Old Nov 29, 2003, 09:06 AM
RCWorks is offline
Find More Posts by RCWorks
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
The Start of my YF-23 Black Widow II Project
Also know as Relitivium Obscurus...
Only 2 of these planes were made for the Advanced Tactical Fighter competition for purchase by the U.S.A.F..
Neither of the 2 prototypes were fully complete, they lacked radar and weapons systems. One of them resides at an aircraft museum, the other I don't know about. But I assume it is in like condition to the museum piece... Lacking anything that could be reused elsewhere (Engines... etc.) and oxidizing quite well (Looking at the lower panels of the fuse in a walk around photo shoot.).
Gentlemen I give you my first proto of the YF-23 Black Widow II...
RCWorks is offline Find More Posts by RCWorks
Old Nov 29, 2003, 09:12 AM
RCWorks is offline
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
And one of the bottom
This one is showing the bottom, note the stiffeners are shaped like the jet intakes...
And to those viewing that might be wondering about my J-250 Powered ALL EPS P-51... I abused it, 3 packs in succession without a break... the motor failed mid way through the 3rd pack and ceased operation... but it was fun while it lasted. Valuable data was gleaned from the proto and will be incorporated into the new proto.
Old Nov 29, 2003, 11:29 AM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Skunkworksrc, which museum is displaying this prototype?
I thought the f23 had nicer lines than the winning Raptor (or is it in the eyes of the beholder?). Never did get a clear explaination what advantages the F22 had over the F23. Was it as clearcut as between the F32 & F35?
What power system do you intend to use?
Phil
PhilLin is offline Find More Posts by PhilLin
Old Nov 29, 2003, 11:47 AM
RCWorks is offline
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
I want to use an DD 020 but I do not have one. Nor an 010...
I am going to try my Zagi Pusher and KAN 1050s for this one.
If I like it I will try going from the 20 inch span to a 30inch and go to my Jeti 15/4 and 8 cells of CP-1300
This one is made from a 20x30 sheet of black sturdyboard.
If I get to a 30 inch verstion with the brushless I will add the cockpit in EPS as well as the top engine nacells and landing gear. If I use the Jeti I will be using a 7x4 prop
The 20 inch-speed 400 setup I will start with a 6x4.
If I can get a good supply of depron I would consider useing a GWS 350 C drive and an MP Jet on a 90x70 on a 30 incher
Someone I fly with was suggesting that I stick the wattage turbofan with the astro in between the stiffeners.
There are a lot of choices... but I have speed 400s, cobalts, grapner 480s, KAN1050s and CP1300s on hand
Since I got a 3 pack of the sturdy board I can play with the design.
I am open to other suggestions...
Old Nov 29, 2003, 11:51 AM
RCWorks is offline
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
From what I gather it was politics that doomed the YF-23 to death in the hanger.
The one I used for the walk around pics is at...
Wright Patterson AFB, Ohio
the link is
http://www.wpafb.af.mil/museum/research/fighter/f23.htm
The other bird is a mystery... but I assume it met a similar fate.
Old Nov 29, 2003, 11:55 AM
RCWorks is offline
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
On the JSF, the winner won because of superior design... the fan on the lockheed setup was better than venting jet exhaust straight down that the front of the plane, the latter contaminated the intake air so much that during lanings flame out could be a real problem, it would stall its own motors, whereas using a driveshaft and transmission to power the front lift fan kept the intake air charge clean and the engine running with perfect reliability.
Old Nov 30, 2003, 12:37 AM
RCWorks is offline
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
I have settled in on a Zagi Pusher motor with a 6x4 prop and 8 cells of KAN 1050 for the first R.O.G..
Flight controls...
I am going to go with Elevator and Ailerons, Both are generous in size and I expect no problems.
L.G. I have a set of landing gear from a Wattage F-22 that I will use on this bird.
As it stands... 555 reciever, CS-21 servos, Wattage 380AS ESC for the guts.
I will be useing KISS (Keep It Simple Stupid) design standards for the prototypes, after which I will add shape to it couresy of my CNC with an EPS cockpit and nacelles.
The goal of this project is to create a smal version 20x30 (260 sq in wing) and scale it to a large brushless version 40x60 (500+ sq in).
