Old Nov 06, 2012, 07:00 AM
mikegbogh is offline
Find More Posts by mikegbogh
Upwardly Mobile
mikegbogh's Avatar
Roodepoort, South Africa
Joined Aug 2007
Lost foam
Hi Wingnutser,
The reason for making a mold in this case , is that at least several sailplanes will be built, and I can experiment with different layups , but the outside shape will always be the same.
Go search on my posts for my Borcian and DG505 both built as one offs with the lost foam method.
mikegbogh is offline Find More Posts by mikegbogh
Old Nov 06, 2012, 07:29 AM
wingnutzster is offline
Find More Posts by wingnutzster
Caravan driver
wingnutzster's Avatar
Lanseria airport South Africa
Joined Oct 2005
Aah I didn't see those, I am going to go have a look right away. You are clearly experienced at the mold making process but until I get there I think I will churn out some lost foam fuz's I have set up a bow based on some of your pics and some tutorials I found so let's see.
wingnutzster is offline Find More Posts by wingnutzster
Old Nov 09, 2012, 01:05 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
JS1 B serial no 002
Hi Guys,
Last night I joined the Nimbus 4 molds and the second JS1 , this morning popped them open and all looks good. I will need to clean of the join lines but , the second one with a different layup is 900 grams so I saved about 100grams, this is good news especially as it is mostly in the tail area.
While the big stuff is curing I continue to make smaller pieces with off cut cloth,
so a third canopy frame was laid up as well as some more streamlined shrouds.
Hopefully this weekend I will start the Rudder mould as well as the tailplane, and joiner molds.
regards
Old Nov 09, 2012, 01:23 AM
Titus ZA is offline
Find More Posts by Titus ZA
Hunting for Goat Lifters
Titus ZA's Avatar
South Africa, GP, Randburg
Joined Jul 2012
Great work Mike. Glad to see the 2nd fuse cam out easier than the first. 100grams less is good going. I'm fairly sure you may even be able to get it down a bit more knowing you.
Cheers
T
Titus ZA is offline Find More Posts by Titus ZA
Old Nov 11, 2012, 02:28 AM
WOO NZ is offline
Find More Posts by WOO NZ
WGTN NZ
WELLINGTON NEW ZEALAND
Joined Jun 2008
Mike, that is one sexy looking fuzz ! ! !
Woo
WOO NZ is offline Find More Posts by WOO NZ
Old Nov 20, 2012, 12:41 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Wing joiner
Hi All,
Slow progress, but progress it is ,I made up a joiner out of 2 x dowel sticks, painted and polished them and glued them together with the correct, dihedral. Next I made up a splitter board waxed everything and gel/coat and glassed one side, followed by the other side.
Sunday was very hot and I layed up the first joiner with a fast harderner, unfortunately the first half had started going off before the second half was completed, all seemed ok and I clamped the two halves, unfortunately the half with no "give" was slightly overfull and as a result there was a slight mismatch in alignment, the joiner is ok and strong but just wont fit the tube, I will use it for some testing, so far if I place it between two bricks and stand on it , it flexes slightly with my 80kgs load, so a 5kg glider is unlikely to ever reach those sorts of loads.
regards
Mike,
Hope to start some foam cores soon. fuselage 3 is just about ready for popping out the molds.
Old Nov 20, 2012, 12:44 AM
Titus ZA is offline
Titus ZA's Avatar
Joined Jul 2012
Nice work Mike. Glad to see that you managed to get some work done on the JS1 as I know you been pretty busy.
Cheers
T
Old Nov 20, 2012, 01:17 AM
swarrans is offline
Find More Posts by swarrans
I'm a glider pilot really.....
United Kingdom, England, Kent
Joined Nov 2008
Argh if you start the wings soon I'll have no excuse and will have to start my ASG29 wings too!
Interesting joiner construction method - I thought you were a pultruding fan though?
Simon
swarrans is offline Find More Posts by swarrans
Old Nov 20, 2012, 01:23 AM
Caravan driver
Joined Oct 2005
I don't know how many more times this can be said or in how many more ways....but you truly are an artist with this medium
I am quite happy with the progress of my plug and it's starting to take shape but will send you pics to get some advice on where it can be improved.
