiful plane, why not remedy the problem the same way BAE did by adding the easy stuff, 2 large wing fences and some vortex generators.
Some reading:
http://navyflightmanuals.tpub.com/P-1231/P-12310054.htm
http://navyflightmanuals.tpub.com/P-1231/P-12310056.htm
http://navyflightmanuals.tpub.com/P-1231/P-12310048.htm
Extreme_RC is offline Find More Posts by Extreme_RC
Sold BAE HAWK (Fiberglass Version) 90mm EDF Plug N Play 49" wingspan!!! Retracts!!! rc4u Aircraft - Electric - Jets (FS/W) 14 Sep 14, 2012 02:32 PM
Sold BAE HAWK (Fiberglass Version) 90mm EDF Plug N Play 49" wingspan!!! Retracts!!! (RTF) kclements Aircraft - Electric - Jets (FS/W) 21 Sep 03, 2012 11:26 PM
For Sale NIB BAE E-Flight BAE Hawk (price lowered) dmize Aircraft - Electric - Jets (FS/W) 8 May 10, 2012 08:44 AM
Question Jet Legend BAE Hawk Turbine->EDF Conversion? neversommer Electric Ducted Fan Jet Talk 4 Apr 21, 2012 10:52 PM
