Old Sep 27, 2012, 08:02 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
HHAEFI,,, Hodges Hobbies All Electric Fly In ,,, Hodges Hobbies is where SEFF is held every year,, a great shop and super great flying field!! And the people are alot of fun too! Should be a good time, I'm looking forward to it. w.
Waltjg is offline Find More Posts by Waltjg
Old Oct 06, 2012, 09:50 AM
bamiller is offline
Find More Posts by bamiller
bamiller's Avatar
United States, CO, Castle Rock
Joined Dec 2009
How goes the build Greg?
bamiller is offline Find More Posts by bamiller
Old Oct 07, 2012, 01:18 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Same as you Brent, I had a slow down but I am getting back on it this weekend. Greg
Lt599 is offline Find More Posts by Lt599
Old Oct 08, 2012, 04:58 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
nice mounts Greg!
I was wondering how you were gonna do that
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Oct 08, 2012, 03:34 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Looks great Greg!! DS foam? And the 146watts,,, that is per fan right?... W
Old Oct 08, 2012, 06:17 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Sorry, DS is Dollar Store Thats an interesting point about the watts. When I got these numbers I had both fans running together off of 1 batt. I had a splitter from the battery to the ESC's, a Y connector for the Rx with the red wire removed on one side for the BEC. Those numbers would reflect only one fan??? I wonder if my meter will not recognize the twin set up? except the meter was plugged in between the batt. and the Y off to the two ESC's. I will have to run one set up single and see. You would think that the meter would not be able to tell the difference. It should be reading what ever the draw is going through it.
Old Oct 08, 2012, 08:21 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Ok I ran one of the fans alone. On a 3s 2200 20c the meter was reading 78 watts at 6.6 amps. So I guess those where total numbers. 6.6 amps is nothing. On the specs for the motor/fan it states up to 18 amps? It does not give watts. I have been assembling the A10 and right now after hinging, finishing the motor mounts and nacelles Im at a total airframe only weight of 6.4 ounces. From everything I have seen these little fans will put out about 1 lb of thrust each. I am not using any efflux tube, dont need speed. I guess we will see what happens
Old Oct 09, 2012, 02:21 AM
sloperjoe's Avatar
Joined Mar 2012
hmmmmmm....6amps doesnt sound right..the 20amp ESC's I run will get real warm fairly quickly on a bench test at full throttle so I can only think they must be pulling close to the ESC limit, dont have an amp meter so I cant say for sure.
I do remember a few folks having trouble with the 30amp RedBrick ESCs, the 2 20amp RB's I have work awesome, so I dont know.. 6amps is an awefull low pull for those fans though, if your thrust and eflux are good then there probably isnt anything wrong but maybe an erroneous amp/watt reading...?
I was thinking like Walt, the 148watts and 13amps were from one unit, that would be more like it..
Joe
Old Oct 09, 2012, 01:03 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
It did not seem right to me either. I am going to run one of the units on a different 20 amp ESC that I have and see what it shows. I am going to static thrust test them also and see what kind of numbers I get. Something seems fishy!
Old Oct 09, 2012, 05:38 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
ESC question
Ok guys, I did some bench testing and I have a question. I ran one fan on a 20amp esc that I have and I got good numbers 15amps with 146 watts. On both the Red brick 30 amp esc's I am getting half of that 6amps with around 75 watts! One thing I noticed is on the Red bricks I have to change the polarity going to the motor to get the fan to spin the proper direction, not so on the other ESC. I have not tried switching the polarity on the battery side of the Red Brick ESC yet. I do not know if this would account for the minimal outputs Im getting or not??? Any input out there would be great. Greg
Old Oct 09, 2012, 06:41 PM
TANGOSIERRAROM is offline
Find More Posts by TANGOSIERRAROM
James L
TANGOSIERRAROM's Avatar
Beck Row Mildenhall
Joined Mar 2009
Sounds a bit like the Esc throttle points have not been set properly on the 30 amp escs.
TANGOSIERRAROM is offline Find More Posts by TANGOSIERRAROM
Old Oct 10, 2012, 02:06 AM
sloperjoe's Avatar
Joined Mar 2012
oh lord dont switch the battery side....ESC's dont like that...it will let the "magic smoke" out that makes em work.
Joe
Old Oct 10, 2012, 08:14 AM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Joe
Don't listen to him. DO IT DO IT DO IT...
J/king dont do it.
Hope you get it all figured out.
D_FAST is online now Find More Posts by D_FAST
Old Oct 10, 2012, 08:50 AM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Didnt get the chance to switch the batt side, one of them let out the "magic smoke" all on its own when I hooked them both up again and was going to try to reprogram them to facory default. but it doesnt matter, the other one wont accept the programming??? I canned them and ordered different esc's For 6 bucks( or what ever they where) I wasnt going to stress it, ordered the Dynam 30amp's. I know I do not need 30 amps but the difference was only 2 grams in weight, they should be here in a couple days. Greg
On second thought, they just came from the factory!!! shouldnt they have been at "factory default"
Sold A10 cr Modified Twin 70mm Flown once RC Lander Gear LPU Edwards Rc Aircraft - Electric - Jets (FS/W) 5 Oct 11, 2012 09:01 PM
For Sale NIB Skyangel 50mm & 35mm EDF Jet Airframes L39 Blue Angel A4F F22 T45 F15 A10 F16 F18 www.hobbyb.com Aircraft - Electric - Jets (FS/W) 10 May 25, 2012 11:48 AM
For Sale Skyangel 35mm & 50mm EDF Jets F15 Mig29 A10 T45 JAS39 Mirage2000 **Free Shipping** www.hobbyb.com Aircraft - Electric - Jets (FS/W) 0 Apr 29, 2012 12:57 PM
For Sale Skyangel 35mm & 50mm EDF Jets F15 Mig29 A10 T45 JAS39 Mirage2000 **Free Shipping** www.hobbyb.com Aircraft - Fuel - Jets (FS/W) 0 Apr 29, 2012 12:51 PM
Discussion F15 twin 50mm pmpjohn Foamy EDFs 11 Apr 14, 2012 03:07 PM
