Old Sep 20, 2012, 10:04 PM
rcfan450 is offline
Find More Posts by rcfan450
United States, UT
Joined Nov 2009
how close can you install two nanos to each other?
Do you have to follow the 2" rule with the antennas?
rcfan450 is offline Find More Posts by rcfan450
Old Sep 21, 2012, 09:04 AM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
The arrangement in the photo seems too close to me. I would space them at least two inches apart. Of course, if a range check is required.
FlyingW is offline Find More Posts by FlyingW
Old Sep 21, 2012, 02:05 PM
rcfan450 is offline
United States, UT
Joined Nov 2009
I put the slave rx down in the frame by some wires. It only controls a smoke pump so I'll test if it locks out. I didn't want it to mess up the primary rx which runs the plane but was hoping to put it up higher if possible. Was hoping to get a response from Jim to see what he said about putting nanos close to each other. For now its away from the main rx.
Old Sep 26, 2012, 10:31 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
This is not recommened, but I will say that our 50% Yak is done this way, and it works fine.
JimDrew is offline Find More Posts by JimDrew
Discussion Can you tell me how to predict how long my aircraft will fly? GreenAce92_v2 Power Systems 76 Aug 22, 2012 07:15 AM
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Discussion Split elevon servo set-up - How do you install gyro ? solentlife Radios 2 Mar 15, 2012 09:43 AM
Discussion How do you close thread billygoat11 Trader Talk 5 Feb 29, 2012 06:03 PM
Question How close to each other can 35mhz frequencies be operated simultaniously ? heatwave150 Radios 5 May 08, 2009 11:29 AM
