Old Oct 10, 2012, 08:59 AM
Build something.
Nodd's Avatar
United States, CT, Fairfield
Joined Mar 2012
It looks like the maiden will have to wait, its raining today :-(
On the plus side this gives me time to install the wing struts.
Once I've done a few hand launches to get her trimmed we'll probably aerotow or winch her for the maiden.
Thanks for the correction Bernd, fixed. How did I figure out the stall speed? I used this excellent CG calculator. I've found it to be pretty accurate.
Nodd is offline Find More Posts by Nodd
Old Oct 11, 2012, 12:15 AM
Build something.
Nodd's Avatar
Joined Mar 2012
Struts
It wouldn't be a Cub without the wing struts. I figured the wheel support was a good strong spot to start with...
For the wing mount location I created these hard-points...
Cut a slot...
Glued & mounted. The struts are lightweight aluminum struts available at most hobby stores. The blue tape is there temporary to keep the glue from getting all over...
Now that's looking more Cub-like...
Possible maiden tomorrow, although you've heard that one before.
Old Oct 11, 2012, 05:50 PM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
A friend put struts on his 8' telemaster and immediately noticed the extra drag. I had a WACO bipe and flew it for a while then added the flying wires tieing the wing struts etc to make it look more scale. That 1/16" wire created huge drag. Looks great otherwise
davidjensen is offline Find More Posts by davidjensen
Latest blog entry: Scale and Aerotowing
Old Oct 11, 2012, 09:54 PM
Ultrabatics enthusiast
Diceman89's Avatar
United States, CA, San Jose
Joined Aug 2012
Very cool! Nice work. Looks a bit stubby though. Think it could use a longer fuse to fly better? Guess we shall see. Can't wait to hear your report.
Diceman89 is offline Find More Posts by Diceman89
Old Oct 11, 2012, 11:35 PM
Build something.
Nodd's Avatar
Joined Mar 2012
Thanks guys. If I've not already done so, I should mention this project is not about building a really nice flying sailplane, actually quite the opposite. I'm going for a comical, almost cartoonish look.
Yeah she's extremely short-coupled by design. You're correct, a longer tail moment would no doubt result in a more stable plane.
Again I'm not all that concerned about performance, the struts while semi-functional are there mainly for looks. They're removable though so if they turn out to be a problem its not a big deal to leave them in the workshop.
Old Oct 12, 2012, 12:33 AM
Build something.
Nodd's Avatar
Joined Mar 2012
YouTube video, click to watch...
MAIDEN FLIGHT VIDEO
Flight Report (spoiler alert - watch video first)
Well as you can see that didn't go as well as I'd hoped although not a big surprise either, given the deliberately compromised design. Here's my thoughts...
Issue 1
The placement of my ridiculously big wheel sticking way too far out below the fuselage & positioned right at the CG doomed the aerotow. The nose-skid helped but not enough to keep the plane level & stable while towing. A lower profile wheel positioned properly would let her roll smoothly without generating gobs of drag for the poor tow-plane.
Issue 2
Everyone who picks her up is surprised at the weight. She's a heavy bugger, that combined with the short-coupled tail moment makes for some "interesting" flying. I think she'll be manageable if only I can get her in the air & moving along at a good clip.
Issue 3
Watching the alarming angle of attack during the high-start launch, I'm wondering if maybe moving the two-hook location further forward would help. Other factors such as CG & elevator trim may have contributed to the problem too.
The Next Step
After I make the repairs I think I'm going to remove the wheel & nose-skid & just let her slide along on her belly. I'll see if that helps with the ground handling. I may also remove the wing-struts at least until I have a few more test flights under my belt. With the nose-skid gone I can also try moving the tow-hook location forward a little.
Seriously this isn't Serious
While this may come across as a poor excuse for blatantly bad design, my main drive behind this build was to learn about working with foam. This project has in that sense been a success. I'm now confident enough to proceed with some more serious designs. That said I'm not done with this Cub though, at least not yet. I'm pretty sure I can get her flying.
Anyway bring on the theories, suggestions & those inevitable "I told you so's". I have it coming & I welcome it all. Fun Fun.
Old Oct 12, 2012, 06:19 AM
Upwardly Mobile
mikegbogh's Avatar
Roodepoort, South Africa
Joined Aug 2007
Hi Nodd
You can make it fly, get to the top of a big slope, wait for a strong wind and with a bit of down trim throw it.
You will have instant airspeed and altitude your odds will be greatly improved.
Great presentation so far.
