halfway not bad
Hi All,
So 3 days later , time to take off the splitter board. I made some small cuts in the chipboard, one at the nose and two by the tailfin, broke out the thin tailfin section and lifted off the one half. It released with no problem and looks like the plug is still dead centre so thats great. I will start polishing and preparing to now layup the second half. Once finished I will let it rest a few days then cut both the edges, and smooth them . ![]() Cheers Mike |
Joined Nov 2008
Just incredible Mike but I can't bear the idea that you bin the mould at some point!
I'm doing an ASW/ASG29 re-furb thread on the UK Scale Soaring website but I'm much too embarrassed to post it on here! I will be shamelessly copying your wing building technique when you get to it though... Simon |
Hi swarrans,
Just incredible Mike but I can't bear the idea that you bin the mould at some point! Not quite right, we keep the mold and the plug becomes obselete. ![]() The molds should be good for at least 10 fuselages. Should make the first fuselage in about a week or two. cheers Mike |
Joined Nov 2008
Now I'm trying to understand the second mold layup. You have removed the board and will be making the second half using the first mold as the splitting board? ? ? Have I got that right ? ? ![]() If so, then I now understand and going to have to have a go myself . . .someday . . . when I've got time . . .and more room in the workshop . . . . a better understanding of what to do . . . and can decide on JUST ONE MODEL. So much to learn, so little time. Ah well such is life. Mike, I'm enjoying your build and your commentary, it is very informative. Thanks for sharing, Phillip C |
Hi there,
Quote OK, thanks for the answer to my first silly question, answer accepted gratefully. Now I'm trying to understand the second mold layup. You have removed the board and will be making the second half using the first mold as the splitting board? ? ? Have I got that right ? ? Yes thats it without removing the plug the now exposed mold surface is waxed as well as the plug again. The plug is then buffed to a shine and a PVA coat applied. Hopefully after laying up the second half , ie gel coat, light glass heavy glass the shape is perfecty reproduced with a nice clean join line down the middle. The locating holes will be gel coated and filled with some flox mix and later when they lock in place the products will all be exactly the same. Thats the plan anyway, we will see what happens next week when the plug is removed. I have seen guys remove the one half at this stage and then re-insert it back into the mold half, but by doing that you break the midline seal , and it is possible that when you do the second half , the plug could shift ever so slightly.thanks for watching and asking questions , always welcome contributions, ideas and questions. ![]() cheers Mike |
Good luck with part two . . ![]() Phillip C |
Phase 1 Part2 or first part.
Hi guys,
Well saterday I got started early and after one more layer of release wax, gave only the plug a good shine, next was a wipe with the PVA, which by the way is my new best friend. ![]() Painted on the gel coat and after a short break (lunch) it was time to start the process again, namely , flox/resin across all sharp transitions, hollows and canopy lip, next two carbon tows tip to tail , followed by light glass , medium glass and about 4 layers of Bi-axial cloth. Final layer of fine cloth sealed everything off at 17:00 hours. Left overnite it was nicely cured sunday morn, as the sun was trying to come out and I was off for an aerotowing event , I left the mold out in the sun in some black bags to ramp up the temperature for the day and do a little postcuring. The aerotow went real badly for me and so I was home early, decided to crack open the molds and see what was inside. ![]() regards Mike
Nice to hear from you, these fuselages wont just be released, I would rather scale pilots get them, there will be a few complete aircraft built , but there is a lot of interest, including some fullsize JS 1 owners. and I know 4 complete planes already have homes, fuselages are the easy part. Oh and I also have a real job as well, lolYour guess ....well this was only the begining of the pear shape so yes and no ha ha regards Mike |
| Thread Tools | |
| Discussion 80 in. W/span, 1/4 scale Sopwith Triplane | tenacious101010 | Giant Electric Planes | 1 | Sep 03, 2012 05:04 PM |
| Discussion Dummy radial instalation in 1/4 scale round cowl | greggk | Fuel Warbirds | 5 | Jun 18, 2012 04:06 AM |
| Sold 1/4 scale 4 1/4" inflatable cub tires | lla | Aircraft - General - Miscellaneous (FS/W) | 0 | May 28, 2012 10:55 AM |
| Sold 1/4 Scale Balsa USA Cub Nice, no engine LPU in OC Ca. $250.00 | stevster | Aircraft - Fuel - Airplanes (FS/W) | 3 | Apr 13, 2012 01:17 AM |
| For Sale SIG 1/4 scale Cub Airframe in NJ LPU | CarreraGTSCS | Aircraft - Fuel - Airplanes (FS/W) | 0 | Mar 25, 2012 03:29 PM |
