Old Sep 27, 2012, 06:41 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Sweet project! Ignore the haters; they're just jealous. None of them want to try taking on a project this big, so they belittle the efforts of those who do.
What construction method are you planning for the wing?
Piece is offline Find More Posts by Piece
Old Sep 27, 2012, 07:43 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Thanks C4h10 Nice to see someone not being negative welcome aboard..
The wing construction technique will consist of a hotwired Blu-foam core and balsa sheeting epoxied onto the foam core and then fitted with balsa leading edges and Then A nice Juicy carbon spar to hold it together
K
Keenan smith is offline Find More Posts by Keenan smith
Last edited by Keenan smith; Sep 27, 2012 at 07:45 AM. Reason: Correcting capitalizations..
Old Sep 27, 2012, 07:57 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
Interesting. Gonna take a lot of balsa and epoxy to do that whole wing. How much are you estimating the wing to weigh once it's complete (with servos/finish/hardware), and what thickness/area/density of individual balsa sheets will you be using?
Old Sep 27, 2012, 08:13 AM
Joined Dec 2010
About 800g-900 per wing or so ill probably use 3/32 contest grade balsa sheets
K
Last edited by Keenan smith; Sep 27, 2012 at 08:14 AM. Reason: Capitalizations .. again
Old Sep 27, 2012, 08:18 AM
Joined Dec 2010
Originally Posted by G-Forced View Post
Go back to watching playschool little man ! We build and fly here !
Wow your such a big man! only Bullies pick on people younger than themselves... and usually its because they have they own insecurities to deal with
Now can we P..Lease remain on topic ...
K
Old Sep 27, 2012, 08:25 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
800-900g? Are you only sheeting one side of the wing? Doing both sides, your balsa sheeting alone will weigh around 1.2-1.5lbs.
Old Sep 27, 2012, 08:28 AM
Joined Dec 2010
i mean 800-900g dry I'e without servos and finishing im expecting about 1100g finished per wing
and yes im sheeting both sides..
K
Sorry for the confusion..
Old Sep 27, 2012, 08:32 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
Cool. What airfoil section are you using? This is neat...
I sort of ask a lot of questions
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
And the cracks in your belief start....
Tonystott is offline Find More Posts by Tonystott
Old Sep 27, 2012, 08:35 AM
Joined Dec 2010
Questions are fine...! ( i ask alotof questions myself but that how you learn
Im going to be using an SG6041 Airfoil
See below (its a glider airfoil)
K
Old Sep 27, 2012, 08:38 AM
Joined Dec 2010
Well Sorry But i used to Work in Pounds and Ounce and Have been Forcing myself to use the metric system as its Simpler.. (so that may explain the Slight underestimate aswell as a small mis-understanding
now as said earlier please stay on topic
K
Old Sep 27, 2012, 09:00 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
Yeah, nothing wrong with simple errors, eh? Everyone's done it.
How did you calculate the weight of the finished wing panels?
Old Sep 27, 2012, 09:11 AM
Joined Dec 2010
it was just guesstimate For the Time Being..
Old Sep 27, 2012, 12:03 PM
fallingdown is offline
Find More Posts by fallingdown
United States, OR, Portland
Joined Apr 2011
K
Haha! You're supposidly from Great Britain but you're used to using pounds/ounces... You're an American! Although I still think the funniest give-away is the 17 foot wingspan, lol.
fallingdown is offline Find More Posts by fallingdown
Old Sep 27, 2012, 12:14 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
When I gave my examples of a balsa sheeted foam wing, I was using white 1 pound expanded polystyrene foam, not 2 pound extruded foam. You might reconsider the guessed weight to be closer to 20-25 square inches per ounce at this scale... maybe even less (I haven't put the numbers to a calculator yet). The foam has a way of adding a lot of weight as scale increases, due to higher ratio of extra internal cubic fill-space as square inches increase. You might be better off using a hollowed out core instead of a solid core.
Gary Warner is offline Find More Posts by Gary Warner
Discussion 1/5 scale FPV MQ-9 Reaper and Soon Autonomos flight Keenan smith UAV - Unmanned Aerial Vehicles 9 Mar 19, 2013 05:07 PM
For Sale MQ-9 Reaper 98" 7-CH Brushless Remote Control RC UAV Predator/Drone Airplane ARF Kit Rattler767 Aircraft - Electric - Airplanes (FS/W) 5 Sep 23, 2012 12:30 PM
Discussion 5M MQ-9 Reaper For FPV and Soon Autonomos flight Keenan smith Scale Kit/Scratch Built 3 Sep 12, 2012 10:46 AM
For Sale Re-list MQ-9 Reaper 98" UAV Predator/Drone Airplane Rattler767 Aircraft - Electric - Airplanes (FS/W) 2 Sep 03, 2012 03:45 AM
Discussion Any Mq-9/Mq-1 Reaper/Predator foamie builds? Remy130 Foamies (Scratchbuilt) 4 Aug 23, 2012 01:50 PM
