Old Sep 21, 2012, 10:09 AM
Choppa Nutta's Avatar
UK
Joined Jan 2002
How do I calculate strength of an airframe ??
Hi all,
I'm hoping to pick the brains of some structural engineers on the specific maths required to design large airframes, specifically calculating probable loads twist, shear, cantilever etc.
and how to work through material selections.
for instance, if I have a plane of a 100 kilo's with a 6 metre wingspan and I want it to take 12 G's before it breaks for a 6 G nominal load, how much Carbon Fibre/ Spruce/ Steel etc. do I need ?
assuming a rectangular cross section etc.
Calculating the weight of an airframe is a comparatively simple problem, volume x density of materials = mass, that bit I can do but its the rest I want to learn about, at least to a stage I can present a design to an aero engineer to tell me what I've got right & wrong so that I can do most of the leg work etc etc etc
anyhow, if anyone can help point me in the right direction, books to read, web sites to visit & so on I would be most grateful,
many thanks.
Choppa Nutta is offline Find More Posts by Choppa Nutta
Old Sep 21, 2012, 11:06 AM
richard hanson's Avatar
Joined Oct 2007
No calculations but
based on the size model, you may contact various builder /plans suppliers of ultra lite aircraft-which have construction materials you would likely utilize
Many of these designs were under 500 pounds-some even much lighter .
The present generation of RPV craft are foam and glass- messy and expensive
Sitka spruce - , and plywoods may proove to be desired materials tho some builders utilize very thin aluminium ,sheared bent and rolled - -
You really need a concept of desired results -first.
richard hanson is offline Find More Posts by richard hanson
Old Sep 21, 2012, 02:43 PM
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
Choppa
I presume you are aware of the UK Large model association
http://www.largemodelassociation.com/index.html
http://www.largemodelassociation.com/Register.htm
peterangus is offline Find More Posts by peterangus
Old Sep 21, 2012, 03:34 PM
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
these type of questions use to be so common on this forum
the problem is usually how much force can the wings take before they bend and break
these notes may help http://ciurpita.tripod.com/rc/notes/compositeSpar.html
greg
ciurpita is offline Find More Posts by ciurpita
Old Sep 21, 2012, 05:53 PM
Joined Jan 2007
"Analysis and Design of Flight Vehicle Structures", Bruhn, is the bible for aerospace structural design:
http://www.amazon.com/Analysis-Desig.../dp/0961523409
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Sep 22, 2012, 06:58 PM
UK
Joined Jan 2002
Thank you guys,
I have various projects in mind, at some point I know I'm gonna want make something I can sit in but that dream is far away as yet
but what I'm after here is the understanding and knowledge of the structural design process and the maths behind it, I will try the links
Cheers
Old Sep 23, 2012, 01:27 AM
Estonia, Harju, Tallinn
Joined May 2012
This spreadsheet might help you --> http://www.rcgroups.com/forums/showthread.php?t=1213427
I've used it to dimension my wings.
martig is offline Find More Posts by martig
Question How do I "debug" an ARF balsa kit? mbanzi Electric Plane Talk 15 Mar 05, 2012 12:10 PM
Discussion How do you cap a rib with a carbon fiber strip? How much strength does it add? Accu157 Thermal 93 May 07, 2011 11:27 AM
Discussion How do we calculate range and endurance of an RC plane? Keat Modeling Science 11 Jul 17, 2009 01:16 PM
Question How do I calculate an airfoil's reflex atjurhs Slope 3 Mar 09, 2006 12:14 PM
