Old Oct 08, 2012, 09:23 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
After looking at many photos of woodies on the internet and noticing that most have varying color from plank to plank, I'm thinking about staining all of the mahogany to get an even tone, do I have to strip/bleach it first? If so, should I do that to the mahogany before I start planking the hull?
JayJay76 is offline Find More Posts by JayJay76
Old Oct 08, 2012, 09:47 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Are you sure you want to stain it all? I think that the many colors of mahogany is the sweetest about it. But it is only my opinion. You can pair the strips in stunning "patterns"
Sharky1dk is offline Find More Posts by Sharky1dk
Old Oct 08, 2012, 10:11 AM
JayJay76 is offline
JayJay76's Avatar
You make a good point, but while I was building my first runabout I didn't pay attention to the grain direction on each plank and they ended up kinda random. I now realize, the guy I get my mahogany from had them all carefully taped together in a bundle as they were sawn from the board, but I didn't know this and let them get all shuffled. How did you sort them?
I'll have to think about this, I really hate to strip out the natural tone only to replace it with some stain, it seems contradict the logic for using an expensive species like mahogany in the first place..
Anyway that's a sweet looking crackerbox!
Old Oct 08, 2012, 10:54 AM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
I only sorted them visually, kinda paired what i thought would look good together. And in my opinion i succeeded.
Old Oct 08, 2012, 11:50 AM
JayJay76 is offline
JayJay76's Avatar
just out of curiosity, where did you get your mahogany? and the engine hatch hinges? the ones I have on order are 9mm wide that seems just about to scale.
Old Oct 08, 2012, 12:02 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
It is all from http://www.mackproductsrc.com/713_cal__cb.htm
Mahogany: http://www.mackproductsrc.com/7173_m...y_planking.htm
Hinge: http://www.mackproductsrc.com/7127_piano_hinge.htm
Old Oct 08, 2012, 01:17 PM
JayJay76 is offline
JayJay76's Avatar
I was hoping for some European source, but thank you
Old Oct 08, 2012, 01:35 PM
dimdte is offline
Find More Posts by dimdte
Joined Aug 2009
Mahagoni
I bought it here:
http://stores.ebay.de/banane-von-hin...&_sid=63815189
Hinge
http://www.modelshop.co.uk/product/P...g_Pk_2_GH00000
dimdte is offline Find More Posts by dimdte
Old Oct 08, 2012, 02:39 PM
JayJay76 is offline
JayJay76's Avatar
Hi dimdte, welcome! Its an honor that your first post is on my humble build log, thank you for the links.
Old Oct 09, 2012, 07:15 AM
JayJay76 is offline
JayJay76's Avatar
I replaced the ply formers along the sides of the deck, which were too stiff, with 4x3mm pine strips, 4 of them side by side made up the right width and the slots that were already there held them in place perfectly. The resulting shape is very smooth and very stiff. I'm out of pine strips now so I need more to finish the stringers, then on to the 2mm balsa sub planking.
Old Oct 11, 2012, 09:25 AM
JayJay76 is offline
JayJay76's Avatar
I'm getting ready to start planking with 2mm balsa, but I want to spray the whole thing so far to waterproof the framework, then I will sand and true up all the framing to ensure a smooth job with the sub planking, revealing bare wood for all the glueing surfaces. This got me started thinking about how to seal the inside of the balsa planking in inaccessible areas. Anyone have any tips about this? I think if the balsa isn't sealed, the back of the mahogany planking will be open to water from inside the boat. Does that make sense?
Old Oct 11, 2012, 10:15 AM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Can you brush seal it with a thin coat of thin epoxy finishing resin before planking, like Zpoxy or similar? But if it has to be sprayed you may have to resort to something like polyurethane.
Pete
blutoh is offline Find More Posts by blutoh
Old Oct 11, 2012, 10:33 AM
JayJay76 is offline
JayJay76's Avatar
I have a floor panel which is already glued in place, it ensures alignment of the formers in the cockpit area. After I plank the bottom with balsa, the area in between the two would be more or less inaccessible. Maybe I could slosh a thinned out mix of clear dope to wet all those surfaces. Would that water proof it? I don't think sloshing thinned resin around would work.
Old Oct 11, 2012, 10:50 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
I'm not sure about the dope, I've never used it. The finishing resin I mentioned comes already thinned, not like the thick epoxy for gluing. I used it on the inside and outside of the Salty tug.
Old Oct 11, 2012, 12:09 PM
JayJay76 is offline
JayJay76's Avatar
HEY Pete! Post some updated photos and/or videos to the salty thread!
Now I need to locate the german equivalent of thin finishing resin.
New Product Legend Model Boats 1935 Gar Wood 16' Speedster "MISS BEHAVE" frankg Scale Boats 234 May 18, 2015 10:45 PM
Build Log 1:1 MC 15 CRICRI (Cricket) Scratch Build zed1234 Giant Electric Planes 10 Apr 13, 2012 08:14 AM
Discussion 4-Stroke Saito 50 Powered 1/6 Semi-scale Nitro-Trike Scratch Build Log CONDOR2 RC Paragliders and Kites 0 Jun 11, 2011 11:34 PM
Discussion A Gar Wood you didn't know... patmat2350 Scale Boats 19 Apr 13, 2011 06:35 PM
