Old Sep 21, 2012, 08:53 AM
chip.greely is offline
Find More Posts by chip.greely
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
Originally Posted by cpc625 View Post
Chip,
That's why I didn't recognize it. The Lil T wing threw me off. I started gliders with a Lil Tee back in '72. What a lead sled I built. I still have 2 unbuilt kits somewhere.
The Doodler still rests in the same unfinished state it was in when my wife lost interest.
Charlie
I'm guessing that was soon after seeing how the wing went together
The wing on the Lil' T is quite nice. I've built a couple (with/without tapered ends) to use for replacements on broken ARFs. The fuse seemed to be easily converted into a Viking Ship,...keel and all
Try the T's wing on your wife's Doodler and you won't go wrong
chip.greely is offline Find More Posts by chip.greely
Old Sep 21, 2012, 11:51 AM
scaflock is offline
Find More Posts by scaflock
I need some building time in t
scaflock's Avatar
United States, AZ, Douglas
Joined Nov 2007
Here's my Paragon which is a super floater! I did make up a ballast system for it so I can fly in higher winds. I can add up to 12 Oz of lead with the current plates I've made up. As a rule I only add enough weight to smooth out the flight for the conditions that day.
scaflock is offline Find More Posts by scaflock
Old Sep 21, 2012, 02:14 PM
jnmardister is offline
Find More Posts by jnmardister
rc aircraft crasher
jnmardister's Avatar
United States, MI, Lansing
Joined Sep 2012
some one please tel me what a ballast is. i looked it up online and came up some electrical reduction mumbo jumbo. that doesn't sound right. im guessing its just removable weight?
jnmardister is offline Find More Posts by jnmardister
Old Sep 21, 2012, 02:21 PM
kzimmerm is offline
Find More Posts by kzimmerm
Kurt Zimmerman ≡LSF 4461≡
kzimmerm's Avatar
Montrose, NY
Joined May 2003
Ballast is nothing more than extra weight centered on the CG to increase the planes wing loading. Ballast is added to a plane when wind conditions are such that if not added the plane would have little or no forward ground speed. So net result is it makes the plane fly faster.
Kurt
kzimmerm is offline Find More Posts by kzimmerm
Old Sep 21, 2012, 02:40 PM
alstrahm is offline
Find More Posts by alstrahm
AMA 3959
alstrahm's Avatar
United States, CA, San Jose
Joined Oct 2002
Chip, where did you get that Sagitta 900? I think I used to own it! It has top and bottom spoilers?
Al
alstrahm is offline Find More Posts by alstrahm
Old Sep 21, 2012, 02:50 PM
rc aircraft crasher
Joined Sep 2012
thanks for that, i have been seeing the term thrown around a lot and just wanted to make sure. are they hard to install?
Old Sep 21, 2012, 03:00 PM
kzimmerm is offline
kzimmerm's Avatar
Montrose, NY
Joined May 2003
Not at all. Effort has to be taken so that it doesn't move around during flight or landing. I had a glider where buy I would bolt the ballast (in this case, lead bars) through the bottom of the fuse and into a tee-nut pressed into the bar. By cutting various different lengths I was able to add weight in increments to get the desired flight characteristics.
Iíve tapped a lead strip to the top of a Gentle Lady one afternoon when the wind kicked up. Iíd say it was about 4-6 ozs. Worked out great, clocked a 30 minute flight then my daughter out did me with a 45 minute flight.
You will also see very clever methods of ballast mounting especially in the F3B/F3J gliders. Ballast is typically mounted in a tube with spacers so it doesnít change the CG.
Kurt
Old Sep 21, 2012, 03:23 PM
rc aircraft crasher
Joined Sep 2012
thanks again. i havent built my first plane yet but i plan to this winter when i get home. i was thinking about the BOT but people kept warning about that one. you can read all about it in the thread i made (also new to forums). so i am think about the chrysalis 2 meter. i know there are better builds but i dnt want to spend over 100 bucks on my first one. is a ballast a necessity?