Old Nov 20, 2012, 07:29 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Simon
Hi Simon,
Mike (yyz) is a big fan of pultruded carbon rods and I think builds up the spars, with multiple lengths, my theory besides the fact that its not available here , is that yes it is accurately made and stronger than any hand lay up , but I guess if they are round in profile then any weight saving and or strength may be reduced because of the resin in the gaps , between the rods, resin on its own is maybe not that strong, but its one way of building with carbon.
I layup my spars in situ with 40k carbon tow and work the resin well into the carbon, on the joiners the same, except the first 10 tows into the mold are UHM 12k carbon which has a glossy sheen and makes a nice outer finish.
regards
Old Nov 20, 2012, 07:50 AM
Sutton Bank is offline
Find More Posts by Sutton Bank
North Yorkshire UK, on a big hill facing the prevailing wind. Coincidence?
Joined Oct 2007
Do you gently stretch the tows before the resin sets to ensure they are straight and parallel?
I've read this increases strength significantly by making every carbon fibre share the applied load more evenly when stress is applied, instead of some of them needing to unravel a little first. Makes sense to me but I've never tested samples to prove it.
Rog
Still loving the build!
Sutton Bank is offline Find More Posts by Sutton Bank
Old Nov 20, 2012, 08:00 AM
Caravan driver
Joined Oct 2005
Great piece in SA Flyer this month of mountain soaring with some lovely Nimbus shots. There are just so many beautiful performance gliders to choose from it makes sticking to the project started really tough, the JS1 must be one of if not the prettiest bird though
Old Nov 20, 2012, 09:04 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Rog
Hi Rog,
I dont make any special attempt to pull on the tows at all , but you are right ,but must say I wet out each tow and they lay fairly straight in the molds.
But I have found that once your gloves get sticky if you dont handle this tow carefully it all pulls apart and becomes fluffy, those accidents I bin.(fluffy carbon just dont cut it]
I also believe that at 16 mm diameter this joiner is overengineered so not too worried .
I am going to try make another joiner tonite with an epoxy that has 1hr pot life its stinking hot and 15mins pot life is courting disaster.
Work has ticked up as has flying so progress has slowed but wings start in the next week or two.
cheers
Old Nov 20, 2012, 02:01 PM
AllanK1 is offline
Find More Posts by AllanK1
Blenheim, NZ
Joined Dec 2007
Rod spars
Originally Posted by mikegbogh View Post
Hi Simon,
regards
For what its worth....I built my Vertex Electric saiplane using pultruded rods. http://www.rcgroups.com/forums/showt...ghlight=vertex They are glued into grooves in the foam made with a soldering iron tip with no webs then filled and bagged in Kevlar (did I say I hate this stuff!)straight over the top. It worked well although sat a little proud. Relatively cheap and easy and I would use the method again.
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Nov 21, 2012, 01:57 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Bulls eye
Hi All,
Just 3 shots and its in the zone
Fuselage 1 nice layup super strong and 1004grams
Fuselage 2 slightly lighter around the tail
spread tow carbon, carefull resin 914 grams
Fuselage 3 off cuts of hybrid and Arimid/Kevlar cloth
very carefull with resin. 804grams
The join seam was excellent , I got the timing just right and joined just when the glass tape went green but was still tacky.
cheers
Discussion 80 in. W/span, 1/4 scale Sopwith Triplane tenacious101010 Giant Electric Planes 1 Sep 03, 2012 05:04 PM
Discussion Dummy radial instalation in 1/4 scale round cowl greggk Fuel Warbirds 5 Jun 18, 2012 04:06 AM
Sold 1/4 scale 4 1/4" inflatable cub tires lla Aircraft - General - Miscellaneous (FS/W) 0 May 28, 2012 10:55 AM
Sold 1/4 Scale Balsa USA Cub Nice, no engine LPU in OC Ca. $250.00 stevster Aircraft - Fuel - Airplanes (FS/W) 3 Apr 13, 2012 01:17 AM
For Sale SIG 1/4 scale Cub Airframe in NJ LPU CarreraGTSCS Aircraft - Fuel - Airplanes (FS/W) 0 Mar 25, 2012 03:29 PM
