5184783!Introduction
| Wingspan: | 15.3 inches |
| Weight: | 1.16 oz. |
| Length: | 12.5 inches |
| Transmitter: | AnyLink 2.4GHz radio adapter and a compatible transmitter |
| Receiver: | 2.4 GHz, AnyLink compatible |
| Flight Battery: | 3.7V 140mAh LiPo battery |
| Battery Charger: | DC LiPo battery charger |
| Batteries for Charger: | 5 AA batteries included |
| Manufacturer: | Flyzone |
| Available From: | Fine Hobby Stores Everywhere |
| Price: | $79.99 |
I enjoy flying biplanes and I have flown and own the first two Flyzone World War I models. I have found both the Albatros and the Fokker Dr-1 to be good flyers that I have flown outside in calm conditions and inside in my club's winter gatherings at the county fairgrounds. So I was very interesting in reviewing the new Nieuport 17 and adding an allied fighter to my collection of planes. For this review I have flown the plane multiple times and I have let several friends fly her as well. In the final video below you will see at least one of the grass tumble landings made with the Nieuport 17 and she remains undamaged thus far. In fact of my three Flyzone WWI fighters only the Fokker Dr-1 has had any damage and that just required gluing the landing gear under carriage back on one side of the fuselage.
Kit Contents Tx-R Nieuport 17
I supplied
The Nieuport Aeroplane company made a number of fighter planes that were flown by the French and British in World War I. The various models were identified by number. The Nieuport 11 was also know as the Bebe and had a machine gun mounted on the top wing to clear the propeller. It was one of the planes that helped end the Fokker Scourge early in 1916. When they gave it a larger motor they changed the designation to Nieuport 16 but it had balance problems with its Center of Gravity and they went back to the drawing boards and came up with some modifications and named it the Nieuport 17. In addition to its more powerful engine it had larger wings and an improved fuselage. It had a single machine gun initially on the top of the wing but on most planes that was replaced with a single Vicker's machine gun on the fuselage in front of the pilot with a synchronized gun. A second machine was tried but was found to make the plane too heavy.
When first introduced into combat in March 1916 the Nieuport 17 was considered to have outstanding maneuverability and an excellent rate of climb. It was first equipped with a 94 horsepower engine and later a 110 horsepower engine. By the end of 1917 its days as a front line fighter were over for the French but the British flew it longer. It was a sesquiplane as it had a full top wing with two wing spars and a narrow chord bottom wing with only one spar. In combat it was learned that the Nieuport 17 had a disconcerting tendency to disintegrate in a sustained high speed dive. In was followed by the Nieuport 24 but most pilots switched to the Spad S VII as an improved replacement plane. But in the summer and fall of 1916 it was a leading allied fighter.
The Nieuport 17 came fully assembled. There was no assembly that I had to do to fly the plane. I only had to install the five supplied AA batteries into the battery charger and charge the included 3.7 Volt single Cell 140 mAh battery. However they did supply a pilot made out of white foam and I did paint him with my enamel paints while he was stuck on a toothpick. When the paint was dry I glued him into the cockpit using foam safe CA. So far I have not added a scarf but I may in the future as both of my German pilots have scarfs.
The Nieuport 17 is a three channel plane with throttle, elevator and rudder control. Depending on what transmitter you decide to use the rudder control may be on the left stick, the right stick or you might get to choose which stick or both for the rudder. Using the AnyLink 2.4GHz radio adapter I can choose from a variety of my transmitters. My old simple four channel transmitters will have the elevator on the right stick and the throttle and rudder on the left stick. With my modern programmable transmitters they have ailerons on the right stick and rudder on the left stick. By programming a rudder/aileron mix at 100% I have rudder control on both the right and the left stick for the Nieuport 17. It is very easy to do just decide which stick you want to use to control the rudder. I and most of my friends are most comfortable with rudder and elevator on the right stick as we fly two channel gliders that way. However, I do like to use the left stick to add rudder to my power planes which I turn primarily with ailerons so I enjoy flying the Nieuport 17 either way but my sharpest control is with rudder and elevator on the right stick.
I was supplied with Tx-R (transmitter ready) version of the Nieuport 17 for use with the AnyLink radio adapter and I will discuss that in more detail below. However, I have three transmitters from Flyzone planes already in my possession that I decided to try with the Nieuport.