Pending any unforseen problems I will place the protos in the LHS for consignment sales. (I HOPE)
Old Nov 30, 2003, 10:41 AM
turaboy is offline
Find More Posts by turaboy
turaboy's Avatar
USA, VA, Centreville
Joined Jan 2003
The other YF-23A is at the Western Museum of Flight in Hawthorne, CA. I live very close, but have not made it out there yet!
Your version looks great so far!
turaboy is offline Find More Posts by turaboy
Old Nov 30, 2003, 11:37 AM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
You have an interesting plan. I intend to keep track of you progress. Please keep us posted.
Old Nov 30, 2003, 12:25 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
I was around the ATF program and watched all the events with great interest. I was a General Dynamics employee, then and we were part of the Lockheed/GD/Boeing team.
A lot of people claim politics in the ATF flyoff decision, but if you were close to it, you can see that politics were not a significant factor.
Both aircraft were damn good. Both sets of engines were damn good. The YF-22 got the nod because it was deemed to be less risk in its continued development than the YF-23, and was judged to be more flexible for future needs. (some question this attitude, since this was not part of the requirements at the onset). The YF-22 also demonstrated a greater maturity in design, as we were able to demonstate more of the attrributes of a operational aircraft (Missile launches, flight at high angles of attack, etc).
IIRC, there was some worry about the avonics and integrated systems on the YF-23 being even more complex and thus more problematic than those in the YF-22.
Despite the info on the USAF Museum web site, they do not have a YF-23 there. Where is the other one?
Lockheed Martin won every technical aircraft point in the JSF flyoff. Do a search on here for JSF and you will find a long discussion about it in the off topic forum.
I find it interesting that people always want to question why something won over another. If they like the loser, they assume it was politics or other factors and not any inherent shortcomings in their favored aircraft...
Thomas B is offline Find More Posts by Thomas B
Old Nov 30, 2003, 08:56 PM
RCWorks is offline
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
They stated in what I read that Northrop was having cost over runs and delivery problems with other aircraft that they had fallen from favor.
Old Nov 30, 2003, 10:17 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
While that certainly may have influnced attitudes, that was not the sole basis or even the largest factor of the decision.
Latest blog entry: 2014 events and travel
Old Nov 30, 2003, 10:39 PM
DaveGherardini is offline
Find More Posts by DaveGherardini
Central Illinois
Joined Sep 2002
So how are you going to rig that thing? Flying diamonds are a hand full but ha,,,thats the idea.... Elevons?, A/E? ele pusher i assume...well i just reread your posts and see its a/e, with pusher. Flat plate style wings,,,man this is different!!...It does have that YF23 look ...pretty cool.....
DaveGherardini is offline Find More Posts by DaveGherardini
Old Nov 30, 2003, 11:59 PM
Summer is offline
Find More Posts by Summer
Joined Jul 2003
Ailerons of course...
Summer is offline Find More Posts by Summer
Old Dec 01, 2003, 02:02 AM
RCWorks is offline
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
Well Dan and I took it out... a few minor mishaps nothing bad, we did however separate a wire on the speed controls side of the Deans connector...
I am going to look around to see if there is any text for CG calculation of the diamond... I gave it my best shot and it looks like I am off a good 2 inches.
It did get the usual ooooos and ahhhhhs that my strage stuff always gets, but the Evil Kanevil show that we gave was just not my cup of joe (Hey, no tea drinker here.). I will repair the wire and try another run at it at lunch tomorrow.
Hey at this level..."You want to play your gonna pay." I love the challenge of late model military hardware... when you get it right and it flies and you have the only one... But there is the humility factor of early testing... Sometimes you get the bear sometime it gets you. This however has been probably the worst first outing I have ever had and still it did not result in the loss of plane. So I can still hold my head up high. I have yet to see a R/C kit of the YF-23.
Discussion Foamie Yf-23 Black Widdow II corsair nut Foamy EDFs 36 Oct 29, 2006 12:42 PM
Discussion YF 23 Black Widow Eaglehawk752 Pusher Prop Jet Models 2 Sep 28, 2006 01:50 AM
Discussion Foamie Yf-23 Black Widdow II corsair nut Pusher Prop Jet Models 6 Sep 25, 2006 09:35 PM
Northrop/McDonnell Douglas YF-23 Black Widow II Esprit440 Pusher Prop Jet Models 12 Jul 31, 2006 12:47 AM
Yf-23 Black Widow Twin Midi Plane Crazy Electric Ducted Fan Jet Talk 23 Feb 08, 2005 03:25 PM
