Old Sep 21, 2012, 06:24 AM
Little Black Duck is offline
Find More Posts by Little Black Duck
Little Black Duck's Avatar
Thornleigh - 20k N of Sydney,N.S.W.,AUSTRALIA
Joined Aug 2001
Dumb question ... Maybe?
G'day all,
This may seem a dumb question to ask, but the new 7ch Orange Rxs' servo ports are now given channel numbers 1 thru 7 after the Bind port, rather than what the 6ch version's port labelling apparently has ... i.e. - Bind, Thro , Ail, Elev, Rudd, Gear, and Aux1.
Can I assume that it would be the same? ... But with the 7ch Rx having an Aux2 port added.
Why this was changed it from what appears to be normal port labeling ipractice. at least by Spektrum and on the 6ch Orange clone, beats me!
Daffy.
Little Black Duck is offline Find More Posts by Little Black Duck
Old Sep 21, 2012, 06:38 AM
Petem is offline
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Australia, VIC, Werribee
Joined Jul 2008
Yes & dunno!
LBD,
I have a 7ch and a 6ch in front of me and you are right-ish:
The 7 has 1,2,3 etc with Bind/SBus on the right - corresponds to Throt, Ail, etc in same order - negative on top, signal on bottom (if top is label side).
The 6 has batt/bind, throt, ail etc, with signal on top.
Both work, but watch your toes with the plug-in order and direction.
Dunno.
PeteM
Petem is offline Find More Posts by Petem
Old Sep 21, 2012, 07:44 AM
Joined Aug 2001
Thanks Pete,
I was just going to amend my post to correct that error, you beat me to it, mate. The Bind Port is after all the others.
Also thanks for the tip about the polarity ... No continuity or similarity of fitment between the two Rxs or genuine Spektrum Rxs either, except they're all compatible with my DX7S Tx. Can't complain about the price though, as long as they're reliable.
Daffy.
Old Sep 21, 2012, 09:20 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by Little Black Duck View Post
G'day all,
Daffy.
It's a very sensible move by Orange.
Numbering is a much better way to do it than Thr, Ail, Ele, Rud, etc. as the functions change with different programming setups. In the days when everyone just used the standard four channels, it was convenient to label with functions, but now, when dual ailerons, elevons, etc. are commonly used, numbering makes everything clearer.
By the way, the receiver does not determine what each channel is for, that's done at the transmitter.
Daedalus66 is offline Find More Posts by Daedalus66
Old Sep 21, 2012, 10:18 PM
Joined Aug 2001
OK . I'll buy that argument ... But would prefer some commonality with Spektrum based Rxs, including what has been pointed out, the polarity at the servo ports, which could cause connection problems ... Just my thoughts.
Daffy
Old Sep 21, 2012, 10:33 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I'd settle for clear labeling. The polarity of the pins is determined by the design of the circuit board.
Old Sep 22, 2012, 04:33 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
But generally (at least) speaking, they put the red (positive/hot) wire on the center pin so if inserted backwards, you won't burn it up - the servo just won't work; no ground. In which case, just flip it around, should be good to go.
That's one commonality at least - perhaps the most important in the end. Maybe not universally, but AFAIK.
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 22, 2012, 10:33 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
All regular modern servos (since about 20 years ago) are set up this way and as you point out, it's a big safety precaution. The exception is the submicro ones that use various small connectors with the wires that may be arranged differently.
The only polarity accidents we hear about regularly involve people installing a non-standard battery in a transmitter the wrong way round.
One very confusing thing is that plugging the power into the receiver the wrong way round may cause the light to come on, making you think it's correct.
Old Sep 24, 2012, 04:56 AM
Joined Aug 2001
I'll ask another, also possibly dumb too, but the Orange Rx doesn't come with a manual, so there's no positive info as to whether the Rx can be used successfully without a satellite for an e-sailplane. Is the 7ch Orange full range and OK without a satellite?
Daffy.
P.S. Is there a manual available anywhere?
Old Sep 24, 2012, 08:01 AM
scruffy1 is offline
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
Daffy.
manual is in the files tab on the hobbyking website
"Approved for use by the MAAA in Australia as a full range receiver when used in conjunction with the OrangeRX R100 Satellite Receiver."
scruffy1 is offline Find More Posts by scruffy1
Old Sep 24, 2012, 08:11 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Daffy.
A manual is not going to help on that except that it might say adding a satellite increases the reliability of the radio link. But we already know that.
What I can say is that while many people report using Orange receivers without satellites for gliders (mostly the 6 channel) with good results, I would not do it. I would always use the satellite for any model to be flown at medium to long range.
The satellite does not directly increase the theoretical maximum range (both main and satellite receivers should have roughly similar range) but it does improve the reliability of the signal within that range, which is really what counts.
Old Sep 24, 2012, 09:46 PM
scruffy1 is offline
scruffy1's Avatar
Joined Feb 2008
my quote above is from the hobbyking online manual in the files tab
as the op is (like me) in oz, then the maaa assessment is as useful as we can get - they approve it as full range with the satellite, so better to go full belt and braces if you want to have the best of both worlds
that said, i fly my 2 channel thermal soarer with a 7 channel orangeRx and no satellite, and it does okay, but i haven't latched on to a boomer yet
Old Sep 24, 2012, 10:42 PM
Joined Aug 2001
Thanks for those two ... well three posts actually. It's what I thought would be the case ... always assuming there's room in a smaller 2m e-sailplane's narrow, and space limited fuselage, where it's difficult to achieve the 90deg aerial difference. I liked tthat belt and braces analogy though, it was a good one.
Appreciate your replies.
Daffy.
Old Sep 24, 2012, 11:05 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The Orange satellites are really tiny.
Old Sep 25, 2012, 02:12 AM
Joined Aug 2001
You're telling me! ... should find no trouble finding somewhere to stow it ... and I have a feeling that I don't really need to worry about its tiny aerial's orientation in relation to the main Rx either!
Daffy.
Discussion maybe a dumb question bluezuki Sailplane Talk 2 Oct 10, 2009 06:18 AM
Discussion park flyer question maybe dumb zen3 Parkflyers 5 May 10, 2009 10:44 PM
Discussion Maybe a Dumb Question... EP_Heli Micro Helis 3 Jan 30, 2007 05:53 PM
Maybe move to dumb question forum? Rayven High Performance 28 Dec 14, 2004 07:09 AM
Maybe a dumb question about power supplies... WJ Birmingham Batteries and Chargers 12 Nov 24, 2003 11:32 AM
