Old Oct 15, 2012, 04:35 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
I say this thread is suddenly a lot more interesting now that you are trying to figure out how to make this thing actually fly . Perfectly successful is boring.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Oct 15, 2012, 04:54 PM
Diceman89 is offline
Find More Posts by Diceman89
Ultrabatics enthusiast
Diceman89's Avatar
United States, CA, San Jose
Joined Aug 2012
Agreed
Diceman89 is offline Find More Posts by Diceman89
Old Oct 15, 2012, 05:26 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Originally Posted by Diceman89 View Post
Just try the dolly!
Or launch from a cradle plane....
A10FLYR is offline Find More Posts by A10FLYR
Old Oct 15, 2012, 07:30 PM
Diceman89's Avatar
Joined Aug 2012
Ya, attach it to the top of a plane like the space shuttle and build in a release. Lol. Just kidding, would be cool though.
Old Oct 16, 2012, 06:58 AM
philkiteflyer is offline
Find More Posts by philkiteflyer
KISS_KeepItSimpleStupid
philkiteflyer's Avatar
Invercargill, New Zealand
Joined Nov 2006
I have done that with a 2m glider, but the cradle produces more drag than actually towing the plane, so the tug needs to have plenty of power.
Phillip C
philkiteflyer is offline Find More Posts by philkiteflyer
Old Oct 16, 2012, 10:30 AM
birdofplay is offline
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Tons of aero tow advice and assistace here ...
http://www.rcaerotowing.com/
birdofplay is offline Find More Posts by birdofplay
Old Oct 16, 2012, 11:24 AM
Nodd is offline
Find More Posts by Nodd
Build something.
Nodd's Avatar
United States, CT, Fairfield
Joined Mar 2012
The guys over at RCAerotowing have been giving me lots of support. They're all into this build too. I actually fly with a few of the RCAerotowing founders, so I'm in good hands. Yeah if you're interested in aerotowing, that's the place to go for sure.
We played around with piggy back cradles back in the '80s. We had a Telemaster 40 setup for hauling two meter gliders atop its wing. Although it worked okay we ended up going back to using the high-start, it was just simpler but not as fun.
That's interesting that you guys in Denmark have been hand launching your gliders while aerotowing. My flying buddy Bernd suggested we try that but everyone at the field shot down the idea. I found this video showing that it is possible...
YouTube video, click to watch...
Hand Launch Aerotow
I agree though my little Cub maybe a little too weighty for that but its a possibility. Maybe we'll give it a try.
The guppy shape of the fuselage is a major problem. She's rocking forward while under tow. This places the wing at a negative AOA, which maybe okay once she gets moving enough for the elevator to kick in.
When we towed her, I noticed the Fun-Cub was getting airborne first. I've seen this happen before & ordinarily its not ideal but that maybe exactly what's needed here. Once the tow-plane is up she'll be pulling up on the Cub's nose. That should in theory help get her un-glued from the ground. That's assuming the tow-plane doesn't stall out first.
I'm hoping the dolly will fix all this though. It should keep her at a nice neutral AOA & also reduce the rolling friction.
If I was to build a new fuselage (which I may consider but we're not at that point yet) here's what I'd do different...
A more forward position for the wheel should keep her from nosing over & help reduce friction. It looks like we'd also need a small tail-skid to keep the AOA from getting too extreme. Additionally, placing the tow-release up under the nose would reduce the tendency for her to rock forward. I have the release setup this way on one of my other aerotow gliders & it works well. Anyway that'd require major surgery, probably a whole new fuselage. I'm not giving up on the current setup just yet.
I think our next step is to try the dolly though. I've also had a few offers from folks with larger tow-planes. We'll get her flying. Thanks for the input guys, much appreciated.
Nodd is offline Find More Posts by Nodd
Old Oct 16, 2012, 03:49 PM
birdofplay's Avatar
Joined Dec 2005
Dollys with large, narrow tires and Good bearing should NOT offer much resistance. IMHO
Those guys should be al you need to get this going !
Bob
Old Oct 16, 2012, 04:46 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
If your going to make a new fuse stretch it out some. A few more inches between the wing and stab will improve things without making it look to non scale
davidjensen is offline Find More Posts by davidjensen
Old Oct 16, 2012, 08:35 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
We've had mixed results working with the dolly. The wheels can actually put up quite a lot of rolling resistance depending on the grass length. My 100" aerotow glider which weighs 54 oz tows fine on its belly in long grass but slows the tug to a crawl using the dolly in that same grass. Now that its Fall the grass at our field is thinning out some so we'll see how she does tomorrow.
Yeah David, if I do build a new fuselage, I'll likely make quite a few changes. Although I like the comical short-coupled look, there's no doubt a longer tail moment would produce an easier flying bird. But if I wanted that, I could just paint an Easy Glider yellow & call it a Cub *grin*
There's some room for futzing though. If this one works out I could see me maybe building a larger version, stretched out some, possibly with a nice light built-up balsa wing using an appropriate sailplane airfoil. I have several other projects in mind before I go there though.
Old Oct 16, 2012, 08:51 PM
alstrahm is offline
Find More Posts by alstrahm
AMA 3959
alstrahm's Avatar
Joined Oct 2002
fun little project here! I wish I was closer, I have a way overpowered Funcub, we could rip the air with some foam! Those guys at http://www.rcaerotowing.com will get ya up tho! Great group! Good luck!
Al
alstrahm is offline Find More Posts by alstrahm
Old Oct 17, 2012, 08:04 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Yor CubGlider need longer tail arm, to get rid of almost all problems.
But as if you dont want to do that, I am really courious how you will modify model to make it fly well.
Subscribed!
ultralajt is offline Find More Posts by ultralajt
Old Oct 17, 2012, 12:11 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
Have one of the 100cc tugs pull you up. That should do the trick.
Old Oct 17, 2012, 05:50 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
I'll have a flight report & video tomorrow... woohoo she flies!
Old Oct 17, 2012, 07:52 PM
A10FLYR is offline
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
100 CC tug????
Wanted 1/3 World Models Piper Cub or Super Cub ARF NIB learnedinuk Aircraft - Fuel - Airplanes (FS/W) 2 Jun 17, 2012 07:28 PM
Sold Piper Cub LPU davezagwyn Aircraft - Fuel - Airplanes (FS/W) 2 Jun 14, 2012 09:52 PM
For Sale Piper Cub 91 sized ecoliburger Aircraft - Fuel - Airplanes (FS/W) 0 Jun 11, 2012 03:28 PM
Discussion Hobbyking Piper Cub vs Dynam Piper Cub For First Plane? HempfieldHunter Beginner Training Area (Aircraft-Electric) 2 Apr 25, 2012 01:54 PM
Discussion Piper J-2 Cub vs. Piper J-3 Cub Inverted Schizo Giant Scale Airplanes 9 Jan 16, 2007 04:32 PM
