Old Sep 21, 2012, 04:35 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Build Log
1935 Gar Wood Speedster scratch build
This will be my third scratch build, which was inspired by Ed Crowell's Speedster build log. I've based it on the top/side drawings contributed to Ed's thread by frankg.
Because it is kind of a large model (for me at least) and there are a lot of complicated parts, I will CNC cut them from 3mm ply and assemble a 'kit' of parts before I start building.
The first step is to import the drawings into Rhino, and trace the lines needed to form the hull. Then I use a clever tool called "curve from 2 views" which takes the top view of the bow curve, and combines it with the side view of the same curve, to produce an accurate 3D curve. After extracting the hull form curves in this manner I used the fair tool to smooth and refine them resulting in a very clean set of curves from which the hull form is built.
Next, I took a look at the engine hatch and cockpit locations, and determined the number and position of formers to best capture the shape, including one at the widest beam to ensure a smooth shape on the final hull.
Then I used an offset of the outer hull surface to trim the formers, allowing for the 2mm balsa sub-planking. The goal is to meet the outer shape of the hull top and bottom with the sub planking in place, then plank on top of that with 2mm mahogany.
I then constructed the keel and added interlocking slots to ensure alignment of the formers, and added a side former to lock in the alignment and eliminate any twist in the formers relative to the keel.
JayJay76 is offline Find More Posts by JayJay76
Old Sep 21, 2012, 09:19 AM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
This is going to be good. Looking forward to your build.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Sep 21, 2012, 09:54 AM
JayJay76 is offline
JayJay76's Avatar
Hi Ed, thanks for stopping by, I have read and re-read your speedster thread, if my finished model looks half as good as yours I'll be happy!
I'm planning to make most of the fitting by hand from brass and then nickel plate them. Its the windshield brackets that worry me, are your windshield brackets available from wet goose? Any idea what they cost?
Old Sep 21, 2012, 10:43 AM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
I know Ken Valk of "Wet Goose Marine" has the mold for the wind shield brackets and he also has the air vents and bow light. Here is Ken's email.
Kenvalk@pacbell.net
If you plan on plating the brass parts your self I would suggest using (copy chrome) instead of nickle. The nickle will tarnish and get dark. The pieces I plated with copy chrome well over a year ago are still bright like the day I plated them.
Ed
Old Sep 21, 2012, 11:04 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Great start!
woodybob is offline Find More Posts by woodybob
Old Sep 21, 2012, 11:33 AM
JayJay76 is offline
JayJay76's Avatar
I emailed Ken for a pricelist. I also thought about casting myself, pewter or white metal, then copy chrome. I wonder if they sell that or an equivalent here.
Thanks for popping in Woodybob! The cad modelling is the easy part, its finishing the mahogany that worries me. I have one other planked mahogany boat under my belt and the planking was a breeze and came out awesome, but i did have a few issues with spar varnish, this time i think i will seal and level with west systems and then spray with auto clear coat.
Old Sep 21, 2012, 12:02 PM
sunworksco is offline
Find More Posts by sunworksco
BabyBootLegger
sunworksco's Avatar
United States, CA, Alameda
Joined Nov 2010
Is anyone thinking about selling kits.
I would buy one in a heartbeat!
Giovanni
sunworksco is offline Find More Posts by sunworksco
Old Sep 21, 2012, 12:46 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Giovanni
Check This out.
http://www.legendmodelboats.com/miss_behave.htm
Ed
Old Sep 21, 2012, 01:59 PM
BabyBootLegger
sunworksco's Avatar
Joined Nov 2010
Thanks!
Old Sep 21, 2012, 02:13 PM
JayJay76 is offline
JayJay76's Avatar
For any interested scratch-builders, I will be posting my plans here once I know everything fits together, including laser cutting patterns for 3mm ply.
Old Sep 21, 2012, 02:44 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Subscribed!
What took you so long Jason ?!?!
Pete
blutoh is offline Find More Posts by blutoh
Old Sep 21, 2012, 03:07 PM
BabyBootLegger
sunworksco's Avatar
Joined Nov 2010
I would like to build a 1/4th scale version.
48" length.
Giovanni
Old Sep 21, 2012, 03:43 PM
JayJay76 is offline
JayJay76's Avatar
Thanks for checking in Pete! the cartoon runabout is mostly done, but the cooling intake doesnt work and ive burned two motors trying to sort it out. meanwhile ive started this project!
Hi Giovanni, i will post a set of basic plans with stations you can scale to any size, and ill prepare a set at 48" as pdf for you when i get a chance.
Old Sep 21, 2012, 03:55 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
HEY ED!!! Did you ever finish your speedster? If you did have you had your shake down cruise? It has been awhile since you posted on your speedster thread.
frankg is offline Find More Posts by frankg
Old Sep 21, 2012, 04:22 PM
BabyBootLegger
sunworksco's Avatar
Joined Nov 2010
Thank you!
Kind regards,
Giovanni.
New Product Legend Model Boats 1935 Gar Wood 16' Speedster "MISS BEHAVE" frankg Scale Boats 234 May 18, 2015 10:45 PM
Build Log 1:1 MC 15 CRICRI (Cricket) Scratch Build zed1234 Giant Electric Planes 10 Apr 13, 2012 08:14 AM
Discussion 4-Stroke Saito 50 Powered 1/6 Semi-scale Nitro-Trike Scratch Build Log CONDOR2 RC Paragliders and Kites 0 Jun 11, 2011 11:34 PM
Discussion A Gar Wood you didn't know... patmat2350 Scale Boats 19 Apr 13, 2011 06:35 PM