Cheers
mikegbogh is offline Find More Posts by mikegbogh
Old Oct 12, 2012, 07:45 AM
Diceman89's Avatar
Joined Aug 2012
Agreed, I was thinking the same thing. Nice instant lift and easy launch. Definitely the place to test a new design first is a slope. good try though.
Old Oct 12, 2012, 10:54 AM
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Nodd,
Beautiful job creating the Cub glider. I think it is tail heavy - causing the flick while launching with the high start.
Some weight in the nose should fix it.
Thanks for sharing,
Paul
FlyingW is offline Find More Posts by FlyingW
Old Oct 13, 2012, 07:54 PM
Build something.
Nodd's Avatar
Joined Mar 2012
I agree, a nice slope would be ideal for test flights however where I live here in Connecticut, all the hills are either covered with trees or urban sprawl. The closest slope soaring spots are hours away.
Paul you're not alone in suggesting she may have been tail heavy. I'm not convinced she was though, as I'm pretty meticulous when it comes to balancing my planes but I can't ignore the possibility. We'll never know for sure as I've re-balanced her now that she's been modified. This time airing on the side of caution I've set the CG further ahead of the neutral point, at 15% static margin (last time was around 8%).
After Further Analysis...
Well I goofed up. I've no clue why I chose to just eye-ball the location for the high-start hook, especially as I'm well aware of the 30° ahead of the CG rule for tow-hooks. Look how far back I had my tow-hook positioned!..
Its no wonder she behaved like she did, I had the tow-hook WAY TO FAR BACK...
Aerotowing
So lets simplify things. I lobbed off the nose-skid & "tundra sized" wheel & now we have a nice smooth fuselage to work with. The wing struts are history too...
After re-balancing here's how she sits...
Unfortunately due to the Guppy shaped fuselage the tail is still up in the air & it looks like she'll probably rock forward on her nose again during aerotow. Still though I think its an improvement. At the very least she looks cleaner...
I'm going to concentrate on aerotowing for now. I'll worry about adding a new high-start hook later on.
So anyway, weather permitting, we'll give her another try tomorrow.
Old Oct 13, 2012, 08:03 PM
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Nodd, put a strip of clear packaging tape on the bottom.
A10FLYR is offline Find More Posts by A10FLYR
Old Oct 14, 2012, 04:08 PM
Build something.
Nodd's Avatar
Joined Mar 2012
As suggested I stuck some tape on the bottom, good idea, thanks.
YouTube Video, click to watch...
Cub Sailplane Part 2
The video pretty much speaks for its self. We'll try again soon.
Old Oct 15, 2012, 05:16 AM
KISS_KeepItSimpleStupid
philkiteflyer's Avatar
Invercargill, New Zealand
Joined Nov 2006
Come on, use the dolly ! ! ! You need to get that thing in the air! ! !
Waiting for part 3,
Phillip C
philkiteflyer is offline Find More Posts by philkiteflyer
Old Oct 15, 2012, 01:21 PM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Just throw it when towing instead of the ground start, we do that when the grass is a bit too heigh, even with 3,6 meter gliders after a Funcup.
This gives the tow plane a chance to get airborne.
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Oct 15, 2012, 02:54 PM
Diceman89's Avatar
Joined Aug 2012
I don't think throwing that would be a good idea, maybe to run with it and let it go gently. If thrown it would take down that cub, it does not have that great of a glide rate, I think it would yank the plane right down once it catches or make it real hard on the plane. If it was a specifically made poly dihedral glider, then ya, throw it, but no offense, that plane sinks quick. Awesome job on the build, not trying to knock you at all, just saying.
Just try the dolly!
Wanted 1/3 World Models Piper Cub or Super Cub ARF NIB learnedinuk Aircraft - Fuel - Airplanes (FS/W) 2 Jun 17, 2012 06:28 PM
Sold Piper Cub LPU davezagwyn Aircraft - Fuel - Airplanes (FS/W) 2 Jun 14, 2012 08:52 PM
For Sale Piper Cub 91 sized ecoliburger Aircraft - Fuel - Airplanes (FS/W) 0 Jun 11, 2012 02:28 PM
Discussion Hobbyking Piper Cub vs Dynam Piper Cub For First Plane? HempfieldHunter Beginner Training Area (Aircraft-Electric) 2 Apr 25, 2012 12:54 PM
Discussion Piper J-2 Cub vs. Piper J-3 Cub Inverted Schizo Giant Scale Airplanes 9 Jan 16, 2007 03:32 PM