The Flyzone Dr. 1 came with the Tactic TTX402 transmitter which is the same one that comes with the RTF version of the Nieuport 17. Not surprisingly it binds and controls the Nieuport with both the rudder and elevator on the right stick and throttle on the left. If I want to move the rudder to the left stick I just hold the sticks in the upper outer corners as I turn on the transmitter and the left stick controls the rudder. Turn the transmitter off and next time I turn it on the rudder is back on the right stick unless I hold the sticks in the upper corners again.
My Flyzone Focke Wulf FW-190 Select Scale came with the Tactic TTX600 and transmitter has worked with all of the previous AnyLink planes that I have flown including the little Sabre jet. It also bound with and controlled the Nieuport 17 but the rudder was on the left channel as is normal for most four channel radio systems here in North America and the elevator was on the right channel. I had no trouble flying with throttle and rudder on the left stick nor did fellow author Dick Andersen who helped with the media for this review. But several other friends had trouble adjusting to having the main turning control on the left stick.
My first Flyzone World War I era plane was the Flyzone Albatros and it came with its own little transmitter which was before they came out with AnyLink. While it does a great job controlling my Albatros it did not bind with my Nieuport. The original little transmitter version of the Albatros will not bind with the Nieuport. NEWER versions of the Albatros contain the SLT protocol and the current RTF versions come with the Tactic TTX402 transmitter that is compatible with the Nieuport.
My version of the Nieuport 17 came with a receiver board designed to be used with the AnyLink 2.4GHz radio adapter. The AnyLink Adapter has been out for a number of months now and if you are familiar with it I recommend you skip ahead to the flying Basics section. The Tactic AnyLink allows me to fly my Nieuport 17 with it's receiver board directly with a Tactic transmitter as described above or with almost any transmitter out on the market. This includes transmitters that were originally on FM and transmitters made by: Futaba, Hitec, JR, Spektrum and Tower Hobbies. The instruction manual discusses doing a 50 foot range check but I have fully tested a range of about 150 feet outside without any problems. As small as she is I seldom fly more than about 120 feet away from myself maximum.
No binding instructions came with the Nieuport 17. The instructions that came with my AnyLink were for planes with normal size receivers with a binding button to push in. The method described below is my modification from the AnyLink instructions.
The Binding Process
AnyLink: http://www.tx-ready.com/anylink-chart.html
Replacement Parts
As discussed above in connection with the transmitter selection the Nieuport 17 is a three channel plane with throttle control, elevator and rudder control. The rudder and elevator should be in the neutral positions before the first flight. The Nieuport 17 will fly nicely on half throttle. Flight duration can be up to about 10 minutes in calm conditions at low throttle and over six minutes if flown at full throttle for most of the flight. I like to mix up my speed as it makes my full speed runs seem faster to me. The Nieuport 17 is responsive to even small stick commands so I can fly her in a nice controlled fashion or a bit wild when I am in mock combat.
Flights can be started with a small toss into the breeze or by taking off from a hard surface. We have flown the Nieuport from a soft dirt infield with the dirt smoothed out by foot and take-offs have been no problem. I would not try and fly from tall grass or thick carpeting. Landings are more difficult and it is unfortunately all to easy to nose over landing in the soft dirt infield. My best results have been landing with some power on into the wind on a hard surface. Upon touchdown I lower the throttle and apply some up elevator to help hold the tail down. If landing with power off I recommend giving a slight flair at the last second before touchdown. Slight power on as stated above has worked best for me but be ready to kill the throttle on touchdown, especially if she tips forward.
Aerobatics are somewhat limited with only three channel control. That said; she can perform an acceptable loop when I start with full throttle and a slight dive before pulling up on the stick to perform the loop. Also barrel like rolls are possible with practice starting with a slight dive at full throttle followed by full up elevator and hard rudder to the side of your choice after she has almost reached what would be the first quarter of a loop. Some attempts turn out pretty good, some miss for reasons as yet unknown to me, but even the failed attempts are fun. Inverted flight at the top of the loop is possible for the good or lucky pilot. The most fun is to have a friend with another Nieuport 17 or the Flyzone Albatros or Dr-1 to fly with be it pattern flying or mock combat. In mock combat we have experienced some fairly interesting moves at full throttle and flying in a fur ball.
