Well done Sonnier! Well done!
I am stunned the 16mhz version works at all to be honest. Here is the entire build blog OlliW did here at RCgroups that will walk you right through this stuff, Keep in mind it was my first run through also and my first attempt at programming anything with few computer skills to boot. So I think I encountered every problem there is. lollz... http://www.rcgroups.com/forums/showt...=ultim+gyromix Now I am also using this from HK. But they are out at the moment it seems. http://www.hobbyking.com/hobbyking/s...dProduct=21321 |
that is the same UBSaps I'm using can that be used to talk to the gyromixer after it's made though the b motor lead? |
Joined Sep 2009
Hey Sonnier,
I am a bit confused as regards the status of the coax mixer, is it working or isn't it? (in your second-last post it first sounded as it did and in the last sentence as if it doesn't). I wouldn't find it satisfying if it still wouldn't work... I tend to be persistent on such matters and would be glad if we would continue to work together on getting it to run properly.I mean, you have done a great job and everything looks very well done, so - I am confident - the problem is just a tiny little bugger somewhere, which is just not easily spotted. The 16MHz is certainly a problem, and it would be easier if I would have also a 16 MHz version... but that's exactly what I find interesting to figure out. Cheers, Olli BTW: with the USBasp the correct setting in AvrBurnTool v001 in the first entry line is USBasp and not other choice, as you figured out yourself. BTW: no, the USBasp unit can NOT be used to talk to the coaxmixer or the GA250 gyromixer after having been flashed. For both you need e.g. this unit http://www.hobbyking.com/hobbyking/s...roller_5V.html, and have to build the connecting cable using the resitor (and mabye a diode). (Luv, as compared to then we started a year ago or so, hasn't this item become incredibly cheap? Thx, HK!)
Ok
Olliw we will fix the comixer I'm the same Olliw I do like to finish what i start. When I flash the mini pro I get leds flashing on the usb and the mini pro. The burn tool shows it writing taken the burn but when I connect the heli it dose not work. I have this unit http://www.hobbyking.com/hobbyking/s...roller_5V.html also. |
Olliw,
well i just burn it again got the same reaction as i did the first time with the leds as it was flashing the unit see pic I put the unit in the heli and powered up steady blue led steady green 1sec slower blink i-2sec faster blink 2sec then steady green led and BINGO THE HELI WORKED ![]() ![]() ![]() the third pic is what i will need to talk to the unit right |
Joined Sep 2009
CONGRATS
great job, glad it works now. Do you have any idea what was going wrong before? It seems that thre is a minor pitfall somewhere in doing this, and I would love to know... ![]() Quote:
BTW: for the coaxmixer and the GA250 gyromixer you don't need this additional resistor you were talking about in the baove. You also don't really need the switch and teh attached power plug which you see in the photo. The only thing youreally need is the USB-FTDI adapter and one servo cable with a female plug. Solder then the black/brown ground line to GND at the USB-FTDI adapeter, and the white/orange signal wire to the RX and TX pads (which you electrically connect) at the USB-FTDI adapter. |
E2 sent his suggestion for a motor to use did you see them. I am going to use the http://www.ebay.com/sch/i.html?_from...r+for+Mini+E.P what do you thank? |
The fact you toasted the garbage C10 motors isn't a mystery as they often times used aluminum composite wiring instead of copper. The 1811-2900 motor you pm'd me about is the preferred motor to use. Not sure about its exact KV since I run mine all on 3s. The trick is letting them breath with some airflow over the cans and they stay cool. The ones E2 linked he still hasn't tried them yet to my knowledge.
The required rpm changes from heli to heli depending on weight, blades, and flight conditions. I recently had my best results (other than my dual swashed versions) using heavier helis with cheapo china white blades and running 3s 1000ma batts. The OlliW gyromixer is locked in on mine! I fly it fast instead of hovering around. Outstanding work here! |
Joined Sep 2009
Sonnier, sorry, missed your last post
will be interesting to hear your experience with them |
Not that it maters but do you if they need to be drilled and taped? |
| Thread Tools | |
| Discussion Newbie please, need some advice Co Pilot II or Co Pilot CPD4 | bambino | FMA Direct | 2 | Aug 17, 2012 11:37 PM |
| Build Log Co-CO Lama Eye In The Sky Build. | DmanRC | Coaxial Helicopters | 4 | Jan 31, 2007 04:54 PM |
