Old May 19, 2005, 10:44 PM
StrikeZone is offline
Find More Posts by StrikeZone
Joined Nov 2004
I thought about 2 cells also, how would I go about that, using the same approach as the duel wire feed to the EDF’s?
Two cells, that would add more weight
StrikeZone is offline Find More Posts by StrikeZone
Old May 20, 2005, 10:30 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
any good flights yet ???? Ours never flew worth (your word here)!!! Control surfaces???
gpw is offline Find More Posts by gpw
Old May 21, 2005, 10:23 AM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Not sure I understand the question? I'm using One 2s1p battery pack through one ESC, motors wired parallel.
Still thinking about control options- probably A/E with pull-pull.
rdeis is offline Find More Posts by rdeis
Old May 21, 2005, 11:00 PM
Joined Nov 2004
2 cells
In other words If have 2 GWS Ni-MH 750mAh 9.6v, one each to power the set of twin GWS EDF55-150. How would I go about doing that.
My control options will be as the B-2 by GWS.
Old May 21, 2005, 11:24 PM
Joined Nov 2004
I am only using the aileron for Flight control and the no elevator on the rear horizontal stabilizer, it’s already at a 45*. Tested this out on a small model size no aileron control surfaces, the rear horizontal stabilizer (elevator) set at 45* caused the plane to pitch up and loop. When I sling shot the model foamy. Then I added the Aileron on the wings to control the pitch & flew stable. I did a short taxi run on the larger size, it flew off the ground about 1.5ft in the air then it pitch right a little, before I droped the power. It's ready for flight.
Old May 21, 2005, 11:36 PM
RCWorks is offline
Find More Posts by RCWorks
RCWorks's Avatar
Joined Aug 2003
Two batteries, two motors...
Make sure the esc is enough to handle the needs of both motors. What ever you use for a single, double it.
RCWorks is offline Find More Posts by RCWorks
Old May 21, 2005, 11:46 PM
RCWorks is offline
RCWorks's Avatar
Joined Aug 2003
I used 1.25 inch aierons and the elevator was 2 inches of the back between the stabs.
It has not flown well either...
I am taking a new approach to the problem this year... I am cuttting it out of EPP, Spar it in flat carbon and using twin johnsons and LiPos... drop the weight, increase the power.
Old Jul 07, 2005, 03:00 PM
LRHann is offline
Find More Posts by LRHann
Wheaton, IL
Joined Nov 2004
Originally Posted by skunkworksrc
I am going to look around to see if there is any text for CG calculation of the diamond... I gave it my best shot and it looks like I am off a good 2 inches.
Skunk, here's a good thread on measuring CG: See post #7.
http://www.rcgroups.com/forums/showthread.php?t=359277
Lenn
LRHann is offline Find More Posts by LRHann
Old Jul 07, 2005, 08:12 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Skunk , I think you're gonna' have to use the ailerons and V-tail ... the elevator between the fins didn't work well for us on our profile .... tried everything else .... the A/VT seems to be the correct way to go ..... especially since nothing else worked .... Good Luck !!!
Old Jul 14, 2009, 07:24 PM
sixnone is offline
Find More Posts by sixnone
Crash and learn!
sixnone's Avatar
Joined Jul 2009
vt set-up
This could be my plane. Its the same set-up I have on mine. One thing I have thought about is not splitting/hinging the V-tail control surfaces. One day I will use all of the control surface and pivot it with a dowel.
sixnone is offline Find More Posts by sixnone
Discussion Foamie Yf-23 Black Widdow II corsair nut Foamy EDFs 36 Oct 29, 2006 12:42 PM
Discussion YF 23 Black Widow Eaglehawk752 Pusher Prop Jet Models 2 Sep 28, 2006 01:50 AM
Discussion Foamie Yf-23 Black Widdow II corsair nut Pusher Prop Jet Models 6 Sep 25, 2006 09:35 PM
Northrop/McDonnell Douglas YF-23 Black Widow II Esprit440 Pusher Prop Jet Models 12 Jul 31, 2006 12:47 AM
Yf-23 Black Widow Twin Midi Plane Crazy Electric Ducted Fan Jet Talk 23 Feb 08, 2005 03:25 PM