Old Sep 21, 2012, 03:43 PM
kzimmerm is offline
kzimmerm's Avatar
Montrose, NY
Joined May 2003
A BOT built correctly is typically very lightly loaded, meaning having a very light wing loading. You will also find that it is a rather involved building effort. I would suggest you make provisions for ballast so you have the ability to add it when the time comes. I would not suggest flying in conditions early on in your learning effort until you start to become aware of how the plane handles. When you achive a level of comfort being able to handle windy conditions then at least you have the latitude to fly in those conditions.
Ballast tubes can be added in the wings or in the fuse. My latest Viking has ballast tubes in the wing. I had an Aquila Grand that had a ballast box in the fuse. It is all a matter of ease of access.
Finally it is all a matter of learning how to build, fly then master thermaling.The latter may take more time than you first think. By planning before the build will allow you greater lattitude in the future.
Best of luck on your build.
Kurt
Old Sep 21, 2012, 06:43 PM
Don Stackhouse is offline
Find More Posts by Don Stackhouse
Don Stackhouse's Avatar
United States, OH, Bradford
Joined Jun 2005
Depending on how much wind you have, the Chrysalis carries ballast well, but in our experience rarely needs it. It floats essentially the same as the older "gasbag floaters", but penetrates and ranges much better. One of our customers described it as having "the same float as a G.L., but twice the range." I've flown my electric with a 7S 2000 mah nicad that added ten and a half ounces. It tore up the sky with that added weight. Thermalling ability was off by a small but noticeable bit, but still quite respectable.
Don Stackhouse is offline Find More Posts by Don Stackhouse
Old Sep 21, 2012, 07:12 PM
Thermaleer is offline
Find More Posts by Thermaleer
Florida
Joined Jul 2004
My favorite floater the good 'ol Grand Esprit!
Thermaleer is offline Find More Posts by Thermaleer
Old Sep 21, 2012, 07:34 PM
LVsoaring is offline
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
OK, here you go.... pic one of her in happier times. Pic 2, her final launch. Pic 3, her spectacular demise in front of hundreds of witnesses in Visalia.....
LVsoaring is offline Find More Posts by LVsoaring
Old Sep 21, 2012, 07:36 PM
UberZogster is offline
Find More Posts by UberZogster
Be the duck. Whaaaa?
UberZogster's Avatar
United States, CA, Guerneville
Joined Mar 2012
Ouch!
UberZogster is offline Find More Posts by UberZogster
Old Sep 21, 2012, 08:29 PM
Carlsbad, Ca
Joined Mar 2007
Al
Yeah Al,
I think it even has your name in it or on the wing bags that came with it. Barndoor
'split' flaps, beautiful. Dean (RCDude01) posted it for sale and my friend Mark (FreeGlide) bought it. I eventually acquired it from Mark and my survivors will have to move it on, after me.
Old Sep 21, 2012, 10:29 PM
alstrahm is offline
AMA 3959
alstrahm's Avatar
Joined Oct 2002
Originally Posted by chip.greely View Post
Yeah Al,
how kewl is that, the Xmas Sagitta in great hands Built by Ralph Smith from Visalia, he passed, I got it in a silent action from his wife, who donated it to the club, flew it a lot and sold it to Dean, I am happy it's in the right hands!
Al
Discussion Lights (LED) Show me your lights! TioDave Multirotor Talk 22 Dec 23, 2012 09:52 AM
Discussion Show Me Your Papers! Big Foot 48 Life, The Universe, and Politics 36 Nov 29, 2012 11:43 PM
Discussion New car shown in the show-please tell me your thoughts Jorgen Wood Off-road Cars 4 Sep 07, 2012 09:23 PM
Discussion Show me a pic of your board camera and how it is mounted shesbreakingup FPV Talk 4 Apr 06, 2012 04:02 AM
Discussion Show me your worst wings john wing Flying Wings 1 Jun 19, 2011 01:45 AM
