Old Oct 10, 2012, 01:00 PM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
oh man...if you coulda been quicker you coulda sucked the magic smoke up and blown it back into the ESC within 5 seconds of release and it would have been fixed...oh well, proper magic smoke reintroduction techniques sometimes evade us in the heat of the moment
sloperjoe is offline Find More Posts by sloperjoe
Old Oct 10, 2012, 02:39 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
So true...you know what they say, "when in fear, when in doubt, run in circles, scream and shout"
Lt599 is offline Find More Posts by Lt599
Old Oct 12, 2012, 06:53 AM
TANGOSIERRAROM is offline
Find More Posts by TANGOSIERRAROM
James L
TANGOSIERRAROM's Avatar
Beck Row Mildenhall
Joined Mar 2009
When ESCs come from the factory the settings are in their default setting. However the throttle end points are not set until you programme them in. Some might be close to your tx's signal so are pretty close others can only be set to give about ffty percent power when your tx is at full throttle. the manual should tell you how to do this.
TANGOSIERRAROM is offline Find More Posts by TANGOSIERRAROM
Old Oct 12, 2012, 07:44 AM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
I have never had to program throttle end points on an ESC? I have programmed braking, starts, and cut offs. I tried to find some info on this online but found nothing for this ESC. The ESC's did not come with any paperwork and there was no mention of that programing function in the online manual from HK? I was trying to reset default (just to see) when the one smoked I still have the other one, maybe I could get it to work if I had more info
Old Oct 12, 2012, 10:58 AM
thedeuce is offline
Find More Posts by thedeuce
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
The way I did throttle end points with mine was. Turn TX on, set throttle to full, plug in RX battery/ESC lipo then wait for the beep from esc to let you know that it has been received. Set throttle to off to arm system.
Hope that helps.
thedeuce is offline Find More Posts by thedeuce
Old Oct 18, 2012, 02:02 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
deuce, thanks for the info. I will try that infact in the directions with my new esc's it tells you how to set the throttle points just like you said. I have the airframe assembled and am in the process of sanding the WBPU/talc to get ready for paint. I tried using the spray poly but after sanding it and shooting a light coat of primer it did not turn out nearly as smooth as I would like so I went ahead and applied poly/talc with a brush. I will post some pics later.
Old Oct 18, 2012, 06:02 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Greg, I don't think I've ever did a throttle range set on an esc, unless I'm programming the other functions, which most of the time I do. Spray poly is not all that smooth, I use it sometimes for a final protective coat.. Applying with a brush comes out much smoother. Good luck! W
Waltjg is offline Find More Posts by Waltjg
Old Oct 18, 2012, 11:03 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Thanks Walt, I tried what sloperjoe and some others have done by sanding my foam smooth, up to 400 grit, then using the spray to seal it. I think the only way it works is if you spackle the entire airframe first as a fill. Anyway I just applied the poly/talc with brush and sanded. It turned out fine. It was a bugger sanding with the plane assembled. Im in the process of painting the main color now (grey) then I will install edfs and electrics before any detailing.
Old Oct 19, 2012, 01:42 PM
sloperjoe's Avatar
Joined Mar 2012
WOW! that is lookin very nice, the weight looks really good too!
Joe
Old Oct 19, 2012, 05:01 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Great looking Greg!!! Are you going to maiden before paint and finish? W
Old Oct 19, 2012, 05:08 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Walt and Joe, thanks guys, no maiden with the weather we are having so I will keep painting and detailing (I know I said that would maiden first) I will however maiden the first decent break in the weather of course around here I might have 3 more planes built by that time Hows the weather down south Joe?
Old Oct 20, 2012, 03:50 AM
sloperjoe's Avatar
Joined Mar 2012
today was dry early in the day but nasty windy big time, must've been 35mph gusts with a steady 20-25mph wind, trees were really swirling, there wasnt a snowballs chance to fly today, supposed to be a bit better tomorrow....the weather forcasts around here have about a ten minute lifespan though
Joe
Old Oct 20, 2012, 07:59 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
It might be just me,i might just be jinx'd.
When i finish a model in its entirety, then attempt a maiden, they always hit terraferma.
Now when i throw the ugly monstrosities naked they all come home fine.
So ive learnt my lesson, they all get maiden before any detail work is done.
I wont even sand the last coat of resin/microballoons untill its proven itself flight worthy.
Then again i know what its like, just having the bird sitting on the bench all naked while i wait for better weather.
Best of luck with the maiden.
PS. Do you use both magnets? i normally will use one in the fus, then a piece of light metal in the hatches. saves a few grams in weight anyways. For my metal i use a piece of the break away razors very light.
D_FAST is offline Find More Posts by D_FAST
Old Oct 20, 2012, 01:37 PM
Stevercflyer is offline
Find More Posts by Stevercflyer
United Kingdom, England, Trowbridge
Joined Sep 2012
After the maiden when it is debugged, will you be posting a pdf ?
Stevercflyer is offline Find More Posts by Stevercflyer
Sold A10 cr Modified Twin 70mm Flown once RC Lander Gear LPU Edwards Rc Aircraft - Electric - Jets (FS/W) 5 Oct 11, 2012 09:01 PM
For Sale NIB Skyangel 50mm & 35mm EDF Jet Airframes L39 Blue Angel A4F F22 T45 F15 A10 F16 F18 www.hobbyb.com Aircraft - Electric - Jets (FS/W) 10 May 25, 2012 11:48 AM
For Sale Skyangel 35mm & 50mm EDF Jets F15 Mig29 A10 T45 JAS39 Mirage2000 **Free Shipping** www.hobbyb.com Aircraft - Electric - Jets (FS/W) 0 Apr 29, 2012 12:57 PM
For Sale Skyangel 35mm & 50mm EDF Jets F15 Mig29 A10 T45 JAS39 Mirage2000 **Free Shipping** www.hobbyb.com Aircraft - Fuel - Jets (FS/W) 0 Apr 29, 2012 12:51 PM
Discussion F15 twin 50mm pmpjohn Foamy EDFs 11 Apr 14, 2012 03:07 PM
