Old Sep 21, 2012, 05:55 PM
oldtribefan is offline
Find More Posts by oldtribefan
oldtribefan
oldtribefan's Avatar
United States, GA, Kennesaw
Joined May 2007
Super job JayJay76! I am following this thread.
oldtribefan is offline Find More Posts by oldtribefan
Old Sep 21, 2012, 06:40 PM
JOHN SCALE BOAT is online now
Find More Posts by JOHN SCALE BOAT
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
Can not wait to see the plans! Looking for a winter project.
JOHN SCALE BOAT is online now Find More Posts by JOHN SCALE BOAT
Old Sep 21, 2012, 08:49 PM
Ed Crowell is online now
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Originally Posted by frankg View Post
HEY ED!!! Did you ever finish your speedster? If you did have you had your shake down cruise? It has been awhile since you posted on your speedster thread.
frankg,
I set the Gar Wood aside for a while. I expect to start working on the boat in a couple of weeks. It will be completed.
Ed
Ed Crowell is online now Find More Posts by Ed Crowell
Old Sep 22, 2012, 12:26 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Can't wait.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Sep 25, 2012, 08:54 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
I plan to mill the parts out of the plywood sheet with a 3mm cutter, so I made 1,5mm offsets around each part to serve as the tool paths, but I had to make some tweaks to the slot width since my material is actually 3,2mm thick. This doesn't sound like a big problem but anywhere the material is doubled, such as the keel, the 0,4mm difference would make the parts too tight to fit together. I hadn't realized this before but the part design relies heavily on the material thickness.
I laid out all the parts carefully to make best use of material and ended up with three CNC files. Getting ready to mill the first of three sheets of parts.. I will take photos and post them later tonight or tomorrow morning.
JayJay76 is offline Find More Posts by JayJay76
Old Sep 25, 2012, 09:58 AM
JayJay76 is offline
JayJay76's Avatar
Ready to start milling..
Old Sep 25, 2012, 02:47 PM
JayJay76 is offline
JayJay76's Avatar
The first sheet of parts has been cut!
That went much smoother than I expected, my layout seemed almost perfect except for a few small glitches, but I will fix those in the next two sheets before milling. Total milling time was a little less than 90 minutes, but I think the 4 step cutting is unnecessary, so the next sheet should cut 25% faster, and the 140% cutting speed worked out well. Here are some pics of the milling for those interested in such things
Old Sep 25, 2012, 02:57 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Jason,
Are you using and End Mill, or a spiral flute to do the cutting?
Pete
blutoh is offline Find More Posts by blutoh
Old Sep 25, 2012, 03:00 PM
JayJay76 is offline
JayJay76's Avatar
Its an end mill I think.
Old Sep 25, 2012, 03:06 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
If you have a spiral flute available, try it. It may allow you you to take deeper, and possibly cleaner, cuts as it's designed to cut on the sides of the bit. I use them in my router table to do template cutting. Might be worth a try.
Pete
Old Sep 25, 2012, 03:24 PM
JayJay76 is offline
JayJay76's Avatar
I'll ask if we have one, but they normally only mill 3D mockups, no 2D milling. I dunno if spiral flutes are used for that.
Old Sep 25, 2012, 03:30 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
No, 3D is usualy done with ball mills and end mills. If you plan to cut a lot of these, it may be worth the investment in the spiral flute. Here a decent carbide spiral flute sells for around $50 US. Not sure what it would cost on your side of the pond. BTW, that's a sweet CNC router mill. is this a commercial service you are using?
Pete
Old Sep 25, 2012, 04:07 PM
JayJay76 is offline
JayJay76's Avatar
No that's the model shop in my office, I'm not experienced in operating the cnc machine myself, but the modelmakers are friends of mine so they don't mind running private jobs for me when it's not in use. I also have access to the other mills, lathe, spray booth, etc.
Old Sep 25, 2012, 04:09 PM
craig_c is offline
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
Ye be gatherin' fans
craig_c is offline Find More Posts by craig_c
Latest blog entry: Ah, To be young again...
Old Sep 25, 2012, 04:45 PM
JayJay76 is offline
JayJay76's Avatar
I ordered the book "mahogany in scale" from Amazon a couple days ago, I had hoped to receive it today and stay up all night studying. I'm so excited to see what's in it before I continue planning the planking layout. What's a reasonable plank width for the sides and bottom of a boat like this? Ill be using 2mm thickness. And what to use for the black caulking lines?
New Product Legend Model Boats 1935 Gar Wood 16' Speedster "MISS BEHAVE" frankg Scale Boats 234 May 18, 2015 10:45 PM
Build Log 1:1 MC 15 CRICRI (Cricket) Scratch Build zed1234 Giant Electric Planes 10 Apr 13, 2012 08:14 AM
Discussion 4-Stroke Saito 50 Powered 1/6 Semi-scale Nitro-Trike Scratch Build Log CONDOR2 RC Paragliders and Kites 0 Jun 11, 2011 11:34 PM
Discussion A Gar Wood you didn't know... patmat2350 Scale Boats 19 Apr 13, 2011 06:35 PM