Biplanes with their two wings and struts might be a little more fragile then the available Flyzone small trainers but mine have had their share of abuse and are still flying fine. So while not my first choice for a beginner plane, if you have calm conditions or a large indoor space this could be a first plane.
The first three pictures were Dawn Patrol and the sun rose while the plane was in the air.
The Nieuport 17 flies a Dawn Patrol mission.
The Flyzone World War I planes: the Albatros, the Fokker Dr-1 and the Nieuport 17 fly together over Modesto.
The Nieuport 17 is a nice addition to the Flyzone lineup of World War I planes. It is another nice plane for those that like to fly little biplanes indoors or outside. The only labor involved was in painting the pilot and while no one will hire me for my pilot painting skills I did enjoy painting him and now I am looking for a colorful scarf for him. My plane turns a little more sharply to the left then the right but it turns well in both directions. It has flown in a breeze of up to five miles per hour and handled it well but I needed to use more throttle and so I got a shorter flight then usual as a result. I have a couple of one cell batteries and with the stand alone battery charger that came with the Nieuport 17 I can charge one battery while I am flying with another battery. This leaves very little down time if I want to keep flying. By leaving for work fifteen minutes early I can get in a flight at the local park before work and again at lunch on calm days. Practicing landings with the Nieuport 17 should improve my overall landing skills. It flies well for me, has taken some abusive grass landings at the hands of my friends and has been a fun flyer for those that have had some stick time with her. The geared motor is a bit noisy but it works fine. She is too much fun to save just for indoor winter flying but I look forward to showing her off in December at our first indoor event at the county fair grounds.
Pluses
Minuses
My thanks to my friends Dick, Kirk, Benard and Don for help with the videos for this review and thanks to our editor for her assistance. I want to thank Flyzone for supplying this plane for the review as well as the AnyLink 2.4GHz radio adapter.
| Thread Tools |
have you tried to put servos in them? rumor has it they fit the 1.25mm connectors from HK. like the hk5320 or hk282. i dont know. i hear these are tactic bricks. i want one, but if its only 3 ch...ugh. i had the same idea. im on the fence, either the 3ch mini vapor, or the nieuport 17.
some one must know! edit: seems this thread says you can put ailerons in the albattross http://www.rcgroups.com/forums/showt...1599536&page=3 right now towerhobbies seems to have the albatros for sale 39.99 with free anylink, and i got quoted 10 shipping. so a new plane shipped to me with anylink (got my turnigy 9x with open9x running!) for 58 with taxes y todo. not bad. i will see if the local hobby shop can do something similar. |
I was not able to sleep tonight so I am back from a little night flying by streetlight about an hour ago. While it is cold tonight in the low 40s there was no wind at all. Had a very enjoyable flying session with the Nieuport. I was a flying as slow as I have ever flown the Nieuport and trying to be as smooth as possible as I had to limit my range to keep her in sight by the light. Lots of trees near the street to avoid. I did fly too far away at one point and knew her last direction but couldn't see her. I turned her back by the sound of the motor and finally caught a glimpse or her and corrected her back on track by the light. No complaints from me about the noise from the gears.
Mike H
Latest blog entry: New receiver packs and asking Castle for...
| Thread Tools | |
| Discussion Micro Nieuport from Flyzone | Digital Don | Indoor and Micro Models | 90 | Mar 14, 2013 11:04 PM |
| Discussion Flyzone Micro Nieuport 17 | wattman | Micro RTF | 18 | Sep 15, 2012 04:44 PM |
| Discussion Flyzone Nieuport Binding | georgefromvt | Micro RTF | 12 | Sep 13, 2012 03:57 PM |
| Article E-flite Nieuport 17 250 ARF review | Spackles94 | Parkflyers | 83 | Nov 05, 2010 09:43 PM |
| For Sale 1/4 Scale Nieuport 17 Biplane Ready To Fly-SOLD! | GSAV8R | Aircraft - Fuel - Airplanes (FS/W) | 1 | Dec 06, 2006 03:48 PM |
