North Yorkshire UK, on a big hill facing the prevailing wind. Coincidence?
Joined Oct 2007
Thanks for that tip Shedders - I may well try it. Anything that avoids reliance on sunlight has to be a smart move when heading into a Northern UK Winter.
Mike - I sincerely hope you have ferocious nostril hair! Composite dust is lethal stuff and you really don't want it in your lungs - more to the point, WE really don't want it in your lungs... you need to live a long and healthy life so we can learn from your techniques. ![]() I don't want to lecture you... but I'm going to...there are some really effective, comfortable and relatively cheap reusable masks available. I use this 4000 Series half mask by 3M. http://www.screwfix.com/p/3m-mainten...spirator/13038 It is just so comfortable and the seal is so good that you can't even smell vapours through it. It's also available in SA. OK, lecture over. ![]() Rog Who has also nurtured ferocious nostril hair. You can't be too careful. |
Africa is a dusty place
Hi Guys,
Your input is valued thanks for the tips. Shed your idea with the reflection really works, I have a long neon light in my garage and at night I can check the surface reflections with it, any ripple shows up as a line change. Rog you are absolutely right , I am going to pay more attention when sanding and use a dust mask, I have a box of them so why not. ![]() On the safety aspect of composites I always wear gloves, when working with epoxy and work in a well ventilated area. cheers Mike
Joined Oct 2007
Pleased to hear about the gloves Mike. And whilst we're being all Health and Safety conscious, gloves really need to be Vinyl... normal latex just lets the evils straight through to your skin.
Plug looking smoother every post. It makes you realise how much work must go into the full size plugs. Rog |
Sunrise and Ripples
Good Day,
That sounds a bit Australian so for South Africans I will go with the local Howzit (short for how are things going with you and yours) ![]() Anyway Rog's (Sutton Banks) Sunrise Surprise shows some serious hollows these are now being addressed , will do a take 3 ,at dawn tomorrow. Now 6 rounds of primer and sanding , completed so now there is a strong chance colour could be next. Then its polishing and polishing, I am currently experimenting on an old wing with red PVA as a release , I have not used in the past , but really need a good result with this plug. Any PVA addicts are welcome to chime in, my understanding is several rounds of release wax , buffing in between, and then a thin wipe over with PVA, sound right. ??? some Pics cheers Mike
please release me
Hi Shed,
My choices, are release wax, release wax and PVA or Frecote The frecote has a limited shelf life once open and the five litres in the 3 part Kit cleaner, sealer and release will last a life time and cost more than all the epoxy, foam, carbon tow ,ply and glass cloth that I have for about 4 gliders. Who makes the stuff you use and I will see if its available here, cheers Mike |
Not sure if there are any issues w/ international shipping but here's where I get mine:
http://www.acpsales.com/product.php?...97&cat=&page=1 |
Chemtrend (http://www.chemtrend.com/application...elease_systems) make the Chemlease stuff we use. I'll have to have a look on the tins for product codes but you're right; it's far from cheap. However, it's also very good.
Joined Nov 2008
Sorry once again to be asking for your advice on my ASG29 project out of sequence Mike but I'm refurbishing the fuselage and have got to the stage where I need to decide the wing joiner. I hope for it to be aerobatic and have decided on an HQ2.0/12 section 205mm chord 4.4m span.
Any guidance on diameter of joiner, length and material? |
on sailplanes about 4 mtrs , but I have gone up to 6mtrs wingspan normal thermalling type flight etc I use a 16mm aluminium tube OD with about a 14mm ID on a bigger ship or stronger joiner required I would use a tube with a 16mm inside Diameter and a 18mm outside with a bigger tube as the wing tube etc, I like this as it is easy accurate and we have anodised tube available as Curtain rails in most of our hardware shops. In heavy wind conditions I also have a stainless tube with Carbon in it as a bit of ballast and also stronger. Hope that helps. cheers Mike ps I will try find some photo's |
Joined Nov 2008
Simon |
| Thread Tools | |
| Discussion 80 in. W/span, 1/4 scale Sopwith Triplane | tenacious101010 | Giant Electric Planes | 1 | Sep 03, 2012 05:04 PM |
| Discussion Dummy radial instalation in 1/4 scale round cowl | greggk | Fuel Warbirds | 5 | Jun 18, 2012 04:06 AM |
| Sold 1/4 scale 4 1/4" inflatable cub tires | lla | Aircraft - General - Miscellaneous (FS/W) | 0 | May 28, 2012 10:55 AM |
| Sold 1/4 Scale Balsa USA Cub Nice, no engine LPU in OC Ca. $250.00 | stevster | Aircraft - Fuel - Airplanes (FS/W) | 3 | Apr 13, 2012 01:17 AM |
| For Sale SIG 1/4 scale Cub Airframe in NJ LPU | CarreraGTSCS | Aircraft - Fuel - Airplanes (FS/W) | 0 | Mar 25, 2012 03:29 PM |
